When Will You Change Your Tyres??
Nhrisuzu
41 members have voted
  1. 1.
    • when it is no longer in showroom condition.
      0
    • when it is punctured even when thread is <70%
      8
    • when it is dirty.
      1
    • when it is left with <70% thread.
      25
    • when it is left with 70-90% thread.
      7
Well if jap car to jap car shouldnt be a prob as the PCD is either 4x114.3 or 4x100. If you had one for a focus or renault etc then you might have an issue.
Anyway just check your tyres for what i said. generally most tyres have a heat cycles that allow them to last for roughly 2 years. I always play safe and change them every year. do note that softer compounds generally have lesser heat cycles but theaspec db's should be fine.
i think they may not be as sticky as before. braking dist may increase even with no change in threadwear. but i dun think it will be more prone to puncture.
based on bicycle tyres.. i never did this to car tyre.
but i do know tt my rear tyres which are damn old but have lots of thread have really shitty grip. rubber harden liao. for normal driving still ok but if i push the van on a wet day.. [dizzy][sly]
Twincharged
i only need them for normal day to day transportation to and from work as i suspect that my stock rubbers are contributing road noise to my daily trip....so want to try changing back to my Aspec DBs to see got improvement or not.
Twincharged
huh ??
the pic is from my old n16...... i changed to DBA Gold x-drilled n slotted rotors, for better braking.
Tyre makers say about 20K to 40K, some even claiming 50K.
But Tyres hardened within about 2 years from exposure to the elements. With an average of between 10K to 12K travel per year, not all will normally hit 40K in a year in Singapore less those whom are on the road for work every day and frequent NS travel.
Edited by Edrollbrick
brake disc with holes will have better braking??
sorry for my ignorance, i thought only bikes have holely brake disc.. [sweatdrop]
For me, I change when I can see that the tread is barely gone or smoothen... [laugh]
Edited by Ncss
I will change it when i get my car on the first day [nod][nod][nod]
Did the same thing, took the car, went straight to the tyre shop just 3Km away....to upgrade the rims... [;)] Within minutes! [:p]
A little friendly advice, I suggest you rotate your back tyres to the front if possible. In normal driving there's not much difference, but in emergencies your handling will be put to the test and if your back tyres are more worn than your front tyres, you could fishtail or spin. Especially in a van or other high CG vehicle, spin can lead to rollover.
http://www.michelin.co.uk/uk/auto/auto_cons_bib_pqr_neuf.jsp
Twincharged
nope......NA cars will not have x-drilled or slotted rotors.....these are usually avail on high performance cars or sold as aftermarket brake upgrade kits.
same logic as bikes, the holes and slits will provide more friction points to give better braking but at the same time, your pads will wera out faster also.
check out www.dba.com.au or www.brembo.com
GR 30 comes stock with Camry i think. The newer Camry comes with GR-80.
It's not entirely lousy. But it is more to comfort then performance.
yup...if i'm not wrong...its cos the discs can cool off better then normal discs....i had x drilled discs on my previous ride too....an opel astra 1.4m [:)]
in any case....i change my tyres when i change rims [laugh] ....which is technically about once every year or so....and i do rotate them once every service which is about anywhere from 10k to 20k of running.....
MIne i think that i have to drive from pandan loop to AMK to change. Hope that i can get a good price for trade in. Or else forget it man
Actually, solid disc gives the greatest braking torque followed by cross-drilled, then slotted.
Slots and Holes are for cooling, venting and cleaning of pads. It's like a compromise, so the rotors are usually larger too. Slots are considered best for track used because of crack resistance but is never found as standard on street cars because they have poor cold-wet bite. Cross-drilled are preferred straight out from the factory as they give decent cold-wet bite and yet provide cooling. Obviously, cold-wet bite is not an issue for track cars, so aftermarket rotors tend to be slotted.
Given a well maintained car with everything in order, brakes are a tiny determinant in braking distance because braking on a road car is limited by tire grip and never brake torque. Stock brakes will certainly over power any street tire's traction causing the wheel to lock up and ABS to intervene, so even if you have gigantic brakes, it's just going to cause lock up and ABS to come in. Big brakes are for better pedal feel and increased fade resistance.
[nod] Spot on... need to highlight one thing you said...
Thats one thing that most people don't realise.
Also the reason i go for tyres that have good wet and dry drip rather than something that has low noise. Better stopping power is always in my good books!!!
