Cheekg99 Neutral Newbie August 25, 2004 Share August 25, 2004 have not done so for a month already ↡ Advertisement Link to post Share on other sites More sharing options...
Virus 2nd Gear August 26, 2004 Share August 26, 2004 32-36 psi is around 221 - 248 kpa. Link to post Share on other sites More sharing options...
Luckcent 4th Gear August 26, 2004 Share August 26, 2004 I use a tyre pressure gauge and between 30 - 32 psi will boe ok. Do not know the kpa equivalent. Link to post Share on other sites More sharing options...
Biccat Neutral Newbie August 26, 2004 Share August 26, 2004 44 PSI is way too high. For a 1.6 litre engine car, 30 to 34 PSI should do. Link to post Share on other sites More sharing options...
Soya Supersonic August 26, 2004 Share August 26, 2004 little to do wif engine capacity. more of the rim size, driving style and tyre type. Link to post Share on other sites More sharing options...
Biccat Neutral Newbie August 27, 2004 Share August 27, 2004 All these factors are inter-related. The engine capacity will also determine the wt of the car. That is why between one make to another, they may be some slight difference in tire pressure recommendation for the same rim/rubber combination. Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 27, 2004 Share August 27, 2004 That's the maximum pressure you tire can take. You ride will be very hard if pump to this psi. Usually the factory recommended lable is find at the fuel cap cover or on the b-pillar when you open the driver side door. Common practice are between 29psi to 36 psi. stole this thread for just this once... wont happen again hor. sorry sorry. which 1 is the B pillar? also saw what B pillar, C pillar, etc. what r they? A,B,C,D, E cup size i know... Link to post Share on other sites More sharing options...
Soya Supersonic August 27, 2004 Share August 27, 2004 A pillar = front windscreen side pillar, B pillar = pillar between front & rear door, C pillar = after rear door. Link to post Share on other sites More sharing options...
Soya Supersonic August 27, 2004 Share August 27, 2004 that's a wee bit of generalisation. engine capacity does not determine the weight of a car. does that mean a 1.6 getz weighs more than a 1.3 RX8? Link to post Share on other sites More sharing options...
Biccat Neutral Newbie August 28, 2004 Share August 28, 2004 It does but there are exceptions which I also agree with you. The Getz and RX1.3 are 2 different types of engine designs. But if we are talking about 1.6 litres of Jap and Korean made, they should fall within the range that I have mentioned. Here I am talking about the general, not the exceptions. Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 30, 2004 Share August 30, 2004 ic ic. kum sia! Link to post Share on other sites More sharing options...
Verna24 1st Gear September 26, 2007 Share September 26, 2007 any1 cn help, i jus upgrade 17" rims + tyres, but i nt really sure hw much shd i pump leh. my tyre profile 215/45/17, max pressure indicated i tin ard 310kpa, sohw much shd i pump to get both comfort + FC??? my frend say pump 230kpa cn liao leh, but sm say thats a certain % of max, so which is which?? Link to post Share on other sites More sharing options...
Verna24 1st Gear September 26, 2007 Share September 26, 2007 no ans??? Link to post Share on other sites More sharing options...
Garycsy Neutral Newbie September 26, 2007 Share September 26, 2007 dunno about whether diff tyres sizes require diff tyre pressure. but when i changed my tyres, size 185/60 R14, i asked soh tyres uncle frankie about tyre pressure amount. he said normal load - 200kpa can liaoz, if mostly heavy load then pump 220kpa. tyre is GR80. when i bought new BF Goodrich Sports tyre 1.5 yrs ago, the uncle told me 220kpa can liaoz.... Link to post Share on other sites More sharing options...
Verna24 1st Gear September 26, 2007 Share September 26, 2007 thats y,y r there 2 different schs of theory??? i pump 230kpa, sm brothers in another forum say i underpump???? they pump 250-300 for 17" wo Link to post Share on other sites More sharing options...
Garycsy Neutral Newbie September 26, 2007 Share September 26, 2007 Hmm... there is a tyre vendor active in this forum here - Mr. Robert of Hankook Tyres! Can help you enlighten us??? Link to post Share on other sites More sharing options...
Rskeisuke Clutched September 27, 2007 Share September 27, 2007 it has got to do with the load index of the OE tyre. http://www.toyojapan.com/tires/pdf/TTT_17.pdf read page 3 of the PDF file. ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
