Need help for shop with computerised wheel alignment
Tazzy_72
Thanks for the enlightenment... [:)]
So usually at what mileage do we do such alignment? 10k with wheel rotation at the same time?
Yup. I wil do the 4 wheel balancing, rotation & normal alignment every 10K km.
Only if I change shocks or do any work on the suspension or steering wil I do the computerised alignment immediately after the work is done.
Sometimes I will do the computerised alignment after 20K km or 30K km even though I have not done any work on the suspension or steering components, just to make sure all is in order down there.
Ohhh.. so alignment and computerised alignment are different..
erm, normal alignment is how muchie and how is it done?
Yup. Like what Xtruan says, the mechanical type is u drive over 2 plates & they read how far off your alignment is. This is only the side-slip.
The computerised type, they put 4 sensors , 1 on each wheel & pass a laser tru the lens to see how far off the settings r.
This type can check your side-slip, castor & camber angles based on the programme inside the alignment computer. If the computer dosent have the settings for your car, it cannot check the accuracy.
The mechanical type is usually $20 for 2 wheels & the computerised 4 wheel type is $60 for all 4 wheels.
So in conclusion, 2wheels is good for normal 10K servicing and when we do rotation.
While 4 wheel computerised is good for maybe 20 or 40K time.
Assuming it's based on cost being an issue, otherwise we can do 4wheel every 10k?
Am I correct on that assumption? [:)]
Maybe u could approach C&C and ask them the recommended toe in/out,camber adjusting figure!
B4 u adjust to certain shop. If u regular to JB HAWK Tyres has the machine,much cheaper there
Very correct. [thumbsup]
To add: Computerised alignment sud also b done if u do any repair or work on the front or rear suspension or steering components as these wil affect your alignment too.
Good computerised tyre alignment equip have the settings of almost all cars already in their database. If it dosent have, find a shop which has it.
No point asking CNC. They might give u the wrong numbers (maybe even on purpose) or the tyre guy might not u'stand the numbers clearly.
My car is 17 years old & so far the 2 places I went to have the settings in their database.
Thanks for all the infor.
At least I know what to do liao..
Oh, another question: I heard about zeroing as well. How is that different from alignment?
Just a question, is it necessary to even do 4 wheel when the rear cannot be even adjusted? N do we need to do alignment during rotation? Or only when new or repair, accident etc?
Doing the 4 wheel alignment will let u know if something is wrong with your rear suspension set-up. U can then get it fixed.
I do the alignment every 10K km cos it does get knocked out when we go over bumps or hit the kerb. It's just a precaution to do every 10K km. If u dont do then it's up to u cos then the repair bill u will have to pay later.
Even if someone ask me if can dont change engine oil till 50K km? I just tell them it's not good but your wear wil b higher. That's all.
This maintenance is up to u if u want to follow the schedule in the owners handbook or not.
Yes, the best is to do high-speed alignment,bro!!!It will be more expensive but very accurate,bro!!!
I think u refering to "high speed balancing" for the tyres? Also known as "On-wheel balancing".
