Tyre pressure question.
Bluefreud
hi,
would like to ask for help...
as im driving an old car, so no more placards or whatever labels to tell me
how much pressure to pump my tyres...
so i always use the markings on the tyres as a guide...
the markings are as followed : "Max Load 437kg at 300kPa (44PSI) Max Press"
so i interpret it as pump air up to 300kPa or 44 PSI...
but after thinking a while, not sure am i doing the right thing?
my tyres are 175/60R14 79H
pls advise.
thks.
if u pump to 44psi, yr doors and wheels will shake themselves to bits...laugh.giflaugh.gif. that's the max pressure, not the recommended ones. for 14", 30-32 psi is more than enuf.
That's the maximum pressure you tire can take. You ride will be very hard if pump to this psi. Usually the factory recommended lable is find at the fuel cap cover or on the b-pillar when you open the driver side door.
hmm... i havent experienced the shaking part... even though been pumping
at that pressure...
wah then must really thks God that nothing has happened to me so far...
[sweatdrop]
ok, so now i continue driving till the amt of pressure drops to below the 30psi range?
then can re-pump to ard 30 psi?
thks all for your advice.
really appreciate it. [:)]
if u wait for 44psi to drop to 30, your COE may expire b4 that.... laugh.giflaugh.gif
juz press the needle on the tyre valve and release the air for abt 3-4 secs and re-pump it to 30 lah. thumbsup.gif
do you have a tire gauge? good to have one so that you can check... especially one that you can release the air out.
remember to check / pump only when the tires are cool... NOT after a long drive..
so, you can either pump in the morning by driving to a nearby station (nearby hor... if got to drive 10-15 min, the tires might be hot already) or pump at a higher pressure (2-3psi higher) after driving and releasing the air in the morning to the correct pressure
Might even explode if you do that and the roadholding will be affected too. Like what most us says 30 to 32 pis will do.
Might explode is very true [nod]
i remember reading in the papers some years back that someone was over filling the tyre pressure until the tire exploded... the victim fractured his hand with bone jutting out of flesh.... gross... [:(]
hihi, is there a specific guideline for tyre pressure or is it just aga aga? coz i have the same prob.. old car, sticker on the b-pillar gone.. recently changed to 195/55r15 tyres also. so whats the correct pressure to pump in kPa? thanks in advance. [:)]
