Texas5 1st Gear January 14, 2008 Share January 14, 2008 now my sound problem solve liao after change of my old amps & get some proper grounding done thanks to all helps here & my installer with proper setup as well. ↡ Advertisement Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 14, 2008 Author Share January 14, 2008 what amp did you get? Link to post Share on other sites More sharing options...
Texas5 1st Gear January 14, 2008 Share January 14, 2008 Pegasus, its a not very popular amp on local market but i can say its quite a decent clean amp. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 14, 2008 Author Share January 14, 2008 how many channel and what is the power rating like? Link to post Share on other sites More sharing options...
Texas5 1st Gear January 14, 2008 Share January 14, 2008 here the specs... Power Rating : 4 ohm Stereo: 50W X 4, 2 ohm Stereo: 75W X 4, 4 ohm Mono: 150W X 2 Frequency Response : 10 - 30K Hz +/- 3 dB Sensitivity : 140mV - 4V Impedance : 20K Ohm S/N Ration : > 100 dB T/H : 0.1% Power Fuse : 25A X 2 Dimension : 260MM WX 55MM HX 350MM L Master Pack Quantity : 6 Sets / Carton Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear January 14, 2008 Share January 14, 2008 (edited) My ride now has similar issue like yours after sending my ride for a free engine mounting claim from MM Both the front 'Left' & 'Right' speakers cum tweeter siao siao one ... Sometime 1 side got sound, sometimes the other other side and this morning, both side bo sound for a couple of mins before it is back to normal ..... But now, it is functioning back to normal again I hope it's not something which is 'Bo Ho Say' again Edited January 14, 2008 by Mzrmazda3 Link to post Share on other sites More sharing options...
Blue2 1st Gear January 14, 2008 Share January 14, 2008 u cum too much till your ice also got problem liao lor Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear January 14, 2008 Share January 14, 2008 I cannot cum or do hanky panky inside my ride cos got a statue of a goddess Link to post Share on other sites More sharing options...
Gtti Neutral Newbie January 14, 2008 Share January 14, 2008 Bro, u can try to isolate the channels. method1 Eg. swap front ch RCAs to go into rear channel amp, & rear ch RCAs to go into front channel amp instead, if problem still occurs on your front speakers, root cause lies in ur amp(side). if problem become rear speakers, root cause is the RCAs.. method2 If aft trying above & problem still persist, u can try swapping speaker cables in the similar theory oso... Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 14, 2008 Author Share January 14, 2008 did yuo check whether the 50W x 4 is it measured in pmpo or rms? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 14, 2008 Author Share January 14, 2008 I have used my colleague's spare HU to test for a few days (same HU model as mine), still have the same problem. When I went to JL Sim Lim to rectify, I didn't have the problem. So, the guys told me to try to swop the RCA cables for the front and rear. Yet to have the time to do it. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 14, 2008 Author Share January 14, 2008 thanks bro, that's what the installer advised. Will try it when I have the time. Link to post Share on other sites More sharing options...
Gtti Neutral Newbie January 14, 2008 Share January 14, 2008 no prob..good luck.... Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear January 14, 2008 Share January 14, 2008 Hopefully you'll get yours solved soon while mine 'Bo Dai Chi' after tighting all the connections again jus now Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 14, 2008 Author Share January 14, 2008 Bro, u can try to isolate the channels. method1 Eg. swap front ch RCAs to go into rear channel amp, & rear ch RCAs to go into front channel amp instead, if problem still occurs on your front speakers, root cause lies in ur amp(side). if problem become rear speakers, root cause is the RCAs.. method2 If aft trying above & problem still persist, u can try swapping speaker cables in the similar theory oso... One more thing, the funny thing I notice is, when the sound went 'off' on one side, if I hit on the amp, the sound is back to normal.... could this be a tell sign? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 14, 2008 Author Share January 14, 2008 I hope the problem is with the Rca, which is the cheapers.. Link to post Share on other sites More sharing options...
Gtti Neutral Newbie January 14, 2008 Share January 14, 2008 hopefully, it's the RCA connected to it lor..affected by ur vibration knock.. if u really got time, check out the stability of the 12V & GND at amp side lor...(worst case).. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear January 14, 2008 Share January 14, 2008 (edited) Good luck to you & also to myself .... Edited January 14, 2008 by Mzrmazda3 ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Audio Shop Recommendation
Dealer re-sell problem car
I need a soundbar for my Prism+ TV, spillover of 11.11 damage
