Paladin Neutral Newbie May 16, 2005 Share May 16, 2005 Hi , just wondering if it is possible to use bottled distilled water as battery water? If I am not wrong those battery water selling in the petrol station are actually just distilled water right? Anyone using distilled water as replacement? ↡ Advertisement Link to post Share on other sites More sharing options...
Toalson 1st Gear May 16, 2005 Share May 16, 2005 Yes they are the same..... I hv friends who use the distilled water from watson as alternative (cheaper). So far I did try bf on my previous ride but right now lazy n on maintenance free batt thus no need. Link to post Share on other sites More sharing options...
York Clutched May 16, 2005 Share May 16, 2005 (edited) just take note....those found in petrol kiosk...label as battery water...ve very lite acid in the content(chk & found sumtimes ago)... those sold in supermarket as distilled water....r drinkable(pure distill) u can use distilled water for ur battery...DUN use tap water... Edited May 16, 2005 by York Link to post Share on other sites More sharing options...
Hattee Neutral Newbie May 16, 2005 Share May 16, 2005 Depends how much you trusted the source of distilled water. They can be by-product of boiler plant but if their bottling pipe are not adequately anodised, the distilled water is only pure at its point of condensation. Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 16, 2005 Share May 16, 2005 Theory wise, can use. But better don't take any chances and use those battery water instead. After all, how much $$ can you save by using bottled distilled water as compared to battery water? Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 16, 2005 Share May 16, 2005 Highest quality of distilled water are sold mainly at pharmaceutical shops. You need only to add distilled water DO NOT try to add diluted suphric acid. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 16, 2005 Share May 16, 2005 Actually a lot. If you got a resistance tester. Pure water is supposed to have resistance of 18-megaohms. Means no salts in it. BTW, pure water is not very pure. It is acidic in nature which explains why you cannot use it purely in your coolant system. The acid is actually in the form of carbonic acid from dissolved CO2 from the air. pH of pure water ranges from 5-6. Don't let people fool you into thinking pH of water is 7.5 Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 17, 2005 Share May 17, 2005 (edited) [reply] Actually a lot. You mean can save alot $$ by using distilled water instead of battery water? I only know battery water costs about $1 per bottle. How much does good distilled water costs? Also where can I buy it from? Edited May 17, 2005 by Octopus Link to post Share on other sites More sharing options...
Genie47 1st Gear May 17, 2005 Share May 17, 2005 Battery water is best left for battery. You can't take chances with that unless you got means to test if the cheaper distilled water from NTUC Fairprice, Guardian Pharmacy or First Choice meets 18-megaohm. Maybe I will do this for you guys. I got equipment. Link to post Share on other sites More sharing options...
Paladin Neutral Newbie May 27, 2005 Author Share May 27, 2005 I post the question because I remember having reading somewhere that battery water is actually distilled water. Actually a 1.5L ice mountain is selling at 65cts in NTUC I think, while a 1L battery water is selling at $1.30 in Shell petrol station. Link to post Share on other sites More sharing options...
Paladin Neutral Newbie May 27, 2005 Author Share May 27, 2005 Very interesting... so what equipment do u use to test the resistant? Please post the result here. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 28, 2005 Share May 28, 2005 Yes distilled water or de-ionised water is the way to go. Have been using rain water for donkey years until I give up my car 10 yrs ago. Tap water is actually Ok, but because it is being piped by metal pipes and it also contain chlorine therefore it is not de-ionised and have too much other foreign particles.All these are in a way harmful to the electrolysis process inside the battery Link to post Share on other sites More sharing options...
York Clutched May 28, 2005 Share May 28, 2005 (edited) 'I post the question because I remember having reading somewhere that battery water is actually distilled water. ' U may wan to try....dip a few drops of battery water on a concrete flooring...u will see tiny bubble bubbling up....as I mentioned earlier...contains veri lite acidic.. Edited May 28, 2005 by York Link to post Share on other sites More sharing options...
Poortraveller 1st Gear May 29, 2005 Share May 29, 2005 Actually a lot. If you got a resistance tester. Pure water is supposed to have resistance of 18-megaohms. Means no salts in it. BTW, pure water is not very pure. It is acidic in nature which explains why you cannot use it purely in your coolant system. The acid is actually in the form of carbonic acid from dissolved CO2 from the air. pH of pure water ranges from 5-6. Don't let people fool you into thinking pH of water is 7.5 i tot DI water is 18-megaohms? DI water and distilled water same meh? Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 29, 2005 Share May 29, 2005 [reply] I post the question because I remember having reading somewhere that battery water is actually distilled water. Actually a 1.5L ice mountain is selling at 65cts in NTUC I think, while a 1L battery water is selling at $1.30 in Shell petrol station. The wordings on the battery water bottle gives me the impression that its more than just simple distilled water. (Maybe its just marketing) Can't remember the exact wordings, but I'd rather use battery water instead. Anyway, 1 bottle can last a long time, so the costs saving compare to buying distilled water at NTUC isn't much. Link to post Share on other sites More sharing options...
Sk2000sg Neutral Newbie May 29, 2005 Share May 29, 2005 Not advisable to purchase from Shell store too Exp. Me brought from supermarket cost only $0.50 / Ltr Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 29, 2005 Share May 29, 2005 Thanks for the tip. By the way, which supermarket? I remember seeing something like $0.50 per bottle selling at Giants few months ago ...... guess I should wait for the clearance sale then buy. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 29, 2005 Share May 29, 2005 If DI water and distilled water are pure enough, they are almost synonymous. Both should be 18megaohm water. ↡ Advertisement Link to post Share on other sites More sharing options...
Family of three electrocuted to death at Taman Jurong
