Replacing coolant
Rskeisuke
Nowadays got so many different types of coolant meant for so many different types of cars. They cannot & sud not b mixed or changed around.
When in doubt, check the car's owner manual. It will say what is acceptable for the car.
If you just want to cool the engine, distilled water is enough. If you want protection, then mix a little anti-freeze. In our weather, 30% is sufficient.
OK thanks. [wave]
genie wat do u think of redline water wetter? the one in pinkish colour?
it say pour i whole bottle and fill up with water will do.
Stick to your manual's recommendation and get your coolant from reputable shop.
Thanks alot. Coolant is reputable leh.. prestone.. [:/]
My advice is not to get American coolant, I remember they may be formulated differently and MAY contain silicates which are bad for Japanese gastkets. Also I had bad experience using American coolant, NTUC used to sell the TURBO brand coolant very cheaply and it says made in U.S.A, but the can of coolant already contains rust sediments. I tried twice and encountered the same problem, you noticed it when you pour slowly and at the end you see the sediments. I told my colleaque, he doesnt believe me at first, until he save the excess coolant into a plastic bottle, and he can see it too.
The Prestone bottles are plastic. I didn't see any sediments of tat sort when i pour. Only after i open my radiator cap!!
Need to flush liao just to be safe.
most petrol station sells coolant. got 2 main types, no need mix with water (pre-mix) & those that need to mix water. if u want to use a new coolant, its better to flush and top up with new coolant. dun mix 2 different types together
i just bought a 4L can of pre-mixed Mitsubishi Super Long Life Coolant ($15) from Min Ghee for my Cerato V2. Think it's safe to use on my car? According to the sales rep, it's green in colour. My original coolant also green... [confused]
Yes, it is okay, you got it quite cheap too. All japanese car manufacturers use similar coolant but different dyes Honda Blue, Toyota Red, Nissan and Mitsubishi Green.
I'm also using WW. Bought about 7litres of Watson's distilled water to go with the WW. Wouldn't dare to use tap water.
Noticed that the engine temperature could rise to running temperature faster compared to the normal coolant + anti-freeze/anti-boil.
Just get a bottle of REDLINE water wetter. Flush out the entire radiator + engine passage ways and pour in the whole bottle. Top up with clean tap water, thats all.
Maximum cooling and very little water loss. Much better than any glycol based coolant.
Reason :
1) Glycol is an anti-freeze, anti-coagulant, anti-rust, anti-mineral fluid (thats alot of antis laugh.gif )
2) Dye colour is to allow vehicle users to quickly identify coolant leaks, it has no other function.
3) Any other coolant is of course fine.
4) Since most car engines on the roads today are aluminium alloy casted, you don't need the anti-rust or anti-freeze properties.
thanks i did read thru. unfortunately, both my owner's manual and the mitsubishi coolant packinging won't as specific and detailed.
both only vaguely mentioned, "EG-based for aluminum radiator", nothing on silicates whatsoever.
anyway, coolant was changed today and i'm keeping my fingers crossed. [sweatdrop]
Edited by Rskeisuke
bought coolant from song yi for avante, the person sold me turbo brand coolant, s--t... dunno whether it is silicate free? Anyone know?
this is what ur WS tell u??
u better be careful..... the color is not just for coloring ..beside that.. they are coolant and antifreeze...
the coolant and antifreeze help to bring up the boil temperature and also the freezing temperature (this one no concern to us here)...
u better be careful that at the end of the day.. ur car will end up running on 100% water....
in this region.. i think must coolant are mix at 30/70 (30% coolant and 70% water)...
European brand coolants are normally with silicate. For Asian cars keep to those brands from Japanor Korea. EG = ethylene glycol. Best mixture for our sunny island climate is 50 /50 mixture.
my mechanic recommended not to use
stick to the original coolant for kia/hyundai
Check your car manual to see what type of coolant is required.
