Ghostrider 3rd Gear July 28, 2004 Share July 28, 2004 Yours auto or manual ? How much power you want to increase ? Doing a piggyback ECU on a stock car prob can gain a few horses...dun expect much but like 5-7bhp only. If you looking at hugh increase...there is only 2 way. One is force induction or the other way is to increase your capacity. Turbo/super charging can easily gain up to 40bhp and beyond (but that would means how deep your pocket is). 0.5bar boost is quite fun but power is addictive so I assume that you would want more and more...which will means pay more and more too. Capacity increase is a plug and play method. Since there is no factory bolt on kit for your B14, you would have to look at people fabricating a system for you. Maybe you should pay GTR a visit...they are doing fabricating turbo systems. Increasing cap you will have to go do your homework...what engine will sit nice and sweet into your bay without modification of the mounting points. If not to extract power from a NA machine is very expensive affair. If you want the car to be more responsive but stay in NA Tune... 1) If manual....lighten flywheel - Dun give you any horse increase BUT you can reach your power band faster. 2) Enlarge throttle body - Improve your respond from the car. 3) Port and Polish - Done correctly...it can yield up to 15bhp increase !! No joke...but not a cheap option. Expect to pay 1K plus for this. ↡ Advertisement Link to post Share on other sites More sharing options...
Dwoon 1st Gear July 28, 2004 Share July 28, 2004 Eh what & where is GTR? Thanks. Link to post Share on other sites More sharing options...
Phochem Neutral Newbie July 28, 2004 Share July 28, 2004 waoh... ur daily mileage must be very hiong.... wats ur avg FC??? mine 8.8km/lit Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 28, 2004 Share July 28, 2004 By the time I reach step 5 my wallet will feel alot lighter Jokes aside, whats your step 7? very much lighter man Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie July 28, 2004 Share July 28, 2004 mine is 13.7L/100km on average. That excludes hard driving Link to post Share on other sites More sharing options...
Phochem Neutral Newbie July 28, 2004 Share July 28, 2004 high.... 7.3km/lit.... Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 28, 2004 Share July 28, 2004 its a bm so what do u expect? Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear July 28, 2004 Share July 28, 2004 GTR Technologies. They are located at Bukit Batok. Building next to Orix Leasing. Ground floor....just behind the bustop in front of the buliding. Look for Ah Heng. Link to post Share on other sites More sharing options...
Dwoon 1st Gear July 28, 2004 Share July 28, 2004 OK, thanks. Do they do hybrid turbos or can they do a P&P on it + slight clipping on the blades, then re-balance it? Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear July 28, 2004 Share July 28, 2004 Best way to find out.... pop by for a chat with Ah Heng lor....can do or cannot do its up to him....but I warn you first lor...they a bit siow one...you ever heard of a 4WD RX7 FD before ? No ? They got it.....using the 4WD drive train from a Rex......very innovative. Link to post Share on other sites More sharing options...
Blaster Neutral Newbie July 28, 2004 Author Share July 28, 2004 mine is a manual. as for power-wise.....no figure for it Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear July 29, 2004 Share July 29, 2004 Simple...go look at some automotive bible and get your figs lor. If not dyno the bugger before you do any mods. Then you will see the diff in your modification. Maybe you tell us what car and someone who drives the same car might have the figs for you. Link to post Share on other sites More sharing options...
Blaster Neutral Newbie July 29, 2004 Author Share July 29, 2004 Err....a bit too late liao...i have changed my extractor and air filter liao no need to dyno oredi can feel the diff... anyway....wat's the diff in power between 4-1 or 4-2-1 extractor? any bros here know? Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear July 30, 2004 Share July 30, 2004 Did you changing the piping size as well ? De Cat ? Change muffler ?? You change all...you lagi love it !! Muffler change to semi flow can liao....if not you loose too much of your low end. 4-1 is more suitable for manual...power comes in higher rev. 4-2-1 suited for autos...helps to maintain the backpressure. Power diff...not sure. Link to post Share on other sites More sharing options...
Qr25vet Clutched August 7, 2004 Share August 7, 2004 Need some advice here. My current ride is a nissan b14 (i know quite old liao). Would like to increase the HP and torque. Will having a piggyback ECU helps? Or any other mods to do the job? Dun tell me to change car hor... one fo them is changing the compression ratio.....but 2 high will blow the engine Link to post Share on other sites More sharing options...
Yansen Neutral Newbie August 7, 2004 Share August 7, 2004 bro y is 4-1 more suited for manual? i'm driving manual n wanna improve the low end. any advice? btw the only mod ive done is change 2 a straight flow rear muffler, which i believe improves the high end only. however my driving style very rarely visits the high end. thanks. Link to post Share on other sites More sharing options...
Vtim 3rd Gear August 7, 2004 Share August 7, 2004 one fo them is changing the compression ratio.....but 2 high will blow the engine yap, skim the block head Link to post Share on other sites More sharing options...
Darkness Neutral Newbie August 7, 2004 Share August 7, 2004 where did u do this is this legal? ↡ Advertisement Link to post Share on other sites More sharing options...
Torque wrench hunt
Torque wrench hunt
Home repair advice needed
ERP rates increase/decrease thread monitor!
RS Chip Tuning
RS Chip Tuning
Computer advice needed
Town Council S&C Charges May Increase Soon!
