Engine Mounting
Sucker
On 8/30/2026 at 5:18 PM, Mkl22 said:
150k time to check flex disc and prop shaft center bearing  too.
good advice 👍
I'll take a look at the condition of the doughnuts when the car is on the lift to decide
there is some play when shifting from D to R and R to D, but acceptable to me
planning to drive for another 2 years max
if drive for 10 years, I'll definitely change them at the midpoint, which is now
On 8/30/2026 at 5:24 PM, Mkl22 said:
Got. Me. Can check and see. Gearbox mount is not fluid filled plus not near engine manifold or turbos. Not so easy to die.
you inspect the gearbox mount and see. Don’t need to change for just because workshop say might as well. Same with coils. I only change one. So far I have added another 30-40k km after just changing one coil.
the gearbox mount is cheap
for OCD people like me, not worth skipping it
otherwise see doctor money will be much higher than the cost of the gearbox mount
my psychologist hourly rate is more expensive than a piece of marseelee gearbox mount 😅
those DIY-able things I will only change the defective one instead of a set, i.e. coils, bulbs, wheel speed sensor etc
  • Haha! 4
On 8/31/2026 at 6:38 AM, ER-3682 said:
@Gnahp Why need to see Psychologist.?Because i kept talking about you.?Or you keep on buying Tools.?
mental health is equally important
it will affect the physical health too, vice versa
got to take care of both mah 😅
  • Haha! 1
Did you check loading of your place. Tools very heavy… possible to exceed floor loading as you continue to buy? 😂
  • Haha! 2
No need to check,the whole Condo belong to his Family.
  • Haha! 1
Twincharged
price has increased by 15%
comparing to 2.5 years ago
Edited by Gnahp
Twincharged
the engine rattles like a diesel whenever it is idling in gear
spent half an hour troubleshooting
I guess I know the source and the cause of the rattling noise
will tackle it this weekends when I am free
