Apollo 1st Gear April 15, 2005 Share April 15, 2005 dun bother. the wind noise may result due to cross turbulence against the geometry of the car's top surface/ side surface, where eddy current are created under negative pressure side and positive wind slicing against it. the problem is actually excabrated by the think window glazing (abt 3-4mm) supplied by car manufacturers in a "lame" attempt to cut cost & shave weight for ur car. which may explain why older cars tends to hv better sound proof. also take a look at lexus / bmw's glazing n tat may explain a lot more abt luxury cars and budget cars. ↡ Advertisement Link to post Share on other sites More sharing options...
Lionheart7004 Neutral Newbie April 15, 2005 Author Share April 15, 2005 Ok i shall not use visor all bros said so. Just for the interest, i am driving a mondeo mk3. defnitely new. I just wonder why i having the wind noise as i suppose that conti car is suppose to have a better built in this area. Whereas for the soundproofing, i did the skin and front control paddle area. i am exploring to the wheel arch too. Can explore. Basically i just want to get my quality like in my old IS200. Thanks. Link to post Share on other sites More sharing options...
Lionheart7004 Neutral Newbie April 15, 2005 Author Share April 15, 2005 Apollo, your explaination damn chingg... dun really understand.. Any picture or illustration?? Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 15, 2005 Share April 15, 2005 There just no way to detect the source of the problem if the mechanics just use thier eyes , ears and hand to diagnose. For this diagnostic job the mechanics will have to use ultra sonic sound detector to "smell" for the minute leak. This is how it been done - wind up all the windows, switch on the air-con blower to the hihest possible speed. Lock tight all the doors, and any openings. Allow the blow to go for a few minutes to built up the air pressure inside the car, then use a ultra sonic leak detector to go round all the possible leakage area such as door seals, air con fresh air inlet duct, windscreen seal etc etc. Any slight leak will at once trigger the detector. Hpe this helps. Link to post Share on other sites More sharing options...
Lionheart7004 Neutral Newbie April 15, 2005 Author Share April 15, 2005 Yeobh, let me talk to the mechanic, hope they have the device to do the test. thanks. Link to post Share on other sites More sharing options...
Xiaogary Neutral Newbie April 15, 2005 Share April 15, 2005 U can try to buy those rubber stripes u paste along the circumference of the car where the door closes. 3M got those better quality one at $25 per box to do one door. If cheaper brand about 18 bucks got already. I also after stick visor, the wind noise is audible. Before that, very quiet. I suppose its coming in through the vibration of the window glass. Bcos I go listen the circumference of the door very quiet except the top part near the window visor. But I cannot live without window visor when raining and waiting for my VC. I will be stuffed to death if never on Air COn. Link to post Share on other sites More sharing options...
Lionheart7004 Neutral Newbie April 15, 2005 Author Share April 15, 2005 xiaogary, where to buy the 3M rubber? Link to post Share on other sites More sharing options...
Jrt77 Neutral Newbie April 16, 2005 Share April 16, 2005 can try pasteing armaflex strip at the window frame. Link to post Share on other sites More sharing options...
Thug Clutched April 16, 2005 Share April 16, 2005 (edited) Folks, My car always has wind noise when hitting aorund 80-90km/h. What is the best way to fight Wind Noise. i have sound proof the door liao but it is not improving. Wad is ur ride? Edited April 16, 2005 by Thug Link to post Share on other sites More sharing options...
Apollo 1st Gear April 16, 2005 Share April 16, 2005 actually not too chim.. it merely means that there r 3 problems/ factors 1/ the car shape. 2/ direction of the wind passing over ur car. 3/ the glass thickness being not thick. it can only shave 12decibel off noise. all problems/ factors r beyond soundproofing, in short only 1 cure, buy a lexus. Link to post Share on other sites More sharing options...
Benhew05 Neutral Newbie April 16, 2005 Share April 16, 2005 Folks, My car always has wind noise when hitting aorund 80-90km/h. What is the best way to fight Wind Noise. i have sound proof the door liao but it is not improving. Lionheart7004, Try this! one possible solution... http://carshinesvc.proboards37.com/index.c...&num=1113072174 Link to post Share on other sites More sharing options...
Lionheart7004 Neutral Newbie April 16, 2005 Author Share April 16, 2005 Chim. What is that?? Armaflex strip? Where can i find ? Link to post Share on other sites More sharing options...
Jameslai2004 Neutral Newbie April 16, 2005 Share April 16, 2005 (edited) Hello Bro. If you are refering to 3M Undercoating rubberized stuff. Then you could try to order from 3M themself but needs to order min. 10 bottles. Or you could also order from CarShine Auto. at http://carshinesvc.proboards37.com Hope this helps...... Edited April 16, 2005 by Jameslai2004 Link to post Share on other sites More sharing options...
Xiaogary Neutral Newbie April 17, 2005 Share April 17, 2005 U can try those car audio shop along thomson road. My friend got from there but we never take note the names of the shop. Link to post Share on other sites More sharing options...
Trd123 Neutral Newbie April 18, 2005 Share April 18, 2005 xiaogary, where to buy the 3M rubber? Yeah, where to source for it? Link to post Share on other sites More sharing options...
Josephtan1234 Neutral Newbie April 21, 2005 Share April 21, 2005 Folks, My car always has wind noise when hitting aorund 80-90km/h. What is the best way to fight Wind Noise. i have sound proof the door liao but it is not improving. Wind noise is always there, even if you drive a Ferrari. When it becomes loud enough depends on your car aerodynamic design. Noise also comes from the side mirror. Thats why sports cars uses tear drop design to reduce the noise. If your side mirror has a square and flat contour, it probably is the cause. Change it. ↡ Advertisement Link to post Share on other sites More sharing options...
Intermittent rattling noise, car in ICU
Indoor skydiving: Kyra Poh wins two golds at Wind Games
Steering rack noise on 2010 Altis
Extending quiet time by 1½ hours among recommendations to tackle neighbourhood noise in Singapore
NEA to lower vehicle noise levels from 2023
Brake squeak every morning
