Sdexxxxd 2nd Gear March 9, 2008 Share March 9, 2008 Bought a A1Pro wireless mouse. Bring home and charged it, but immediately cannot work. Just to check with bros here whether there is any CD software installer disk to get it working? thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Apollo 1st Gear March 9, 2008 Share March 9, 2008 sud hv mah... is ur Pc detecting it as a new device? Link to post Share on other sites More sharing options...
Bearbear1494 Clutched March 9, 2008 Share March 9, 2008 Check if there're any buttons on the mouse itself and the receiver. Press each button once & they should sync up. Or check for frequency channel switches. Make sure both receiver & mouse set to same freq channel. If still cannot, or no switch/buttons, then go back & ask for exchange. Usually software not required to use wireless mouse, unless it's to customise the button functions. Link to post Share on other sites More sharing options...
David Clutched March 9, 2008 Share March 9, 2008 1) Please check if battery in place correctly. 2) Please check if you have plug in the USB-interfaced reciever/trasmitter that c/w your mouse. You need to plug this to the PC you are working with. 3) The cd, if any, is for additional sw like special function for the mouse. Even if you have not install the cd, the mouse basic function should work. 4) These days, Window XP/Vista would have easily detected your new device and make it workable. 5) If all above are satisfied, then its most likely your mouse is kaput! Link to post Share on other sites More sharing options...
Comfy 1st Gear March 9, 2008 Share March 9, 2008 funny ley u... instead of asking the vendor this kinda question, u chose to ask here... Link to post Share on other sites More sharing options...
Friendstar Supercharged March 10, 2008 Share March 10, 2008 Did u plug correctly into the usb port? some cockster may plug into the ethernet port Link to post Share on other sites More sharing options...
Rickster 5th Gear March 10, 2008 Share March 10, 2008 If he can plug it into the ethernet port then most likely the ethernet port kaput liao Link to post Share on other sites More sharing options...
Watwheels Supersonic March 10, 2008 Share March 10, 2008 Are u using Vista? Is the product Vista friendly? Link to post Share on other sites More sharing options...
Zniper 2nd Gear March 10, 2008 Share March 10, 2008 no la, wun kaput de... juz tat the hole of the ethernet port expand horizontally by a bit only... i doubt TS will pluck into ethernet port instead of USB port... Link to post Share on other sites More sharing options...
Caaa Clutched March 10, 2008 Share March 10, 2008 was using a same one previously. There is a button on the bottom of the mouse, and also a button on the tip of the transmitter (the one that you slot into your laptop/pc via USB port). Press both button together and it should work. This A1 wireless mouse dun come with installation disc....as far as my piece is concern....hope the above helps. Good Luck! Bought a A1Pro wireless mouse. Bring home and charged it, but immediately cannot work. Just to check with bros here whether there is any CD software installer disk to get it working? thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Singpost courier dishonesty with incredibly lousy service
Feedback
Feedback
Wireless carplay anyone
