Topgun7557 Neutral Newbie June 14, 2005 Share June 14, 2005 Hi Guys, Have you ever notive that our spare tyre is of full size. By that I mean it is the same as the 4 running wheels. I have seen the spare tyres for Matrix, Civics and even some BMW that the spare tyre is way smaller. looks more like for motorcycles. Anybody know where we can get the smaller version spare tyre. This would help to reduce the weight of the Optra and lower FC if possible. ↡ Advertisement Link to post Share on other sites More sharing options...
Kopikao Neutral Newbie June 14, 2005 Share June 14, 2005 Why you want to do that? Most likely diff size cos the owners upgraded their wheels but didn't change the stock spare of 14". Wonder what will happen if the tires busted and need to change? Can run on different size? Link to post Share on other sites More sharing options...
Topgun7557 Neutral Newbie June 14, 2005 Author Share June 14, 2005 No no no. It's the stock spare tyre from dealer. If you don't believe me, just pop by kah motor or komoko and have a look at the spare tyre. Link to post Share on other sites More sharing options...
Cbx750p 1st Gear June 14, 2005 Share June 14, 2005 Because the spare wheel well is designed for a full size tire, you may have problem support the floor board if you fit a undersized run flat tire ! You are probably trying to save weight ? It would not make so much difference actually, the FC is sucks already ! CBX Link to post Share on other sites More sharing options...
Yamrxz Neutral Newbie June 14, 2005 Share June 14, 2005 yes Honda and Hyundai spare are really small and it only for temporary use and cannot travel more than 80km/h. Tried to get a picture from the net but only the spare for proton gen 2. Notice the tyre profile like m/bike tyre. Link to post Share on other sites More sharing options...
Toalson 1st Gear June 14, 2005 Share June 14, 2005 Those smaller tyres are space savers aka donuts. It saves space n lighter. As long as u upgrade ur tires correctly; keeping the OD consistent, u'll not hv problem if u use the small tyres during emergency. Anyway its stated under LTA tat when one change tyre or rim, the OD must not be different. Guess not many actually ensure n ROV does really enforce tat to the extreme as well Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 14, 2005 Share June 14, 2005 These type of spare tyres are physical size is the same as your other 4 tyres. They are design solely to be use as as spare tyres and cannot be repair, and will allow to be use temporary for up to few 100km distance. Link to post Share on other sites More sharing options...
Topgun7557 Neutral Newbie June 14, 2005 Author Share June 14, 2005 Any idea where I can get those? Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 14, 2005 Share June 14, 2005 Most of the scrapyard importing Japanses used car parts should have them. Link to post Share on other sites More sharing options...
Kopikao Neutral Newbie June 15, 2005 Share June 15, 2005 Hmmm... interesting... i remove the spare tires before and it was real heavy... Link to post Share on other sites More sharing options...
Toalson 1st Gear June 15, 2005 Share June 15, 2005 Its definitely heavy cos its normal steel rim of 14" if not wrong. The donuts r so much lighter. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 15, 2005 Share June 15, 2005 (edited) Hi Guys, Have you ever notive that our spare tyre is of full size. By that I mean it is the same as the 4 running wheels. I have seen the spare tyres for Matrix, Civics and even some BMW that the spare tyre is way smaller. looks more like for motorcycles. Anybody know where we can get the smaller version spare tyre. This would help to reduce the weight of the Optra and lower FC if possible. these type u mean for spare tyres take note 1) such mini donuts cannot take more than 60-80 km/h for more than 1 hr 2) they run at a very very high higher pressure than normal sized spares 3) spare tyres should be changed after 4-5 yrs if not used, and if u have used it before, must change after first 3yr of vehicle life as it will have hardened up 4) due to their size/footprint/threadblock , their sole purpose is getting u to nearest tyre repair joint, not driving around, i seen a volvo s80 2.5T driving with this from pie at simei all the way to pie clementi, u drive with such tyres u find ur steering/handling will be off, and more pronounced for bigger cars with bigger tyres, eg 235 in 17inch, and use these mini donuts such ads in yahoo below, eg the one selling that pathetic tyre above, are a danger to public safety copy n pasted ad ========================== This is the spare tire / tyre of my old mazda 323. 10 years old. Only use it for 7 – 10 times. BridgeStone T9003. Made in Japan Temporary use only. Max speed 50 MH (30km/H). Inflate To 60 PSI ( 42 kg cm3). Max load 1235 LBS 60 PSI max Press. Thread 3 Nylon Side Wall 2 Nylon Tubbles. Tracompa.3. T115/705D14 88M Dot Enta. Wheel diameter is 20 inch. Wheel width is 5 inch Important* Item is only for self-collection only. I Live around Paya Lebar ( Near Lor ah Soo ) Edited June 15, 2005 by Furrynadz Link to post Share on other sites More sharing options...
Cheeze Neutral Newbie June 15, 2005 Share June 15, 2005 so..in theory if I take it out...cos my car performance increase slightly? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 15, 2005 Share June 15, 2005 at most 15kg how much performance can increase Link to post Share on other sites More sharing options...
Cheeze Neutral Newbie June 15, 2005 Share June 15, 2005 hee well, when u r driving a car with weak low end torque...even 5kg might make u feel the difference... Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 15, 2005 Share June 15, 2005 unless its a pajero mini or some other pathetic 660cc na car and u fill up with 4 plumpers inside, not likely Link to post Share on other sites More sharing options...
Topgun7557 Neutral Newbie June 15, 2005 Author Share June 15, 2005 Yup that's the one. What's the PCD for it? If of no use to you, I would like to give it a try. Link to post Share on other sites More sharing options...
Imprezawagon Neutral Newbie June 15, 2005 Share June 15, 2005 KopiKao >> Let the original tyre stay! No change to space saver. Want to save a few Kilograms to get 0.1 hp increase but endanger your life? The spare tyre is there for a reason. The AUTOmobile designer & engineer tat built your car put the spare tyre there also to take impact upon collision from the rear. It is able to take shock while at the same time retain the rear body structure of the car. By taking out the spare wheel, you indirectly endanger your rear passenger during accident! Pass massage around. PLEASE.. ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Tyre puncture
Tyre puncture
SPARE PARTS LIST
SPARE PARTS LIST
Continental CSC 7.
Continental CSC 7.
