Mouse Neutral Newbie May 6, 2008 Share May 6, 2008 (edited) Hi, did a search and can't seem to find anything on it. I am looking for a portable Air compressor to pump my tires. Does anyone has one to recommend? Would appreciate if you could list the brand name,price n location of where you brought it. is it practical to use such portable compressor or is it better to go queue up at Petrol kiosk to pump? (Quite sick of going to kiosk to pump air cos a) at times have to queue up for quite long b) some of the kiosk pump are faulty) Thank you. Edited May 6, 2008 by Mouse ↡ Advertisement Link to post Share on other sites More sharing options...
Incom 1st Gear May 6, 2008 Share May 6, 2008 (edited) There is one brand which is from a company in Singapore, it is on sale in Autobacs and Homely. Suggest you go down to Homely to take a look. http://www.homely.com.sg/ I bought 1 which is another brand from Autobacs. So far so good, no complains about it as i am quite sick of going petrol stations to pump air. I check my tire pressure once a week, so the portable air compressor is useful to me. Hope this information helps. Cheers Edited May 6, 2008 by Incom Link to post Share on other sites More sharing options...
Apollo 1st Gear May 6, 2008 Share May 6, 2008 wait for unker yeobh Link to post Share on other sites More sharing options...
Mouse Neutral Newbie May 6, 2008 Author Share May 6, 2008 Thanks..any idea how much u paid for yours? I was told by some friends that those portable ones are kinda of useless. Link to post Share on other sites More sharing options...
BoneStock 5th Gear May 6, 2008 Share May 6, 2008 i've been using one for the past 5 years or so. Bought at homefix DIY for about 30+. Definitely worth the money. Petrol kiosk got many inconsiderate people who parked their cars at the lot designated for tire pump....so i prefer to do it at my MSCP. Link to post Share on other sites More sharing options...
West_end Neutral Newbie May 6, 2008 Share May 6, 2008 $30+ is surely a worthy purchase. It is also very useful when one encounter a punctured tire and need to pump up it before driving the car off to a nearest tire repair shop. Past experience taught me that moving a car with a deflated tire would dragged it against the road which in turn may cause the tire' rubber wall to tear and rendered unsafe for use. Replacing a tire cost about... $80 ?, while "plugging" a spot leak is $5. Link to post Share on other sites More sharing options...
Ultramega 1st Gear May 6, 2008 Share May 6, 2008 Home-Fix at Marina Sq has quite a few models ranging from $30+ to 100+. Link to post Share on other sites More sharing options...
Mouse Neutral Newbie May 6, 2008 Author Share May 6, 2008 Thanks...probably will go n hunt for it during the weekend. will report back here if i mgd to find any good ones. Link to post Share on other sites More sharing options...
Kklee 6th Gear May 7, 2008 Share May 7, 2008 (edited) Mustafa 4th level, Mini Compressor (pressure up to 250) @ $16.90. Bought one but have yet to use it. Gauge accuracy - unknown. Skimmed thru the user leaflet, seems that it takes quite a while to pump. In addition, you might need to get a pressure gauge. Do note that pressure gauges might not be calibrated. E.g if you measure 245, it might be only 230. Edited May 7, 2008 by Kklee Link to post Share on other sites More sharing options...
Incom 1st Gear May 25, 2008 Share May 25, 2008 I bought mine for $50. Portable ones are good enough to topup tyre pressure. Cheers Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie May 25, 2008 Share May 25, 2008 I am using a foot pump that cost less than 10 dollars. You can buy them from neighbourhood hardware stores, can also be used for football, bicycle etc etc. It comes with a pressure gauge built in. With this you can pump early in the morning since the specifications for tyre pressure is cold tyre pressure. Different brands are a bit different, some brands has thicker steel. Provide some exercise for your leg too. Link to post Share on other sites More sharing options...
Carlovz Clutched May 25, 2008 Share May 25, 2008 bro, which brand/model u using now? i brought one from autobacs too....but found that the reading from the compressor and the tire pressure guage kinda of show diff readings. So normally i will jus base on the tire guage. else the two show diff readings....confused Link to post Share on other sites More sharing options...
Carlovz Clutched May 25, 2008 Share May 25, 2008 After I got one from autobaccs.....visiting petrol kiosks is history liao,.... Link to post Share on other sites More sharing options...
Tjkbeluga 5th Gear May 25, 2008 Share May 25, 2008 Oh, didn't notice this thread when I posted to ask about the one selling at Carrefour, Jump Start 900. Hmm... will check out from autobac... Link to post Share on other sites More sharing options...
Mouse Neutral Newbie May 26, 2008 Author Share May 26, 2008 which one did u get from autobacs? went there last week, they carry a few models, out of the few only one seem decent but that one cost $300++ . Those cheaper one I am not sure whether s good enough or not. One of my friends told me b4 he brought a $30 one n each time he had to wait till 20 mins on each tires for topping up the air pressure. Link to post Share on other sites More sharing options...
Albeniz Turbocharged May 26, 2008 Share May 26, 2008 Oops...talking about tyre pressure, I have not pumped the tyres for quite a few months already. But, everything is still ok. For me, as I don't usually pump my tyres that often, I would rather do it at petrol station than buy a compressor. The compressor takes up space. I will prefer to fill whenever I drive by a kiosk. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 26, 2008 Share May 26, 2008 Manual pump is very good. Not prone to failure and doesn't drain the battery. Can use to inflate sex doll. If use electric compressor to pump up sex doll, might explode in your face. Link to post Share on other sites More sharing options...
Mouse Neutral Newbie May 26, 2008 Author Share May 26, 2008 fwahh your tires pressure can last for few months? The compressor is not that huge n does not take up much space. Kiosk sometimes have faulty pump n sometimes have to queue. Own compressor - pump at your own timing. no rush. do it at the carpark b4 u drive off can be used on the spare tire in case u need to change it ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
This is Why You Should NOT Fit OE Tires To Your Car!
What tires for SUV?
What tires for SUV?
Tread Depth
Tread Depth
Dunlop SP Sport LEMANS LM705
Used Truck / tractor tires.
How close to wear indicators before changing tires?
