Casshern Neutral Newbie October 18, 2006 Share October 18, 2006 (edited) anyway check out the fuse, having so many bulbs blown at one shot is not normal. possible that they blown out 1 by 1 but u din notice? den u see all 3 at the same time Edited October 18, 2006 by Casshern ↡ Advertisement Link to post Share on other sites More sharing options...
Nutty 4th Gear October 18, 2006 Share October 18, 2006 So your ride only left a single headlight and no brake lights? Fixed already or not? I better siam your ride at night. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 18, 2006 Share October 18, 2006 Maybe just do a check on the plugs where the bulbs plug in & see if anything wrong there. Maybe got rust or wires short or contact worn??? If all looks normal, change bulbs & monitor lor. If again blow, then something is definately wrong. My headlamps already abt 2 years old (Philips VP) & the brake bulbs so song I also forget how long. Link to post Share on other sites More sharing options...
Titanium 4th Gear October 18, 2006 Author Share October 18, 2006 My classmate told me last week that both brake lights blew, so i assume is the fuse since both SHOULD BE blew @ the same time, but last night i noticed 1 of the headlight also... :( Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 18, 2006 Share October 18, 2006 When was the last time u checked ALL your lights? If u never checked, then maybe they all blew at different times long ago. I check all my lights abt once a month & just b4 a long trip or Vicom inspection. This includes all signal, interior & boot light also. Link to post Share on other sites More sharing options...
Titanium 4th Gear October 18, 2006 Author Share October 18, 2006 Usually i only check "run light". Hahaha... Link to post Share on other sites More sharing options...
Apollo 1st Gear October 18, 2006 Share October 18, 2006 if ur ride already fitted with HID, doubt they will question you abt it. only thing is whether the ballast was faulty or damaged due to high vibration/ factory defects. Link to post Share on other sites More sharing options...
Fortress Clutched October 18, 2006 Share October 18, 2006 First check the fuse(unlikely), if so, then is a concern, as the is a short in the circuit. 3 bulbs blowing at the same time could be due to aging Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 18, 2006 Share October 18, 2006 Replace the brake light and apply brake - if the bulb blow , chances the brake light switch is faulty or the bulb socket/ hardness is corrosed/ grounded. Link to post Share on other sites More sharing options...
Titanium 4th Gear October 19, 2006 Author Share October 19, 2006 I plug out n plug back the brake light, now ok liao... Only the headlight is cfm blown... ;) Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 19, 2006 Share October 19, 2006 Ok good, check the headlight fuse, it's the recommded size. Link to post Share on other sites More sharing options...
Wheeler Neutral Newbie October 22, 2006 Share October 22, 2006 (edited) Ignis brake light fuse easily... but sometime when u unplug and plug back, u notice it works again. When u observe the double coil bulb, check if any of the coil in the bulb unit has fused, if not plug it back and see if it works again. I notice Ignis brake has got frequent tendency of this happening. Edited October 22, 2006 by Wheeler ↡ Advertisement Link to post Share on other sites More sharing options...
Are LED lights subject to brightness checks?
Brake Pads
Brake Pads
2009 hyundai avante HD
Brake squeak every morning
Car travelling without headlight on
Brighter headlights needed
