Pisces69 6th Gear July 5, 2005 Share July 5, 2005 what i see is that it look exactly the same....but any one know how to differentiate between original and not original one? When Cyclone first came out many years back, a copycat soon followed. Named Hurricane (I think). Cyclone was brass & the other was silver in colour. ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 5, 2005 Share July 5, 2005 [replyYou may need up to 4 of them depending on car make/type to be effective. To achieve the base effect, minimum 2 is required, which are to be deployed between the inlet/outlet. Regards,[/reply] Mine is carb car, so only need 1 to b installed as close to the carb as possible. For injected engines, I just cant see the difference of putting more than 1. Only the one nearest to the injectors cud make any difference. But if the injector supplies fuel directly into the combustion chamber, I don't think it will help at all. The swirling air effect wud have been lost by then. The design of the valves & head wud have it's own swirl effect in the chamber. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear July 5, 2005 Author Share July 5, 2005 If that is the case, Surbo will not be effective as well. Pardon my ignorance, what is a carb car? Regards, Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie July 6, 2005 Share July 6, 2005 Just to update, something wierd....i have removed my CAI ...fine ...now i have a surbo snout pointing toward the front of the car ...so a short RAM kinda intake ....i did mention that the pickup improved ...so scrap the CAI ....then something wierd ....my usual consumption for the past 2 yrs has been between 10-11km/l ...with that CAI removed and i have just done up my 1st tank and my consumption efficiency increased to 13.8km/l ....walaoeh ..what's happening .....i used to run with such config before and still 10-11km/l ...anyways ...it's a great sign!!! Link to post Share on other sites More sharing options...
Dennisk Clutched July 6, 2005 Share July 6, 2005 that's great...so you using single or twin surbo...so you conclude that surbo give you better FC? Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie July 6, 2005 Share July 6, 2005 I think so....didnt change driving style and route a bit... i am using single....i am a little worried tho with such a drastic change....same petrol and RON as well.... maybe FI tio tat ? hahah Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 6, 2005 Share July 6, 2005 Sorry I can't comment about Surbo as I have never seen it & don't know how it works. Carb means carburettor as opposed to fuel injection. Link to post Share on other sites More sharing options...
Dennisk Clutched July 6, 2005 Share July 6, 2005 continue to keep us posted...what is your ride? your's manual or auto ride? when did you install surbo? need to make appointment? Link to post Share on other sites More sharing options...
Kelpie 2nd Gear July 6, 2005 Author Share July 6, 2005 Ya lor as Dennisk has mentioned, let us know the subsequent refill whether it maintains that way. If so, I will go for Surbo liao! Regards, Link to post Share on other sites More sharing options...
Dtoh Neutral Newbie July 10, 2005 Share July 10, 2005 hi.. I do hav 1. use oni 1 mth. stil new. got spare cos fix cone filter n obstruction. So got spare. Can cal me if u intersted. 9746 2634 (des) Link to post Share on other sites More sharing options...
Clody Neutral Newbie July 16, 2005 Share July 16, 2005 Why not try something new? SR Typhoon. Haven't gotten the chance to post in classifieds. I let you see the page. http://community.webshots.com/album/390938199iLMLqz can contact me through e-mail at [email protected]. Link to post Share on other sites More sharing options...
Tigerstrike Neutral Newbie July 19, 2005 Share July 19, 2005 Hi there, R u refering Ginza plaza? who's selling the cyclone II around $50? If i'm wrong, pse enlighten. Tks! Regards Link to post Share on other sites More sharing options...
Zrun Neutral Newbie July 20, 2005 Share July 20, 2005 If unsure of direction of twist for surbo or cyclone, the best config is surbo before filter box and cyclone is after.......if u r going for both together. Surbo before the filter, when air passes through the filter, it'll all be straight again. No more "surbo'ing" effect, whatever it is. If surbo is asking their customers to do this, it'll be unethical, since it is like putting an orange in front of your AC to make it cooler. Link to post Share on other sites More sharing options...
Wbucket Clutched July 21, 2005 Share July 21, 2005 Ya, it does sound illogical. But could there be more fiuld dynamic theory involved that we do not know which is behind the working principle of the Surbo? Got a friend who uses it and feedback about its "feel-able" improvement. Link to post Share on other sites More sharing options...
Zrun Neutral Newbie July 21, 2005 Share July 21, 2005 If it is after the filter, there "may" be some effect. Before the filter, it is impossible to cause any kind of difference in air flow. The problem is that the "effect" will not propagate into the engine if it is outside the filter. Link to post Share on other sites More sharing options...
Wbucket Clutched July 21, 2005 Share July 21, 2005 Maybe you are right. But I wouldn't comment base on groundless speculation. I have studied basic fuild dynamic and realised that it isn't just simple logic. Link to post Share on other sites More sharing options...
Zrun Neutral Newbie July 21, 2005 Share July 21, 2005 I know Mazda has this tumbling technology inside the intake manifold, which cause air to flow very accurately into the center of the cylinder, causing some good tumble dynamics. However, note that it is extremely localized and high precision technology. Link to post Share on other sites More sharing options...
Wbucket Clutched July 21, 2005 Share July 21, 2005 In manufacturing and design, we always emphasize the need for robustness in the designs we do. Who know what natural attributes are involved when they designed the surbo or cyclone, might be through trial and error that they are able to produce something that boast performance which they themselve might not be able to explain it. End of the day is, if you tried it and it doesn't work for you, do comment your findings. But if you can't support your theory by any backing of testing results or theory, but only uses layman understanding of how air is supposed to flow, then isn't your assumption very question-able? People uses to think that earth is flat, cause that is what they see. Until someone comes around and prove them wrong. So everything is possible until proven otherwise. ↡ Advertisement Link to post Share on other sites More sharing options...
Cyclone Rusty
Cyclone Rusty
Australia cyclone upgrade to top threat level
Show Your Support to the Victim of Myanmar Cyclone and Szechuan Earthquake
Estimated 80,000 cyclone dead in one Myanmar district: official
Cyclone & Pulley
Cyclone & Pulley
Car-nival - Cyclone 3 Air Charger
Are these worth investing in? Cyclone 3, RS Twin Power Intake ...
Cyclone II
Cyclone II
