Giggsy3 Clutched November 11, 2004 Share November 11, 2004 This problem has been going for more than 4 months at least. My car's rpm sometimes goes up to 1500 during idling instead of the usual 800. It will only happen after I travelled for a distance when the car comes to a stop eg. traffic lights or slow traffic, etc.... But the problem is inconsistent, sometimes have sometimes dun have, well most of the time have~~ Anyway, when this problem arise, I will have another problem: my air-con will be giving out warm air..... hot inside the car However my car temp remains normal throughout. So once I off my air-con my rpm will drop back to ard 1000 (looks normal), and I'll have to wind down my window throughout my journey without my air-con. Went to my mechanic before and he said it's something to do with this "air-con box" at my passenger seat there, not really sure what it is, and he said cos my car is a very old model, got to live with it as if want to find old spareparts is not worth the $$$.... So now I'm living with the problem and whenever it comes I'll just off my air-con and wind down my window for the journey.... Does any starlet users here got similar experiences??? ↡ Advertisement Link to post Share on other sites More sharing options...
Genie47 1st Gear November 11, 2004 Share November 11, 2004 I'll check to see with the rest of the guys if they can help you. I think the A/C needs some changing together with some tuning of the carburetor. After Hari raya. Be patient. Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie November 11, 2004 Share November 11, 2004 I can recommend a k class forum to you. They all drive that category of cars. vivio, starlet, etc Link to post Share on other sites More sharing options...
Giggsy3 Clutched November 11, 2004 Author Share November 11, 2004 haha thanks! But I'm rather broke so if the whole thing involves alot of $$$ so I would rather live with it!! Sorry for the trouble!! Link to post Share on other sites More sharing options...
Timoec Neutral Newbie November 14, 2004 Share November 14, 2004 go check izzit no a/c gas liao? Link to post Share on other sites More sharing options...
Burpmonster Neutral Newbie November 14, 2004 Share November 14, 2004 Could it be the problem with the belts (timing belts etc)?...I had such a problem with my car last time..... Link to post Share on other sites More sharing options...
Hitman Neutral Newbie November 14, 2004 Share November 14, 2004 This problem has been going for more than 4 months at least. My car's rpm sometimes goes up to 1500 during idling instead of the usual 800. It will only happen after I travelled for a distance when the car comes to a stop eg. traffic lights or slow traffic, etc.... But the problem is inconsistent, sometimes have sometimes dun have, well most of the time have~~ Anyway, when this problem arise, I will have another problem: my air-con will be giving out warm air..... hot inside the car However my car temp remains normal throughout. So once I off my air-con my rpm will drop back to ard 1000 (looks normal), and I'll have to wind down my window throughout my journey without my air-con. Went to my mechanic before and he said it's something to do with this "air-con box" at my passenger seat there, not really sure what it is, and he said cos my car is a very old model, got to live with it as if want to find old spareparts is not worth the $$$.... So now I'm living with the problem and whenever it comes I'll just off my air-con and wind down my window for the journey.... Does any starlet users here got similar experiences??? I use to have the same problem with my Peugeot. The idling problem was due to a dirty throttle body. The aircon problem was due to an ailing aircon compressor. Link to post Share on other sites More sharing options...
Jusnel 6th Gear November 19, 2004 Share November 19, 2004 bro, i had teh same problem some months ago.... it's really the air con compressor gone case already..... you need to change the air con compressor. if you dun change, and if you are driving on a highway with that air con problem, the compressor will burn out, and you will have burning smell blowing out of the air con vents. i bear it with for some months until i cant stand it. like you, i got to off the air con and drive with window down. on a hot day, i almost die in the car! went to a recommended (by another starlet owner) air con work shop. name: New Luck Air Con, at Ubi. near the Post Office Bldg. i dun have the address now. but you can check with the business listing directory or something. they quoted me $200 for a re-con compressor, new air con filter(look like a smoke grenade), new piping, plus top-up gas. time taken about 2 hours. owner is v friendly. i changed in July 2004. till now, no problem at all. pretty satisfied so far. if you go, tell the boss it's a red starlet (doing printing business) referred you to him. i hope he still remembers me though. i brought my company van to him also for air con gas top up. Link to post Share on other sites More sharing options...
Yongwd 1st Gear November 19, 2004 Share November 19, 2004 sounds like a bad joint or faulty relay. this relay circuit located below passenger glove box temporary turns off aircon compressor during inital drive off (juz like a Power pass system) Link to post Share on other sites More sharing options...
Giggsy3 Clutched November 20, 2004 Author Share November 20, 2004 What I did is just turn off the air con and everything is fine through the journey... No smell or burnt things at all. Temperature remains normal and I'll just step on accelerator for awhile, and I'll on the aircon again and it should be ok already. The main idea is to step on the acclerator hard and travel for awhile Link to post Share on other sites More sharing options...
Trust Neutral Newbie November 20, 2004 Share November 20, 2004 Air Con uses engine power 1 Inconsistant idling could be caused by faulty TPS (Throttle Positioning Sensor) 2 Check your air vent to see if it's closed 3 Link to post Share on other sites More sharing options...
Genie47 1st Gear November 20, 2004 Share November 20, 2004 The car is carburetted. There is no TPS. Link to post Share on other sites More sharing options...
Octopus 3rd Gear November 20, 2004 Share November 20, 2004 This problem has been going for more than 4 months at least. My car's rpm sometimes goes up to 1500 during idling instead of the usual 800. It will only happen after I travelled for a distance when the car comes to a stop eg. traffic lights or slow traffic, etc.... But the problem is inconsistent, sometimes have sometimes dun have, well most of the time have~~ Anyway, when this problem arise, I will have another problem: my air-con will be giving out warm air..... hot inside the car However my car temp remains normal throughout. So once I off my air-con my rpm will drop back to ard 1000 (looks normal), and I'll have to wind down my window throughout my journey without my air-con. Went to my mechanic before and he said it's something to do with this "air-con box" at my passenger seat there, not really sure what it is, and he said cos my car is a very old model, got to live with it as if want to find old spareparts is not worth the $$$.... So now I'm living with the problem and whenever it comes I'll just off my air-con and wind down my window for the journey.... Does any starlet users here got similar experiences??? Link to post Share on other sites More sharing options...
Octopus 3rd Gear November 20, 2004 Share November 20, 2004 Sorry.....my reply as below... I had the same idling problem which you've described a few months ago. But air-con seems OK. Had my mechanic to adjust the carburator a few times but unsuccessful. Finally need to replace the carburator @ $380 (Parts + labour). Link to post Share on other sites More sharing options...
Genie47 1st Gear November 20, 2004 Share November 20, 2004 380 for a carburetor!! Brand new carburetor? Link to post Share on other sites More sharing options...
Giggsy3 Clutched November 21, 2004 Author Share November 21, 2004 thanks for all the suggestions. I'm still relatively idiot to all the technical terms of the car parts, so pardon me for the ignorance. So roughly how much $$ I would need to solve the prob? As I'm very tight up in my pocket nowadays so hope can keep everything to a minimal Else have to wait for AWS liao Link to post Share on other sites More sharing options...
Genie47 1st Gear November 21, 2004 Share November 21, 2004 I will make arrangements with some of the Starlet kakis for kopi. Maybe can come to discuss your problems and see if it can be done by DIY. SMS me so I can your number. We meet on the fly so don't be surprised we can meet in 2hrs notice. Link to post Share on other sites More sharing options...
Lukie102 Clutched November 21, 2004 Share November 21, 2004 This problem has been going for more than 4 months at least. My car's rpm sometimes goes up to 1500 during idling instead of the usual 800. It will only happen after I travelled for a distance when the car comes to a stop eg. traffic lights or slow traffic, etc.... But the problem is inconsistent, sometimes have sometimes dun have, well most of the time have~~ Anyway, when this problem arise, I will have another problem: my air-con will be giving out warm air..... hot inside the car However my car temp remains normal throughout. So once I off my air-con my rpm will drop back to ard 1000 (looks normal), and I'll have to wind down my window throughout my journey without my air-con. Went to my mechanic before and he said it's something to do with this "air-con box" at my passenger seat there, not really sure what it is, and he said cos my car is a very old model, got to live with it as if want to find old spareparts is not worth the $$$.... So now I'm living with the problem and whenever it comes I'll just off my air-con and wind down my window for the journey.... Does any starlet users here got similar experiences??? my charade had this problem too....the rpm is irregular (sometimes engine died) but the air-con is still giving cool air. End up it's the aircon valve that's not working properly. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Singpost courier dishonesty with incredibly lousy service
