Dennisk Clutched June 25, 2007 Share June 25, 2007 (edited) Q1. recently i open my bonnet and saw the coolant level only left 2-3cm of coolant level. coolant stain was all over the reservoir cap. i send to my workshop and realised that air con fan is not working at all. The temperature overheated. i have been driving quite sometime, maybe a week with over normal temperature. is my engine hurt in anyway? after replacing the motor fan, i topped up the reservior with distilled water. Q2. yesterday i opened my bonnet and i saw the coolant reservoir is almost empty again. what could have happen? advise??? Edited June 25, 2007 by Dennisk ↡ Advertisement Link to post Share on other sites More sharing options...
Fuxion Neutral Newbie June 25, 2007 Share June 25, 2007 you may want to bring it back to the workshop to check the water pipe in the car... cause it happen to me once before that the rubber pipe is leaking... but mine was a van in the past.. Link to post Share on other sites More sharing options...
Legendary Clutched June 25, 2007 Share June 25, 2007 Sounds serious ... better get it checked up ASAP Link to post Share on other sites More sharing options...
Blackbird749 Neutral Newbie June 25, 2007 Share June 25, 2007 It should be some leaking somewhere along the coolant piping. check underneath your car before u drive out in the morning to check any water/coolant on the floor.Get the mechanic to flush and change your coolant at the same time. Can get cheap coolant at spare parts shop in Veerasamy Road and then ask your mechanic to change for u.No point putting distilled water. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged June 25, 2007 Share June 25, 2007 (edited) it could be: 1. Coolent hose leaking (wear & tear, its made of rubber) 2. coolent clip that is securing the hose is loose. you mentioned that the coolent was all over the coolent cap? how old is yr car? if your car is relatively aged, another possible reason is that the existing coolent cap (Radiator cap)cannot withstand the increased pressure from an older radiator. Try to change a radiator cap that has a higher pressure rating than yr existing ones.. example yr existing is 0.9, change to a 1.0. u should be able to see the rating on the cap. CAUTION... dun touch the cap or try to open it when engine is hot! i try this stunt once on my friend's old car when overheat... the cap fly out and all the coolent gush out a few METRES! luckily my reflexes fast enough to avoid the hot liquid! go back to your usual trusted workshop, they should be able to solve it. u can ask them to do a pressure test to test its really leaking. shouldnt be too much of a problem. Edited June 25, 2007 by Chucky2007 Link to post Share on other sites More sharing options...
Dennisk Clutched June 26, 2007 Author Share June 26, 2007 i mean is the coolant reservior not the radiator cap. my car is about 6 year old now... Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 26, 2007 Share June 26, 2007 it seems that you have more than one problem. fan motor was one and has been resolved. The next is check whether any leakage. And also check when car is cooled on the radiator..any fountain or such. is the coolant moving when start car....to know whether the water pump and temp valve working Link to post Share on other sites More sharing options...
Dennisk Clutched June 26, 2007 Author Share June 26, 2007 what do you mean fountain? Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 26, 2007 Share June 26, 2007 best is when car totally cool down, check that on car, and the water pump/temp valve moves the coolant. if the coolant gets overfill and "vomit" out from opening it could be due to head gasket needs replacement if car is hot (u have been driving) and u see same symptoms + u only see high temp when u drive more 120km/hr, this could be choked radiator (needs cleaning, not flush) Link to post Share on other sites More sharing options...
Vtim 3rd Gear June 27, 2007 Share June 27, 2007 there is a spring and rubber sealant inside the radiator cap, the spring could be weak or the rubber sealant wear off, this will cause the radiator cap not to be able to work according to it's designed pressure it can hold on to, hot steam/air will be force out of the radiator cap so it's better that you check and replace if necessary, it's not very expensive but do get the one that's having the correct PSI for you engine, stock replacement ones from the stockists will never go wrong Link to post Share on other sites More sharing options...
Smiley Neutral Newbie June 27, 2007 Share June 27, 2007 likely to be leaking some where. cannot be drying up so fast, especially when you hv already changed your fan. Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 27, 2007 Share June 27, 2007 Go for a pressure test and you will know whether the radiator cap is faulty or the cooling system is leaking PS This how a cooling system and cap pressure tester looks like Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 27, 2007 Share June 27, 2007 like what Vtim and yeobh have mentioned, it could also be due to the radiator cap. I have the leaking problem when I change my radiator cap the other time. Then realised that it was the cap the causes the leak. Link to post Share on other sites More sharing options...
Dennisk Clutched September 29, 2007 Author Share September 29, 2007 it seems that you have more than one problem. fan motor was one and has been resolved. The next is check whether any leakage. And also check when car is cooled on the radiator..any fountain or such. is the coolant moving when start car....to know whether the water pump and temp valve working i have gone to workshop to check twice, there isn't any leakage from the hose. but there are evidence that there are coolant vomiting out from the reservoir cap "small straw". is it due to over heating, raditor fan weak, radiator choke or....? last time i know that i don't really need to top up my coolant for months. but now every 3-4 weeks it will dry up almost the whole reservoir reserves. Link to post Share on other sites More sharing options...
Dennisk Clutched September 29, 2007 Author Share September 29, 2007 (edited) the workshop did for me the test. it seems perfectly ok even they try to increase the pumping... currently i am monitoring my temperature using gauges because i broke the stock one while changing the dial. i realise that the temperature will shoot higher than 100'c if i drive RHF style and also above 110km/h Edited September 29, 2007 by Dennisk Link to post Share on other sites More sharing options...
Kianbeng Clutched September 29, 2007 Share September 29, 2007 If done pressure leak test and ok, then I guess your radiator is choked. Choked radiator can cause pressure to build up, and your coolant cap will overflow. end up your coolant will not be enough. Whats your mileage like? How long ago did you change your coolant? Did you ever top up coolant using any coolant? Or just water so far? Link to post Share on other sites More sharing options...
Yeobh 4th Gear September 29, 2007 Share September 29, 2007 (edited) Cooling system is a pressurised system - the whole idea is to allow the coolant to boil at higher temp.With this arrangement the coolant system need only min volume of water to cool the engine.If the engine is running @ operating temp, the water pressure will rise and up to a point the cap release valve with open and allows the excess superheat water and pressure to escape into the overflow bottle.Most of the stock pressure cap is rated @ 0.9kg/cm2 for Jap and 1 kg/cm2 for European cars. Once the engine cool down to ambient temp , the cooling system coolant will contract thereby creating vaccum in the system. The vacuum of negative pressure will suck the coolant from the overflow bottle back into the cooling system. Ask the mech to check the coolant system for air bubbles or oil stain when the engine is running at operating temp. The best way is to do a leak down test ( a process of actually introducing compressed air into the cylinder -)- to confirm that the cylinder heat gasket is ok and there is not internal leak in cylinder head or engine block. PS photo shows a leak down tester kit Edited September 29, 2007 by Yeobh Link to post Share on other sites More sharing options...
Whatefish Neutral Newbie September 29, 2007 Share September 29, 2007 Maybe you should try another wksp. Get another opinion and expertise. There are many hoses/pipes connected to the cooling system. Some cracks/leaks can't be seen by the naked eyes. Then there are the water pump for leak. How abt the cylinder head core plugs. ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
Coolant question
Coolant question
Citroen C4 1.2 Sensor & Display
