Rollagt 5th Gear May 28, 2008 Share May 28, 2008 Hi Folks, The power window motor on the driver side of my G9 had died.. Any kind souls can advice where can I find a replacement and the estimated cost. I understand if get original ones made in Japan will be very expensive hence looking at Altis power window motor which might be cheaper since its made in TomYam Land. ↡ Advertisement Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 28, 2008 Share May 28, 2008 Can try Fong Tat Link to post Share on other sites More sharing options...
Streetbumpkin Neutral Newbie May 28, 2008 Share May 28, 2008 Could it be jammed instead of being dead? Have you tried pressing the window down switch and at the same time giving your door a knock near the motor? Link to post Share on other sites More sharing options...
Cactus Clutched May 28, 2008 Share May 28, 2008 i tot ur dad got it fixed that time? Link to post Share on other sites More sharing options...
Rollagt 5th Gear May 28, 2008 Author Share May 28, 2008 He cant be bothered .LOL Link to post Share on other sites More sharing options...
Rollagt 5th Gear May 28, 2008 Author Share May 28, 2008 Its confirm dead coz I got try knocking and also try to "force" it down but cannot. Haiz.. Thou its wind up but still got to get it fixed otherwise quite troublesome when go to those carpark with no ERP parking system. Link to post Share on other sites More sharing options...
Rollagt 5th Gear May 28, 2008 Author Share May 28, 2008 Where is is located ? Specialised in Toyota parts ah ? Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 29, 2008 Share May 29, 2008 Bro, Fong Tat located at 355 & 357 Serangoon Road Tel: 62985333 They deal with a wide variety of parts from Toyota, Nissan, Honda, Mitsubishi ... Link to post Share on other sites More sharing options...
Sk67 Neutral Newbie May 29, 2008 Share May 29, 2008 I got a contact that repairs the power window for less then a hundred. Its not brand new, its repaired ones, change mine for 6 months already, still works. U can call up to enquire. mr tan 90069797. Link to post Share on other sites More sharing options...
Rollagt 5th Gear May 29, 2008 Author Share May 29, 2008 Wow ! Thks alot for the contact ! Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 29, 2008 Share May 29, 2008 Got website somemore...good luck! http://www.powerwindow9797.com Link to post Share on other sites More sharing options...
Sk67 Neutral Newbie May 30, 2008 Share May 30, 2008 hmm... i din expect mr Tan would put up a website... outstanding..... Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 30, 2008 Share May 30, 2008 Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear May 30, 2008 Share May 30, 2008 i got my Nissan lamps from Fong Tat at Kallang Way (Fong Tat Building).. are they the same people?? Link to post Share on other sites More sharing options...
Slowwalker Clutched May 30, 2008 Share May 30, 2008 (edited) i got it replaced at $25 each. Any workshop can do the job. If u need my workshop(Sinming), let me know. Edited May 30, 2008 by Slowwalker Link to post Share on other sites More sharing options...
B_goh88 1st Gear May 30, 2008 Share May 30, 2008 I'm having the same problem but mine is passenger side, so did care. In fact, problem surfaced during warrenty period and BM repaired for me free, but it came back just after 3.5 years. Slowwarker, appreciate you could pass me your workshop location and contact. I don't mind get it repair/replace if not too expensive. Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie June 3, 2008 Share June 3, 2008 any idea how much to fix power window? Link to post Share on other sites More sharing options...
Guest Zenoxnipaspmalvags Neutral Newbie January 24, 2019 Share January 24, 2019 Sposob awarii dysku twardego mowi nam, w jaki sposob zabrac sie za naprawe i ostatecznie jak zostana odzyskane jego dane. Jest wiele roznych technik naprawy uszkodzonego nosnika - np. zewnetrzny dysk twardy, ktory zostal upuszczony, klikajac wymaga zupelnie innej metody naprawy niz na przyklad dysk, na ktorym wystepuje awaria oprogramowania ukladowego. Uruchomienie dysku na potrzeby przywrcenia dostpu do danych i proces odzysku danych jest skomplikowany i czesto czasochlonny, dlatego powinien on zostac podjety tylko przez profesjonalna firme zajmujaca sie odzyskiwaniem danych, taka jak np. MiP Data & Forensic ↡ Advertisement Link to post Share on other sites More sharing options...
Envy motor director Ng Yu Zhi in hot soup
Window grill lock
Window grill lock
DIY W212 side mirror actuator replacement
Survey: Which is the best (claims) Motor Insurance company
Home power back up
Home power back up
Huge fire at Yong Sing Motor Works
