Skylander Neutral Newbie January 12, 2007 Share January 12, 2007 Noticed that when i start my car, there's this noise which sounds like screeching. Even worse when i turn on my air conditioner. The noise is like those you always hear in buses and lorries when they start to move off in stationary position. Maybe due to the timing belt? Anyone hear can shed some light? FYI my car close to 100k mileage already. Going to do servicing next week. ↡ Advertisement Link to post Share on other sites More sharing options...
Quantum 5th Gear January 12, 2007 Share January 12, 2007 must let us know what car it is Link to post Share on other sites More sharing options...
Skylander Neutral Newbie January 12, 2007 Author Share January 12, 2007 oh so sorry. Its the mit lancer 2003 1.5 GDI. I think its the cs2 version. Link to post Share on other sites More sharing options...
Jho0001 Neutral Newbie January 12, 2007 Share January 12, 2007 sounds like your fan belt is slipping. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 12, 2007 Share January 12, 2007 The belt is slipping. Common on any car based on Mistubishi technology. Hyundais suffer from this as well since their engine tech was based on Mitsubishi. Link to post Share on other sites More sharing options...
Ivan96935sg Neutral Newbie January 12, 2007 Share January 12, 2007 seems like fan belt that is giving the noise...... Link to post Share on other sites More sharing options...
Ccssgm 1st Gear January 13, 2007 Share January 13, 2007 Air Con Belt Loose........also hav tis sound...... Timing Belt No Sound No Signal .......One......If Broken.....U Siow Liow.... Link to post Share on other sites More sharing options...
Skylander Neutral Newbie January 13, 2007 Author Share January 13, 2007 Thanks to all bros for the advice. Was having problems with my air con as well, mouldy smell coming through the vents. Read the forums here and guessing that the filter may be mouldy. Maybe need to change air con belt as well. Maybe because of rainy season? Went around paya lebar (behind sing post) and ubi area to check out prices for servicing. Was quoted approx $400 for changing almost everything, saying my 4 yr old car about time already. Dono if true or just want to earn my $$$. normal servicing also cost about $180. first reaction wah so ex ah..... din know do air con can cost so much.... anyway read through the forums here that markcool service good and reliable, but a bit far.... anyway bro got good shops around the area to recommend? Link to post Share on other sites More sharing options...
Ccssgm 1st Gear January 13, 2007 Share January 13, 2007 Repair Air Con.........Can Cost up to More than $1000........Interior Coil Cost a few Hundred.....Compressor......... Link to post Share on other sites More sharing options...
Dumb 4th Gear January 13, 2007 Share January 13, 2007 Can consider changing car liao instead of paying for 100k servicing, belting, air-con etc. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Intermittent rattling noise, car in ICU
