Chinablue Clutched May 2, 2010 Share May 2, 2010 normally when pumping at petrol station, you will just see the label at the pump and just fill up. so how do i know the RON98 that i am pumping is the actual RON 98 and not some lower grade fuel? ↡ Advertisement Link to post Share on other sites More sharing options...
HOUSENUMBER Neutral Newbie May 2, 2010 Share May 2, 2010 you can try smelling it Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 2, 2010 Share May 2, 2010 I think you worry too much, this sort of thing you also think so much. Life must be very stressful for you. The best solution is to pump the cheapest grade so you won't lugi. How do you know the kampung chicken that Five Stars is selling is really from Kampung? How do you know that when you order Coke, the drink served to you is not Pepsi? Link to post Share on other sites More sharing options...
Ldawn88 2nd Gear May 2, 2010 Share May 2, 2010 I have never thought of this. Why? Do you suspect the integrity of the petrol company that you patronize? If worried, just change to another one. normally when pumping at petrol station, you will just see the label at the pump and just fill up. so how do i know the RON98 that i am pumping is the actual RON 98 and not some lower grade fuel? Link to post Share on other sites More sharing options...
Darthkk Clutched May 2, 2010 Share May 2, 2010 I think you worry too much, this sort of thing you also think so much. Life must be very stressful for you. The best solution is to pump the cheapest grade so you won't lugi. How do you know the kampung chicken that Five Stars is selling is really from Kampung? How do you know that when you order Coke, the drink served to you is not Pepsi? wow I like your answer!!! Link to post Share on other sites More sharing options...
Eyke Supercharged May 2, 2010 Share May 2, 2010 so how do i know the RON98 that i am pumping is the actual RON 98 and not some lower grade fuel? take sample then send to lab for testing lor. Link to post Share on other sites More sharing options...
Chinablue Clutched May 2, 2010 Author Share May 2, 2010 I have never thought of this. Why? Do you suspect the integrity of the petrol company that you patronize? If worried, just change to another one. somehow it just crossed my mind when i was refilling myself. while waiting, i was thinking how do i know if i am pumping the real thing? - you can't see the fuel going in, even if so, all petrol looks the same. - you can't drink it and taste the difference(not like coke and pepsi above which both have their own distinctive taste) Link to post Share on other sites More sharing options...
Kiadaw 6th Gear May 2, 2010 Share May 2, 2010 (edited) Singapore don't use RON, US does. The grades (92, 95,98) are octane rating. The higher the rating (say 98 compare to 92) means can prevent premature combustion aka knocking or pinning better, & higher octane grades are usually need only for high end & turbo cars that runs high compression & rpm. Most sedan works fine with 95 (read manual, or ask technician), & contrary to common believe, higher octane reading doesn't yield better FC or hp. By the way, all pump gases in Singapore are "branded" (no supermarket brands, like ASDA or Tesco or unknown brands), so you should not worry with the petrol quality at all. Edited May 2, 2010 by Kiadaw Link to post Share on other sites More sharing options...
Perc2161 Neutral Newbie May 2, 2010 Share May 2, 2010 Singapore don't use RON, US does. The grades (92, 95,98) are octane rating. The higher the rating (say 98 compare to 92) means can prevent premature combustion aka knocking or pinning better, & higher octane grades are usually need only for high end & turbo cars that runs high compression & rpm. Most sedan works fine with 95 (read manual, or ask technician), & contrary to common believe, higher octane reading doesn't yield better FC or hp. By the way, all pump gases in Singapore are "branded" (no supermarket brands, like ASDA or Tesco or unknown brands), so you should not worry with the petrol quality at all. Err... Wrong SG uses RON rating for petrol. Anyway, its impossible to tell whats the exact RON value of the petrol unless it sent to labs for analysis. For the rest of us, the only thing we can do is to look out for signs like detonation/pinging/knocking if our engines are highly tuned. If your car is tuned strictly for RON98 petrol, you will get knocking if you pump 95. Link to post Share on other sites More sharing options...
Perc2161 Neutral Newbie May 2, 2010 Share May 2, 2010 somehow it just crossed my mind when i was refilling myself. while waiting, i was thinking how do i know if i am pumping the real thing? - you can't see the fuel going in, even if so, all petrol looks the same. - you can't drink it and taste the difference(not like coke and pepsi above which both have their own distinctive taste) I can understand how you feel. Btw, petrol stations every did put the wrong fuel before in UK. They used RON98 and sell it as RON100. Link to post Share on other sites More sharing options...
Yuan 6th Gear May 2, 2010 Share May 2, 2010 I think you worry too much, this sort of thing you also think so much. Life must be very stressful for you. The best solution is to pump the cheapest grade so you won't lugi. How do you know the kampung chicken that Five Stars is selling is really from Kampung? How do you know that when you order Coke, the drink served to you is not Pepsi? I like your answer. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear May 2, 2010 Share May 2, 2010 Err... Wrong SG uses RON rating for petrol. Anyway, its impossible to tell whats the exact RON value of the petrol unless it sent to labs for analysis. For the rest of us, the only thing we can do is to look out for signs like detonation/pinging/knocking if our engines are highly tuned. If your car is tuned strictly for RON98 petrol, you will get knocking if you pump 95. yes. we and most of the world use Research Octane Number (RON). North America uses Road Octane Number (RdON) or Pump Octane Number (PON) Link to post Share on other sites More sharing options...
ER-3682 Supersonic May 2, 2010 Share May 2, 2010 normally when pumping at petrol station, you will just see the label at the pump and just fill up. so how do i know the RON98 that i am pumping is the actual RON 98 and not some lower grade fuel? S'pore petrol stations no worries,their H.Q. is very strict about this,hmmm,but for Malaysia,not so sure,the Shell V-Power sold there smell like 92 petrol of S'pore. Link to post Share on other sites More sharing options...
Speedz76 2nd Gear May 2, 2010 Share May 2, 2010 normally when pumping at petrol station, you will just see the label at the pump and just fill up. so how do i know the RON98 that i am pumping is the actual RON 98 and not some lower grade fuel? You won't know exactly, but I am quite sure you can feel the diff between pumping 95 and 98 when you drive.. 98 feels smoother compared to 95 Link to post Share on other sites More sharing options...
SimonTan 2nd Gear May 2, 2010 Share May 2, 2010 Very good question actually. Like someone says when the divery truck still got left over after filling up the 98 underground tank, they may pump into the 95 or 92 underground tanks. And not the other way round. But had you guys ever wonder what if they still got left over after filling up the 92ron fuel into the 92rkn underground tank? Throw the fuel away? Return back to refinary? Or truck driver secretly sell it to privateer in some shady deal? Or just pump into the 95 ron underground tank? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 2, 2010 Share May 2, 2010 I like your answer. Thanks. Actually I am not trying to diss him off. What I am trying to say is life here is too stressful liao. This kind of kuching kurap thing don't have to worry so much. There are a thousand more important things to worry about. As I said, best option is to pump 92 and who knows, they might have added 98 or 95 into the 92 storage tank! And please don't smell the petrol, I hope the bro that said it is kidding. Can cause cancer. Link to post Share on other sites More sharing options...
HOUSENUMBER Neutral Newbie May 2, 2010 Share May 2, 2010 yea it was meant as a joke.. since he so free to ask this Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 2, 2010 Share May 2, 2010 I know you are joking bro. It's the other bro who said V-power of Malaysia smells like 92 of Singapore. How does he knows?? ↡ Advertisement Link to post Share on other sites More sharing options...
How do you know you are in midlife crisis?
Where to mod fuel needle?
Anybody know what happened eventually?
