Install insulator on the aircon pipe
Tanhl
Newsman,
Good start for the pics. I think most of us know where the pipes are. Don't you think the 'x2' pipe is wee bit too close to the engine? Pretty narrow...kinda hard to attach the insulator plus foil...
I will try this way:
Measure the lenght required for the hose,
Slit the hose on one side only,
the slit on the hose should be able to hold on to pipe;
Get Aluminium foil in a Roll with width of about 3cm, get those
with sticky tape on one side. Roll over the Insulator.
Do U think, this way on work?...Advise pl.
Hope it work as easy as i think.
Anyway...i am a lousy with DIY workmanship
It's worth a try but risky. Dunno whether engine will go up in flames! [laugh]
It's still best that we wait for some pics from the original threader, Tanhl.
Edited by Brock
Do keep us updated, Genie. This DIY would be pretty effective. Even a noob like me should be able to get it done! [laugh]
OK...finally wrapped up my Aveo5 Air-Con pipe.
Not the Best of DIY as seen in Pic.
Will re-do after getting better grade Alumiumium Foil.
Do it at yr own RISK!!!!!!!!!!!!!!!!
Found the insulator type of cover at Daiso IMM. Decided to DIY to cover the air-con pipe.
Pic 1 = material ( 2 layers of foam and 1 layer of foil)
Pic 2 = radiator area
Pic 3 = firewall area
PS: pls wait till engine cool down.. [rolleyes]
the material came as shown in your pic or you have to manually paste the 2 layer of foam + foil together?
I saw this thing in Daiso too. Freaking cheap. Actually it is to be used for their garden tap to prevent it from freezing in winter.
yup... hehe.. since heat can't goes out.. it cannot come in too.. [sweatdrop]
I like it since it got the aluminium foil layer outside... not to mention freaking cheap..
Do update us on any difference in terms of interior temperature. Heh...if can use thermostat as indicator, it'll be better.
