Lancer79 Neutral Newbie August 13, 2008 Share August 13, 2008 Hi guy, i just upgrade to 16 inch rim, so do i need to do alignment. thank you ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 13, 2008 Share August 13, 2008 No need, alignment needed only when changed suspension. Link to post Share on other sites More sharing options...
Lancer79 Neutral Newbie August 13, 2008 Author Share August 13, 2008 oic thank you Link to post Share on other sites More sharing options...
Unfair 3rd Gear August 13, 2008 Share August 13, 2008 Change of rims need to do alignment and balancing..... Link to post Share on other sites More sharing options...
Lancer79 Neutral Newbie August 13, 2008 Author Share August 13, 2008 I have change tyres do balancing, do you koe how much to do alignment... Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear August 13, 2008 Share August 13, 2008 Balancing definitely have to do especially when you change tyres. So in your case, you have to do do balancing and not alignment. Link to post Share on other sites More sharing options...
Jazz 2nd Gear August 13, 2008 Share August 13, 2008 Hi guy, i just upgrade to 16 inch rim, so do i need to do alignment. thank you If you found your driving on a straight road drifting to 1 side, then you need to do alignment. Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 13, 2008 Share August 13, 2008 Hi guy, i just upgrade to 16 inch rim, so do i need to do alignment. thank you -------------------------------------------------------------------------------- If you found your driving on a straight road drifting to 1 side, then you need to do alignment. =========================== Alignment consists of 3 items. Castor, camber & toe-in/out. Not necessary the car will pull to one side if any 1 of these r out. A good computerised 4 wheel alignment wil check all these & put them right if possible. Then your car is travelling straight & true as per manufacturers requirments. Changing rims and/or tires, it is advisable to do a computersied 4 wheel alignment just to make sure the new set is tracking the road properly. Some tire shops say no need lah but remember if the alignment is out, your tires wear out faster & guess who wil make more $$$ from u then. Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear August 13, 2008 Share August 13, 2008 Balancing should be maximum $10 per tyres. Link to post Share on other sites More sharing options...
Robo 2nd Gear August 13, 2008 Share August 13, 2008 i paid $10 for balancing all tyres when i rotated em... Link to post Share on other sites More sharing options...
Maxngck 1st Gear August 13, 2008 Share August 13, 2008 ya, balancing and alignment is totally 2 different thing lor Link to post Share on other sites More sharing options...
Getz_76 Neutral Newbie August 18, 2008 Share August 18, 2008 But i heard the mechanics saying that once you change tyre, its best to do alignment too. Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear August 18, 2008 Share August 18, 2008 Balancing yes, alignment I don't think so bah. Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear August 18, 2008 Share August 18, 2008 Wow. Where you do it? You got that price when you did rotation alone or when you did together with other stuff? Link to post Share on other sites More sharing options...
Grubbyrex Neutral Newbie August 18, 2008 Share August 18, 2008 i got my tyre rotation lifetime free thruout the tyre life and free patching for minor(nails etc) :) Link to post Share on other sites More sharing options...
Robo 2nd Gear August 18, 2008 Share August 18, 2008 did it at a shop behind bedok idac... Link to post Share on other sites More sharing options...
Grix17 Clutched September 3, 2008 Share September 3, 2008 I got new 18" rims and CSC3s at Stamford a few days ago .. was told to come back in a few days to do alignment. First time this has happened to me. Link to post Share on other sites More sharing options...
Nauticar Neutral Newbie September 7, 2008 Share September 7, 2008 If you do not know your original alignment specs (ie before you changed tyres and rims) it's good to do an alignment. It might be good for people who intend to change their tyres/rims anytime soon to LOOK at your own old tires and see how the wear is like. The wear pattern of the 4 tires are visual clues to your alignment and from there you can decide whether an alignment is necessary after a wheel/tire change. N ↡ Advertisement Link to post Share on other sites More sharing options...
Need Advice on Self Storage
