Shibadog Turbocharged December 9, 2016 Share December 9, 2016 Yeah I heard that too... so what would you recommend me to do? Use 225/40 r18 all around or stagger? rear-wheel drive? it's designed to have bigger (wider) tyres at the back. if I were u, I would use 225/40/18 front and 245/35/18 (or wider, if fits) rear ↡ Advertisement Link to post Share on other sites More sharing options...
jaspal81 Clutched December 9, 2016 Share December 9, 2016 rear-wheel drive? it's designed to have bigger (wider) tyres at the back. if I were u, I would use 225/40/18 front and 245/35/18 (or wider, if fits) rear Thanks. Another quick qs... the shop I wanted to go to said their rims are not staggered but they can use staggered tyres. Doesn't make sense does it? I should be using staggered rims too right? Really appreciate the help and advise. Link to post Share on other sites More sharing options...
Shibadog Turbocharged December 9, 2016 Share December 9, 2016 (edited) Thanks. Another quick qs... the shop I wanted to go to said their rims are not staggered but they can use staggered tyres. Doesn't make sense does it? I should be using staggered rims too right? Really appreciate the help and advise. staggered rims will better as the tyres are better seated (assuming rims are correct width). As mentioned abv, do also check offset. add: your owner's manual may have the full rim and wheel specs. Or chk bmw forums Edited December 9, 2016 by JohnSHL Link to post Share on other sites More sharing options...
jaspal81 Clutched December 9, 2016 Share December 9, 2016 staggered rims will better as the tyres are better seated (assuming rims are correct width). As mentioned abv, do also check offset. add: your owner's manual may have the full rim and wheel specs. Or chk bmw forums What offset do I need? Link to post Share on other sites More sharing options...
Shibadog Turbocharged December 9, 2016 Share December 9, 2016 What offset do I need? I don't know. it's usually car specific try here http://www.wheel-size.com/size/bmw/1-series/ Link to post Share on other sites More sharing options...
jaspal81 Clutched December 10, 2016 Share December 10, 2016 thanks for sharing i believe your current ride rim diff width for front and rear (same for your tires size too) beware of putting same size 225/45/17 on your current rim, some WS don't know the rim diff btw f and r it is OK to have all 4 same size for 18inch rim and tire size 225/40/18 Hi, I checked with the tire shop today. They do not have staggered rims so I figured maybe I just do a non staggered set up of 225/40/18. Any implications in the long run? Will my suspension be affected? I am not familiar with what the downside will be by using the same set up throughout. Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 12, 2016 Share December 12, 2016 After speaking to another tyre shop, I have decided not to upgrade rims. Stick to stock rims, 17". Anyone knows if Goodyear Excellence run flat tyres are good? Tyrepac is having a great price for it for my size. Thinking if I should go for it. Link to post Share on other sites More sharing options...
Beregond Supersonic December 12, 2016 Share December 12, 2016 After speaking to another tyre shop, I have decided not to upgrade rims. Stick to stock rims, 17". Anyone knows if Goodyear Excellence run flat tyres are good? Tyrepac is having a great price for it for my size. Thinking if I should go for it. excellence rft is 1 if the orginal for BMW. but abit noisy, check out their nct 5 or efficentgrip rft, same from good year, more quiet. Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 12, 2016 Share December 12, 2016 After speaking to another tyre shop, I have decided not to upgrade rims. Stick to stock rims, 17". Anyone knows if Goodyear Excellence run flat tyres are good? Tyrepac is having a great price for it for my size. Thinking if I should go for it. Rather than RFT, you always can switch to Non-RFT. Juz buy Slime Tyre Repair kit loh. I have been using PSS Non-RFT for almost 1 year. I even drive into Malaysia. Anyway, I only believe in Michelin. Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 13, 2016 Share December 13, 2016 After speaking to another tyre shop, I have decided not to upgrade rims. Stick to stock rims, 17". Anyone knows if Goodyear Excellence run flat tyres are good? Tyrepac is having a great price for it for my size. Thinking if I should go for it. good moved stick to staggered size is best otherwise all 4 x 205/50/17 MHO 1 Link to post Share on other sites More sharing options...
Piyopico Supercharged December 14, 2016 Share December 14, 2016 more comfort and quiet ride fc no diff yes the monitoring system will still work with non run flat but u need to reset everytime u pump air just get non run flat, i cant wait to change my current run flat tyre, too stiff ald lol You driving a Mercedes right. How come must reset every time you pump air? The merc tyre monitoring system is auto right? I never reset before after pumping my types. 1 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic December 15, 2016 Share December 15, 2016 You driving a Mercedes right. How come must reset every time you pump air? The merc tyre monitoring system is auto right? I never reset before after pumping my types. I driving bm The idrive system on their handbook did mention to initialize tyre pressure after correcting even after changing tyre. So now i did that every time i pump air. I am not sure about merc auto anot but last time my e250 right rear completely flat but the system never pop out and indicator/warning about it when i drive, suddenly feel car getting heavy and go down check, almost travel on rim lol Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 15, 2016 Share December 15, 2016 I driving bm The idrive system on their handbook did mention to initialize tyre pressure after correcting even after changing tyre. So now i did that every time i pump air. I am not sure about merc auto anot but last time my e250 right rear completely flat but the system never pop out and indicator/warning about it when i drive, suddenly feel car getting heavy and go down check, almost travel on rim lol Same for my A6. Must recalibrate after pumping air. 1 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic December 15, 2016 Share December 15, 2016 Same for my A6. Must recalibrate after pumping air.I think for better accuracy hence must set again to let vehicle know tyre just get pumped. Otherwise they will only detect sudden loss of pressure or worse cannot detectJust like my e class last time, i nvr intialize Link to post Share on other sites More sharing options...
Piyopico Supercharged December 15, 2016 Share December 15, 2016 Looks like I better go find out if I need to reset after pumping. Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 15, 2016 Share December 15, 2016 The A6 is using indirect TPMS, I would if it will be able to detect if running on run flat tyres??? Thou wiki say able to detect. https://en.wikipedia.org/wiki/Tire-pressure_monitoring_system Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 16, 2016 Share December 16, 2016 let me share my basic knowledge about TPMS ,correct me if I am wrong please. it is getting little common new car equipped with TPMS (is being around for at least 1 decade ) let start car BMW ( esti 10 years ago) fitted with run flat tires and is a must to have this gadget help to monitor tires pressure while driving, Why : because no one is able to tell should the run flat tire punctured from the outside look, it is very dangerous to run a punctured at high speed and long distance (tires may failed and explode to be exaggerated ) BMW car mostly uses ABS base sensor to monitor your wheels revolution and stored the value in CPU , and should any of the tires pressure drop(little bit drop also can activate ) , CPU detected it because the REV increased ,so CPU will alert driver by MSg tire pressure check or bla bla bla) My understanding the Newer version BMW TPMS will tells you exactly which tire pressure lost . old model Mercedes/ Audi also equipped with same typre of TPMS like BMW. back to work now shall continue my sharing about Sensor base TPMS later welcome ? Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 19, 2016 Share December 19, 2016 Was quoted a very good price for Pirelli Cinturato P7 run flats. Currently on Michelin Primacy 3 ST. Would the P7 be upgrade or downgrade? ↡ Advertisement Link to post Share on other sites More sharing options...
Michelin Primacy 5 Energy
Pirelli P Zero PZ5
Pirelli P Zero PZ5
Petlas Or Giti?
Petlas Or Giti?
Hdb flat renovation
Hdb flat renovation
