Tazzy_72 Neutral Newbie August 2, 2006 Share August 2, 2006 Hi guys, Can someone recommend me a shop that has the computerised wheel alignment equipment? My Outlander is drifting to the left. Complained to C&C but all they did was pumped the tyres claiming the tyres were not properly inflated (duh! i had checked that already).. Even after the so called pumping the tyres, the car still drifts. I suspect that the alignment is out and if that is the case, my tyres are gonna wear off unevenly. So, I would be grateful if someone could help me with a shop that can perform the above job. Many thanks in advance. regards ↡ Advertisement Link to post Share on other sites More sharing options...
Jusnel 6th Gear August 2, 2006 Share August 2, 2006 i got 2 shops. Riverview - AMK People's Auto - Ubi But i think yrs is 4 wheel drive? better call them first b4 going down. i not sure they can do 4 wheel drive...... Link to post Share on other sites More sharing options...
Tazzy_72 Neutral Newbie August 2, 2006 Author Share August 2, 2006 Thanks Jusnel. Will check out their contacts and drop them a ring.. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear August 2, 2006 Share August 2, 2006 can try eng seng at amk autopt ground floor i love that machine Link to post Share on other sites More sharing options...
Xcalibur Neutral Newbie August 2, 2006 Share August 2, 2006 Hi Tazzy You can look for Mike Low from Kian Teong Auto Centre (Blk 176 Sin Ming Drive #01-08), at 6 455 6268. I been there b4 and they do provide computerized 4 wheel alignment. Hope it helps. xc Link to post Share on other sites More sharing options...
Lancer037 Neutral Newbie August 6, 2006 Share August 6, 2006 Hi, U can try Stamford. Their Price is reasonable. Link to post Share on other sites More sharing options...
Grunt72 Neutral Newbie August 11, 2006 Share August 11, 2006 Kenny from Riverview has moved to his own shop...guys who know his skill level can support him there. Just a few shops away on the other side of Riverview. Cheers Link to post Share on other sites More sharing options...
X_xxx_x Neutral Newbie August 13, 2006 Share August 13, 2006 bro u can check out stamford tyre...i think they charge 30 for 2 wheels and 60 for 4 wheels..not bad lor... Link to post Share on other sites More sharing options...
Picanto 3rd Gear August 13, 2006 Share August 13, 2006 the price of stamford tyre is a bit steep. try getting a quote from the other shops and see how it compares to stamford. Link to post Share on other sites More sharing options...
Mivec9 1st Gear August 13, 2006 Share August 13, 2006 the price u listed for stamford is for members.. Link to post Share on other sites More sharing options...
X_xxx_x Neutral Newbie August 14, 2006 Share August 14, 2006 hehehe...bro im a member....but i know this particular branch which can get alignment at the prices i mentioned...they r quite ok...agreed their prices quite steep but i would say their service is up to standard....at the end of the day its up 2 u if u wan 2 pay cheaper or pay slightly more for the service.... Link to post Share on other sites More sharing options...
X_xxx_x Neutral Newbie August 14, 2006 Share August 14, 2006 bro so far i have been servicing with them most times....i find though their prices are quite steep as u mentioned...their standard of service is quite good....i guess its a choice btw lower price and higher price but better service lor...tis is of course my two cents worth.... Link to post Share on other sites More sharing options...
Ixat 1st Gear August 15, 2006 Share August 15, 2006 Hi guys, I just had my alignment done after changing to lowering springs. Now the car veers right quite significantly and I have to counter with a 10deg left tilt on the steering wheel. Actually before the alignment it was alright, car was straight. Should I send back for re-alignment again? Link to post Share on other sites More sharing options...
Ronnie Neutral Newbie August 15, 2006 Share August 15, 2006 its a no-brainer isnt it? Send back for alignment la. Link to post Share on other sites More sharing options...
Vivioman Neutral Newbie August 15, 2006 Share August 15, 2006 Riverview at AMK Autopoint. Highly recommend them. Had my alignment done after I changed to lowered springs and bigger rims in my previous car. Very professional and I was very satisfied with the result. If anything is wrong with your alignment, they will be able to point that out to you. Cheers Link to post Share on other sites More sharing options...
Ixat 1st Gear August 17, 2006 Share August 17, 2006 Went back to Kenny to check my alignment. He said all within specs but veering to right is indeed a problem and could be due to having rotate my tires from back to front. Need to let it wear out evenly before the car will go straight again... Any advice? Link to post Share on other sites More sharing options...
King 1st Gear August 17, 2006 Share August 17, 2006 if u 1 2nd opinion, u can go to autocare at singmin first floor, look for mike from kian tong Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 17, 2006 Share August 17, 2006 Maybe u can try Creatiive Trdg @ #02-06 , No: 38 Woodlands Ind Pk. E1 Tel: 67601591/2. Ask for the boss, Jimmy. He's been doing my tyres, balancing & alignment (he has both types) for many years now. No complaints yet. ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Singpost courier dishonesty with incredibly lousy service
MOM help FTs look for jobs ?
