AVEO NOISY ENGINE noise
Car_man
Hi like to check with aveo owner does your engine sound very noisy like a diesel automobile and feel very rough engine running? My engine sound become like that after doing my 40k servicing and after i took out my resonator.Any solution to make the noise reduce and smoother? Pls Help
What's your oil that you are using. Most of us realize that using 10W30 and below will make the Aveo engine very quiet.
You got to be kidding ! The thinner the oil, the noiser the engine ! Common sense ! Diesel engine use thick oil, i.e. SAE80 or SAE 20W50 at least ! Thicker oil would increase pressure on hydraulic lift thus resulting in quieter engine but engine drag increase ( loss of power ) resulting in higher FC !
CBX
Nope. Diesel is inherently noisy and you can't compare with the petrol engines of ours. The Aveo guys are mostly using 10W30 and 5W30. The engine is very quiet below 3000RPM. Floor the throttle and the engine sounds angrier to the delight of many. wink.gif
i'm using mobil 5W50.Dunno y the engine sound so rough.Any way to make it smoother or is there any problem with engine
Swap out the Aveo engine with a V6 - sure quieter one. [;)]
Small engine, sure noisy one - it really depends on your own expectations. If you are used to a a 2.L Inline 6 or a V6, anything less...sure noisy..no matter how thick your engine oil lor..
HAHA if got money sure buy A higher CC car. My AVEO 40K Disc rotor warp,brake pad uneven and transmission leak.Ask Starsauto y so fast spoilt and they can't give me an answer but
subsidised all the repair after i complain to the manager.This Aveo give a lot of problem but what to expect cos the car is cheap
IS it true using 5W30 make the engine quieter?Smoother? If that the case next servicing i will change to that
Check with the rest of the Chevy guys who converted. It is smoother. The engine's tolerances and clearances are tighter and hence the reason why 30wt is good.
Try mobil 1 gold, 0w40, FC improve, feel it gives more power and most of all i felt engine is smoother and quieter.
Its still going to suck power out of a meagre 1.4L engine lah! 10W30 and below is the way to go. Right now, with 10k OCIs, M1 Gold is damn expensive for that kind of interval. With cxxxxxe and Schaeffer's selling 30wt oils so affordable, that's the way to go.
Please lah! Its just a damn car! It doesn't care if you give it cxxxxxe or Mobil 1, it only cares if there is enough oil to generate oil pressure! And no, Mobil 1 does not have a 30wt oil available. Just use whatever 30wt you can find be it cxxxxxe or Schaeffer's or RP.
