Blackmafia Neutral Newbie April 25, 2006 Share April 25, 2006 Hi all, could I check with you guys...has any of you faced "double vision" on the lighting at night after tinting your car? Wad's caused it? The quality of the film? ↡ Advertisement Link to post Share on other sites More sharing options...
Slee Neutral Newbie April 25, 2006 Share April 25, 2006 Double vision sounds quite bad ... how can you drive with double vision ? How long ago was the tinting done ? It normally takes a week for the film to cure and that's assuming everyday is a hot sunny day ... takes longer in current weather where it rains quite bad. For me, initially just 'wavy lines' at the rear with some halos and glare .. but over time, they 'disappear'. Be careful if double vision still exists ... Link to post Share on other sites More sharing options...
Kaer Neutral Newbie April 25, 2006 Share April 25, 2006 Mine had for a few weeks. Dun worry, it will clear up. At the meantime, just drive carefully. Link to post Share on other sites More sharing options...
Blackmafia Neutral Newbie April 25, 2006 Author Share April 25, 2006 I see...thanks guys. Tinting was done less than a week. I suppose I'll have to wait to see how it goes...wad do u think will be a good time frame? Link to post Share on other sites More sharing options...
Knight 1st Gear April 25, 2006 Share April 25, 2006 Bad workmanship or Poor quality of film or Time to have your lenses checked or Change the car Link to post Share on other sites More sharing options...
Konspire Neutral Newbie April 26, 2006 Share April 26, 2006 do u have this on all the sides that u tinted or only on ur windscreen? cos if all the sides, then ur tint film is not a good quality cos when they stick to the mirrors, the film will integrate with the mirror so that it become one. if only on the windscreen, then installation is not proper as our wndscreen is curved. the problem also will occure if u have more than one film on the mirror. it will create a correction like in lenses but since the correction cannot do a proper sphere or cylinder, double vision will occur...... for installation that's done more than a day or two, it shld already be considered cured with exceptions of a few bubles at the edge... Link to post Share on other sites More sharing options...
Edrollbrick Neutral Newbie April 26, 2006 Share April 26, 2006 Are you refering to blurred images? It is part of the film, adhesive & partly the curvature of windscreen when they need to heat shrink to fit. Skill of installer plays a part. Suspect the quality of the original film also will play a part. The reflected lines on the rear windscreen never did disappear for mine, they only become less prominent after drying out, but you can still see the "lighted" demister lines at night. Link to post Share on other sites More sharing options...
Kiatmobile 1st Gear April 26, 2006 Share April 26, 2006 (edited) I only knows that rear windscreen does occurs as this is due to the heater elements which derives from it. But what i notice is that mine has got reflective images on all the things(e.g : IU) reflected on the screen. Its really not use to it. Edited April 26, 2006 by Kiatmobile Link to post Share on other sites More sharing options...
Dazenconfused Neutral Newbie May 10, 2006 Share May 10, 2006 does thewindow tint come in same color as windcreen? i prefer black color. LTA compliant of couse Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie May 12, 2006 Share May 12, 2006 Are you seeing this only on the rear windscreen or all round? Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged May 12, 2006 Share May 12, 2006 (edited) Hi all, could I check with you guys...has any of you faced "double vision" on the lighting at night after tinting your car? Wad's caused it? The quality of the film? Wat brand of film?? the previous brand i used (Th***** Gu***) got this issue. The current film (3*) i use no problem. Believe not due to workmanship nor curing. Edited May 12, 2006 by Ody_2004 Link to post Share on other sites More sharing options...
Voxster Neutral Newbie May 17, 2006 Share May 17, 2006 I am looking for solar film for my Mazda3. My SE offered me a deal with Thermal Guard for $250. Any recommendations on which brand and model is value for money and good? tks Link to post Share on other sites More sharing options...
Jusnel 6th Gear May 17, 2006 Share May 17, 2006 Cool and Lite brand? heard few good comments from fellow MCFers abt this brand Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear May 17, 2006 Share May 17, 2006 (edited) Are you refering to blurred images? It is part of the film, adhesive & partly the curvature of windscreen when they need to heat shrink to fit. Skill of installer plays a part. Suspect the quality of the original film also will play a part. The reflected lines on the rear windscreen never did disappear for mine, they only become less prominent after drying out, but you can still see the "lighted" demister lines at night. hi all, I am having this problem too. I just installed it 2 days ago and having a little blur blur windscreen. My side windows are ok. Normally how long it take for the blur blur look to go away? Is it true that during this period the more we sun the car the film will tighten and the blur blur vision will go away? Edited May 17, 2006 by Roadhogger Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear May 17, 2006 Share May 17, 2006 do u have this on all the sides that u tinted or only on ur windscreen? cos if all the sides, then ur tint film is not a good quality cos when they stick to the mirrors, the film will integrate with the mirror so that it become one. if only on the windscreen, then installation is not proper as our wndscreen is curved. the problem also will occure if u have more than one film on the mirror. it will create a correction like in lenses but since the correction cannot do a proper sphere or cylinder, double vision will occur...... for installation that's done more than a day or two, it shld already be considered cured with exceptions of a few bubles at the edge... Hi, what do you mean by "for installation that's done more than a day or two, it shld already be considered cured with exceptions of a few bubles at the edge"? Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged May 17, 2006 Share May 17, 2006 How long u intend to drive yr car? For the dark look or really blocking of UV & IR? If short term (less than 3 yrs) n look go for affordable film like Th****** Gu***. Personally n from frens this film not that effective.. But if u serious n can stretch yr budget go for V****, 3* or H**** O***. Link to post Share on other sites More sharing options...
Wrc206 Neutral Newbie May 17, 2006 Share May 17, 2006 Guys, any feedback on 3M film? Thinking of installing soon. Thanks for any feedback. Link to post Share on other sites More sharing options...
Chogokin 1st Gear May 18, 2006 Share May 18, 2006 If got budget go for better ones. If not like me I choose coolnlite. Althought they are not the best product , but they at least their honour their words. Film got pro ?, they replace immediately no question ask. I went back 2 times for replacement and they did happily for me with no . ↡ Advertisement Link to post Share on other sites More sharing options...
NameWee complaining of Double standard.
3M Double Sided Tape and Car Body Coating
windows tinting...
windows tinting...
Vehicle Inspection Failed due to Tinting
Apple Vision Pro
Apple Vision Pro
Low sex drive be careful, expert warning : Double the risk of death
Penalty for parking at double yellow line
Double sided tape for door visor
