Azman79 1st Gear May 23, 2008 Share May 23, 2008 My current LG 2 door fridge is about 3 years old. The frozen side is currently not cold even though set at cold. Is it due to the gas inside the compressor has finished or other faults? Any contact to repair it and how much roughly? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
David Clutched May 23, 2008 Share May 23, 2008 Most likely its the heater spoilt. Check on the freezer side if there is any ice formation on the wall of the fridge. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 23, 2008 Share May 23, 2008 Shouldn't have any problems unless the door cannot be properly closed due to the rubber insulation. If not, most likely it's the compressor. Link to post Share on other sites More sharing options...
Azman79 1st Gear May 23, 2008 Author Share May 23, 2008 I've checked but no signs of water at the sides. Is it true there's a need to top up gas? Link to post Share on other sites More sharing options...
User12343 Clutched May 23, 2008 Share May 23, 2008 hardly heard of fridge need to top up gas. used ACMA, Mitsu, fisher paykel before all never needed to top up gas even when i changed them out. Link to post Share on other sites More sharing options...
David Clutched May 23, 2008 Share May 23, 2008 Not water, its ice. If you remember the old days fridge where you have ice accum at the freezer where we make ice cubes. There is a heater hiding behind. When this heater is spoilt, then ice will form. Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged May 23, 2008 Share May 23, 2008 You mean those fins or heatsink strips at the back of the fridge right? Link to post Share on other sites More sharing options...
David Clutched May 23, 2008 Share May 23, 2008 Inside the fridge, in the freezer compartments. Remove the container if you cannot see, the inside walls of the fridge. It should be clear of any ice formation. When there is ice formation, which would likely be the heater spoilt, it sort of a clog up and it hinder the cold air flow. Link to post Share on other sites More sharing options...
Nkps 1st Gear May 23, 2008 Share May 23, 2008 time to change fridge someone is closing a deal soon Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear May 23, 2008 Share May 23, 2008 My current LG 2 door fridge is about 3 years old. The frozen side is currently not cold even though set at cold. Is it due to the gas inside the compressor has finished or other faults? Any contact to repair it and how much roughly? Thanks. Top up gas - $20? Link to post Share on other sites More sharing options...
Scenic98 Clutched May 23, 2008 Share May 23, 2008 yup yup. that's the same problem i had. ice formed in the air passage. My pana fridge no heater. repairman says the compressor hot enough to evaporate the water. just try not to block those outlets in the compartments that will restrict airflow. Cost me about 170 to repair. Link to post Share on other sites More sharing options...
David Clutched May 23, 2008 Share May 23, 2008 Try Mr Koh 6271-8067 Link to post Share on other sites More sharing options...
Apollo 1st Gear May 23, 2008 Share May 23, 2008 check classified and call mech to jeep gas. ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
Car air-con
Car air-con
Electrical appliances
LG Fridge door open sensor keeps beeping
Everything about ice creams
When anything happens…CHANGE CAR!
Neighbour from the artic
Which fridge brand is better?
