Kelpie 2nd Gear June 19, 2008 Share June 19, 2008 Hi all, 1. For the HDB dweller, do you put your shoe rack just outside your door or along the corridor? Is installing customized shoe rack just outside your door an illegal act? 2. Any concerns of shoes being stolen away? What will happen, if the cleaner wash the corridors? Please advise me. Thank you very much. Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Blue2 1st Gear June 19, 2008 Share June 19, 2008 (edited) outside door... got $$ can do wat u 1 as long as no KP kumplain... scare shoes stolen put cheap cheap shoe outside of house... good cleaner will help to wash your shoes...no good cleaner will make sure shoes will not be wash... Edited June 19, 2008 by Blue2 Link to post Share on other sites More sharing options...
Singer Neutral Newbie June 19, 2008 Share June 19, 2008 Bro, depends on the width of the corridor but most have makeshift ones next to the door. Customised one, as long as doesnt disturb the physical structure of the unit is ok, eg of the same dimension and structure to the ready made ones. Just make sure to only put chaepo items outside Cleaners hv their own time table to spring clean the corridor. Either you take note of this or do like what i do, sweet talk with bangla so that they cover the shoes/sandals with a plastic mat that i purposely prepared for. Kp it at a place where is easily accesible by the cleaner Link to post Share on other sites More sharing options...
Boyboy 1st Gear June 19, 2008 Share June 19, 2008 it's against HDB regulations but wth, i did that anyway all those malay house decor technically is against HDB regulations also, as they drill them into the corridor ceiling, etc etc, but as long as it doesn't block pple's way, nothing shd happen. and of course dun offend other neighbours, maybe ask them if they mind. some corridors can be quite narrow Link to post Share on other sites More sharing options...
Scoop Neutral Newbie June 19, 2008 Share June 19, 2008 I use those cheap shoe rack that can be found at DIY or hardware store, best is would those plastic cos will get wet when cleaner do their routine washing. Put only cheap stuff outside. So bro which area are you shifting to... last heard hougang rite ? Link to post Share on other sites More sharing options...
Typhoonz 4th Gear June 20, 2008 Share June 20, 2008 Is your customised shoe rack fixed or movable? If it's movable then I guess it okie... Just as long it doesn't obstruct the pathway and of course your neighbours don't complain... As for the risk of your shoes being stolen, anything that's not locked can and will be stolen so it's totally at your own risk... No more place inside your house? I only put my slippers outside and the rest of the shoes in my house... Link to post Share on other sites More sharing options...
Sfhuang Clutched June 20, 2008 Share June 20, 2008 I used to put a shoe rack outside the door, until I lost a pair of Teva sport sandals and also a pair of SAF sport sandals. I suspect both pairs were stolen by the bangla cleaners, because I saw one bangla downstairs wearing Teva sport sandals that were exactly the same as mine. Link to post Share on other sites More sharing options...
Nutty 4th Gear June 20, 2008 Share June 20, 2008 Anything left outside your house can go missing. My neighbours always report shoes missing. Report to polis also no use. Link to post Share on other sites More sharing options...
Qpik Supercharged June 20, 2008 Share June 20, 2008 a fixed one might pose some probs. get a portable one. beware of karung guni men/aunty. mthly cleang will find yr shoes wet. be careful of roaches hiding inside. the same apply for lingerie hanging outdoor. Link to post Share on other sites More sharing options...
Scion Turbocharged June 20, 2008 Share June 20, 2008 i placed my smelly muddy wet soccer boots outside my door.. gone in the next day... knn Link to post Share on other sites More sharing options...
Silhoutte Clutched June 20, 2008 Share June 20, 2008 How about a shoe box instead? A shoe box can include a lock so that your shoes stay safe inside it. I believe if the rack / box is placed properly without obstructing the walking path, then it shouldn't be a problem at all. Cheers. Link to post Share on other sites More sharing options...
Spikedoll Clutched June 20, 2008 Share June 20, 2008 my neighbour's maid even placed her laundry stand or hanger (whichever u call) at corridor.Mine is corridor end unit and need to walk past their unit.But I'm fine with it as long dun hang undergarments. Link to post Share on other sites More sharing options...
Dumb 4th Gear June 20, 2008 Share June 20, 2008 WTF my neighbour with few foreigners placed their shoes outside the house and the smell goes right into my kitchen. Had to shut my kitchen door whenever they are in. Link to post Share on other sites More sharing options...
Route88 2nd Gear June 20, 2008 Share June 20, 2008 Spray baygon at their shoes Link to post Share on other sites More sharing options...
Kelpie 2nd Gear June 20, 2008 Author Share June 20, 2008 It seems like there many problems associated with putting shoe rack outside of the door. I was told, putting dirty shoes at home is bad Feng Shui. No choice, will customized shoe rack at home near to the door instead. Thank you all for comments. Regards, Link to post Share on other sites More sharing options...
Kelpie 2nd Gear June 23, 2008 Author Share June 23, 2008 I use those cheap shoe rack that can be found at DIY or hardware store, best is would those plastic cos will get wet when cleaner do their routine washing. Put only cheap stuff outside. So bro which area are you shifting to... last heard hougang rite ? Yalor, still ended up in Hougang. Hougang is pretty big, It originated from the fridge of near serangoon mrt, covering Kovan, Hougang MRTs and probably ended at BuangKok MRT. Mine is not too far away from the present Tai Keng. Regards, Link to post Share on other sites More sharing options...
Boyboy 1st Gear June 23, 2008 Share June 23, 2008 I used to put a shoe rack outside the door, until I lost a pair of Teva sport sandals and also a pair of SAF sport sandals. I suspect both pairs were stolen by the bangla cleaners, because I saw one bangla downstairs wearing Teva sport sandals that were exactly the same as mine. i only put shoes which i totally dun mind going missing, outside. still can wear, but cheap or old. lost also nvm, no big deal. and true enuff, none of my shoes which i left outside were stolen Link to post Share on other sites More sharing options...
Scoop Neutral Newbie June 23, 2008 Share June 23, 2008 Welcome to hougang.. : ) Food there not bad ↡ Advertisement Link to post Share on other sites More sharing options...
Trunk Rack for Bicycle
Undertaker fined for urinating in shoe..
What office shoe do you wear?
HDB's new clothes drying rack
Car with bicycle on roof rack into Malaysia
Steering horizontal rack column
