Sony 1st Gear May 24, 2006 Share May 24, 2006 Mine is beind in the boot since it's a Hatchback. For vios, you might want to go to the shop and see if it can fit in. Frankly, I doubt so as it's quite thick. Go to the Pionner website for the actual dimension. Cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Notsoblurr Neutral Newbie May 24, 2006 Share May 24, 2006 hi Bro, Where did u place the subwoofer? izzit below your seat? Me wondering if it can feed below my vios car seat? Plan to buy the Pioneer TS-WX22A subwoofer and place it under the driver seat, but I already have my power amplifier and CD changer under the seat. There is a storage tray under the passenger seat. I am driving a Toyota Wish, might able to place it inside the rear boot truck space. Another question is, I am wiring it up myself, could I parallel the rear speaker signal from the amplifier to the subwoofer using the Y-connector? Link to post Share on other sites More sharing options...
Blue2 1st Gear May 25, 2006 Share May 25, 2006 thanks bro. Link to post Share on other sites More sharing options...
Blue2 1st Gear May 25, 2006 Share May 25, 2006 Link to post Share on other sites More sharing options...
Sony 1st Gear May 25, 2006 Share May 25, 2006 You are welcome. Do feedback when you have done up your sub. Cheers.. p.s. you know which shop to go? Link to post Share on other sites More sharing options...
Blue2 1st Gear May 26, 2006 Share May 26, 2006 no problem bro. Think might be going to AudioEdge to take a look. Link to post Share on other sites More sharing options...
Blue2 1st Gear May 26, 2006 Share May 26, 2006 went 2 take a look at Audioedge... Mr Foon told me that the active sub can be fitted below my seat. But no stock.... Need to go down again another day, tomorrow or next monday for the stock to arrive. Link to post Share on other sites More sharing options...
Sony 1st Gear May 26, 2006 Share May 26, 2006 Oh ya.. you should have called... apologies, forget to remind you. Link to post Share on other sites More sharing options...
Kwchan 1st Gear May 26, 2006 Share May 26, 2006 Hi all, Any idea if it is possible to have subwoofer box of only 15cm in depth? (yes, i only have 15cm to spare) I dont need very powerful sub, but most importantly it must be able to fit my backseat. thanks Link to post Share on other sites More sharing options...
Sony 1st Gear May 26, 2006 Share May 26, 2006 I think alpine and kenwood might fit the bill but not really sure. You can google and check out their Sub and see the spec. Not too sure if the pioneer one can do anot. You can check it out also. Cheers Link to post Share on other sites More sharing options...
Notsoblurr Neutral Newbie May 26, 2006 Share May 26, 2006 Hi all, Any idea if it is possible to have subwoofer box of only 15cm in depth? (yes, i only have 15cm to spare) I dont need very powerful sub, but most importantly it must be able to fit my backseat. thanks Pioneer have 2 model: 1) TS-SW124D Shallow-Type Subwoofer 2) TS-WX22A Sealed Amplified Subwoofer Link to post Share on other sites More sharing options...
Blue2 1st Gear May 28, 2006 Share May 28, 2006 no problem bro... oso need 2 go take a look. Link to post Share on other sites More sharing options...
Sony 1st Gear May 28, 2006 Share May 28, 2006 Try looking at Steelmate as well.. As the name implied, it's really enclosed in steel.. But AudioEdge don't carry this brand. Try Pin Liang or Chuan Sing. Link to post Share on other sites More sharing options...
Sony 1st Gear May 28, 2006 Share May 28, 2006 I think TS-SW124D Shallow-Type Subwoofer is a passive sub. Unless he wanted to add a Amp to drive it, he can just opt for an Active. Cheers Link to post Share on other sites More sharing options...
Zambik 2nd Gear May 29, 2006 Share May 29, 2006 I agree active sub owners normally will upgrade... I'm one of them, will be selling off the 10" Audiobahn one soon to change to a 12" sub with customised enclosure. Active sub don't provide enough depth in the bass. Link to post Share on other sites More sharing options...
Blue2 1st Gear June 1, 2006 Share June 1, 2006 thank bro for the advice... Dun know if the sound quality for Steelmate and Pioneer which is better? Link to post Share on other sites More sharing options...
Sony 1st Gear June 1, 2006 Share June 1, 2006 Pioneer have very good review from users.. while steelmate is from china but hear say hear say the quality is not too bad either. Might be cheaper also. Link to post Share on other sites More sharing options...
Kwongwing Neutral Newbie June 1, 2006 Share June 1, 2006 Pioneer is better - have experience with both and installed Pioneer in the end! ↡ Advertisement Link to post Share on other sites More sharing options...
Is a subwoofer necessary?
Save up to $100 on the Brand New Sony XS-AW8 Compact Powered Subwoofer
Which 10" boxed subwoofer to get?
Recommend under seat active sub
Questions on my active sub LPF crossover
Active vs Passive Setup
Active Brake Assist function limited
