Adawang 1st Gear August 27, 2008 Share August 27, 2008 My car is 2 yrs old, Mitsubishi few month back, the left brake light bulb keep blowing changed the third time already last change was 2 weeks back, today blow again bulb is 21/5 watt, dunno why, can anybody help? ↡ Advertisement Link to post Share on other sites More sharing options...
Charleslim Neutral Newbie August 27, 2008 Share August 27, 2008 Do not touch the glass on the bulb; skin oil will create a hot spot that greatly reduces the life of the bulb (so it is said). Link to post Share on other sites More sharing options...
Robo 2nd Gear August 28, 2008 Share August 28, 2008 try buying a better quality bulb might help.. Link to post Share on other sites More sharing options...
Apollo 1st Gear August 28, 2008 Share August 28, 2008 check ur fusebox connection. did u add any extra wire? r u using original type of bulb or LED or 3rd party high white type? Link to post Share on other sites More sharing options...
Modykoh 1st Gear August 28, 2008 Share August 28, 2008 maybe u wan to buy a dozen to standby,...whhaaa... try a higher rating wan.... Link to post Share on other sites More sharing options...
Watwheels Supersonic August 28, 2008 Share August 28, 2008 Yeah replace the fuse. Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 28, 2008 Share August 28, 2008 Can be due to poor contacts due to rust , loose fittings/wires or present of water. Link to post Share on other sites More sharing options...
Chongster 6th Gear August 28, 2008 Share August 28, 2008 brake less Link to post Share on other sites More sharing options...
Adawang 1st Gear August 28, 2008 Author Share August 28, 2008 using the original type of bulb. Japan made Link to post Share on other sites More sharing options...
Adawang 1st Gear August 28, 2008 Author Share August 28, 2008 I bought a few haha Link to post Share on other sites More sharing options...
Adawang 1st Gear August 28, 2008 Author Share August 28, 2008 wil trouble shoot if got loose connection this weekend Link to post Share on other sites More sharing options...
Adawang 1st Gear August 28, 2008 Author Share August 28, 2008 maybe u wan to buy a dozen to standby,...whhaaa...try a higher rating wan.... using original ratings Link to post Share on other sites More sharing options...
Treesmaker Clutched August 28, 2008 Share August 28, 2008 My car is 2 yrs old, Mitsubishifew month back, the left brake light bulb keep blowing changed the third time already last change was 2 weeks back, today blow again bulb is 21/5 watt, dunno why, can anybody help? Dude, its not the bulb or fuse, its more serious. Get a "wire-man" to trace the source of the "short". Its a short somewhere. Link to post Share on other sites More sharing options...
Singer Neutral Newbie August 28, 2008 Share August 28, 2008 after those simple diagnosis and prob still persist, mayb short circuit somewhere? u may not wannna meddle unnecessarily and get electrician to check Link to post Share on other sites More sharing options...
Adawang 1st Gear August 28, 2008 Author Share August 28, 2008 cannot be a short circuit as fuse will blow if short Link to post Share on other sites More sharing options...
Santav Neutral Newbie August 28, 2008 Share August 28, 2008 i had similar problems wif brakes light bulbs during the 1st year of my ride. the left, right & center brake light bulbs take turns to blow every month. AD checked electricals & said nothing wrong.....finally decided to buy own bulbs from outside auto shop at $1 each (cheaper then AD)...and problem gone.....it's been 3yrs since, no bulb blown.... Link to post Share on other sites More sharing options...
Modykoh 1st Gear August 28, 2008 Share August 28, 2008 try the LED type..more stable.. Link to post Share on other sites More sharing options...
Megaweb Clutched August 28, 2008 Share August 28, 2008 (edited) just change it lor so cheap, cost $1.20 each only ... just changed mine 4 month ago, still working Edited August 28, 2008 by Megaweb ↡ Advertisement Link to post Share on other sites More sharing options...
Cyclops Rear Light - Who came up with it first?
Quad Light Bulb Size
Brake Pads
Brake Pads
Recommendations for light kitchen carpentry and sink works
P2096 Check engine light
