Davey Neutral Newbie August 29, 2004 Share August 29, 2004 Hi, Wondered if anyone tried the following "mod" ... 1. Remove spare tyre, jack and accessories 2. Replace with Tyre Inflater and Tyre Sealant Note: - In Singapore, for bad puncture, call tow truck. (anyway its free for those who are members of AA or STAR etc.) - Remember to put back spare tyre when travelling to Malaysia! Does the weight reduction help for better acceleration and fuel consumption? Understand that some of the new Continental models (e.g VW Golf) is doing this. (i.e. NO SPARE TYRE!) If it works, then later on I might dump my bass tube and just mount the subwoofer in the spare wheel well too! ↡ Advertisement Link to post Share on other sites More sharing options...
Silver_blade Turbocharged August 29, 2004 Share August 29, 2004 It does help to some extend, but it may also affect the weight distribution, but I guess ppl don't push their cars to the limit...so should feel much diff (of the wronf weight distribution issue). Those tyre inflater/sealant are bad for your tyre. Once injectedin to the tyre, the tyre has to be replaced. Those cars that doesn't come with spare tyres like, mini copper, VW glf, etc are running on 'run-flat' tyres which are very ex and it's also a case of, once tyre inflater/sealant is used = tyre to be replace. But the diff is that 'run-flat' tyre can still be used,without air, for over 15km. So that give them time to look for a tyre shup for repair...unlike our normal tyres, Link to post Share on other sites More sharing options...
Tanzy Clutched August 29, 2004 Share August 29, 2004 My car doesn't have the spare tyre. Driving for so many years, I've only ever changed the tyres twice. Makes a lot of difference for lighter cars but insignificant for big or powerful cars. Current stock of run flats are rubbish! Avoid at all cost. The ride is hard as hell. Feels like you have 19" or 20" rims. Link to post Share on other sites More sharing options...
Biccat Neutral Newbie August 30, 2004 Share August 30, 2004 FC will definitely improve with the reduced body weight. By how much, really depends on the car and driver. A lot of ppl are already dumping the sub-woofer into the spare tire space. For me, the sealant is a no-no. I would rather have the spare tire back. Link to post Share on other sites More sharing options...
Zakuii 1st Gear August 30, 2004 Share August 30, 2004 Will a 1.2ton car benefit from 10 to 20kg spare tyre being removed? Why not reduce our own body weight instead? Link to post Share on other sites More sharing options...
Hoppe Clutched August 30, 2004 Share August 30, 2004 Just found out a year ago, that my car has a spare but wrong rim size! haha... should have checked the tyre before I made a 2nd hand purchase. Link to post Share on other sites More sharing options...
Biccat Neutral Newbie August 30, 2004 Share August 30, 2004 Can you reduce your weight by this amt? Link to post Share on other sites More sharing options...
Soya Supersonic August 30, 2004 Share August 30, 2004 can. my spare is a semi-space saver type and it oredi weighs 18kg. so out it goes! Link to post Share on other sites More sharing options...
Davey Neutral Newbie August 30, 2004 Author Share August 30, 2004 Removing the car's spare and my own spare will yield about 30kgs or more ! Given the curb weight of the C3 at 1063kg, that is a significant percentage. Given the stock engine's 110bhp/147Nm performance figures (http://www.star-motoring.com/research/specs.asp?id=310), the power to weight ratio should be pretty good after that! Link to post Share on other sites More sharing options...
Genie47 1st Gear August 30, 2004 Share August 30, 2004 Saw the pics of your C3 or Pluriel as it is called. Pretty good. Citroen makes pretty funky cars. I believe for a small compact, they rated it to have the best safety and comfort. I think some German car magazine program squared it off with the SmartforFour. The Pluriel won the comfort, space and safety categories but failed when measured in performance and braking department. Also the price tag is a big margin as the Sfor4 is really expensive. Link to post Share on other sites More sharing options...
Zakuii 1st Gear August 30, 2004 Share August 30, 2004 I can, cos' i am grossly overweight! Then again, will 20/1200 = 1.67% reduction in weight help to improve pickup, FC, etc? Link to post Share on other sites More sharing options...
Majellann Neutral Newbie August 30, 2004 Share August 30, 2004 i've been driving for 2 years in Singapore without spare tyre. Link to post Share on other sites More sharing options...
Jiayong 3rd Gear August 30, 2004 Share August 30, 2004 Just found out a year ago, that my car has a spare but wrong rim size!haha... should have checked the tyre before I made a 2nd hand purchase. Wrong rim size is ok if u just intend to make it to the work shop. but definitely a no-no for longer distances. Mine also wrong size. but bo bian...cos rims for old cars very hard to find...so they cannot afford to give me the correct size... Link to post Share on other sites More sharing options...
Genie47 1st Gear August 30, 2004 Share August 30, 2004 Eh! I heard your car got a tail-out at the BMW turn in PG. Scary huh? Link to post Share on other sites More sharing options...
Virus 2nd Gear August 30, 2004 Share August 30, 2004 can. my spare is a semi-space saver type and it oredi weighs 18kg. so out it goes! My spare steel rim only 14kg. Why your space saver so heavy ?? Link to post Share on other sites More sharing options...
Soya Supersonic August 30, 2004 Share August 30, 2004 being a wowo, probably got crumple zones, airbags, reinforcement bars built into it. Link to post Share on other sites More sharing options...
Davey Neutral Newbie August 30, 2004 Author Share August 30, 2004 (edited) i've been driving for 2 years in Singapore without spare tyre. You must have a very good excercise/fitness regime ... But seriously, why do you go around without a spare tyre? Is the car's performance better? Edited August 30, 2004 by Davey Link to post Share on other sites More sharing options...
Davey Neutral Newbie August 30, 2004 Author Share August 30, 2004 Saw the pics of your C3 or Pluriel as it is called. Pretty good. Citroen makes pretty funky cars. I believe for a small compact, they rated it to have the best safety and comfort. I think some German car magazine program squared it off with the SmartforFour. The Pluriel won the comfort, space and safety categories but failed when measured in performance and braking department. Also the price tag is a big margin as the Sfor4 is really expensive. Two models of the C3 is available in Singapore, the 1.4L 4 speed automatic and the 1.6L SensoDrive (5 speed semi automatic). In addition, the C3 is also available with/without the panoramic sunroof. Last I checked, prices ranged from S$68K to S$77K for the different engines/options. The Pluriel is a different animal from the C3 and is even more cool! Unfortunately it is not available in Singapore. It can transform itself into the following variants: 1. Normal Saloon with roof 2. Normal Saloon with panoramic roof (e.g. looks like the Mazda 121) 3. Open top convertible/roadster (remove the entire roof and pillars) 4. Open top convertible pickup truck (remove rear seats) See here: http://www.citroen.com/site/htm/en/range/p...uriel/02_config ↡ Advertisement Link to post Share on other sites More sharing options...
Where is the most difficult and easiest place on Earth to gain citizenship?
FT discrimination agst locals
Any free Web hosting that is easy to set up?
South Korea: Seoul - Free and easy 2 nights stay in Seoul
Tis is Considered First? He is our G Hero. Haha
Calculation of "bone weight" (骨重)
MCF Points - reduction issues
Soya Bean Milk Recipes - Make at home easy.
