Nephilim 1st Gear September 5, 2008 Share September 5, 2008 (edited) Last week, I installed a chassis bar (it's from Cusco and made for my vehicle model) to the front of my undercarriage (see attached pic below). It was fine when I left the workshop but by the 3rd day I can hear intermittent "tok tok" sound when I turn very slowly (<10km/h). When back to the workshop and they told me it's the bar doing its job. But nonetheless they took it out and reinstalled again and everything was fine until ... yes you've guessed it ... the third day when the "tok tok" sound returns. Anyone has the same experience? Is this normal? It's just a little annoying whenever I'm parking. Edited September 5, 2008 by Nephilim ↡ Advertisement Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged September 5, 2008 Share September 5, 2008 It happened once to me. At that time no bars installed. My mech check and realised that it is because a brake hose was loose, so when turning, the tyre rub against the brake hose thus the sound. They just use a cable tie to contain the brake hose. Jack up the car and check. Link to post Share on other sites More sharing options...
Kangadrool Supersonic September 5, 2008 Share September 5, 2008 Is there sufficient clearance between bar and exhaust pipe? Could be the exhaust hitting the bar. Link to post Share on other sites More sharing options...
Modykoh 1st Gear September 5, 2008 Share September 5, 2008 sound to me is installation looses after the tightening set in... Link to post Share on other sites More sharing options...
Osiris 1st Gear September 5, 2008 Share September 5, 2008 I installed a lower tie bar to my ride. the tok tok tok sound comes from the installation becoming loose. have to tighten it. tighten very tight liao, after a while come back. so irritating till i gave up and took it out and sold it off. Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged September 5, 2008 Share September 5, 2008 So in this case, it is more of inferior production? I installed, front and rear H-brace and front and rear anti-roll bar... no such thing leh... Link to post Share on other sites More sharing options...
Nephilim 1st Gear September 5, 2008 Author Share September 5, 2008 Unlikely to be the brake hose (which are stock). Sound was gone (temporary) after they took out and reinstalled the bar. We're all pretty sure it's the bar. Link to post Share on other sites More sharing options...
Nephilim 1st Gear September 5, 2008 Author Share September 5, 2008 Yes there's sufficient clearance. The only points touching the chassis are the joints with the screws. Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged September 5, 2008 Share September 5, 2008 Then it may be as what orisis said. Ask them to change new bar for you..... but i think unlikely they will do that Link to post Share on other sites More sharing options...
Nephilim 1st Gear September 5, 2008 Author Share September 5, 2008 So we might be in the same boat then. My bar didn't come with anything and the workshop installed it with just the screws (no washers). Asked them to put washers but they didn't have and said it should come with it. Do you think washers might help? Link to post Share on other sites More sharing options...
Osiris 1st Gear September 5, 2008 Share September 5, 2008 mine from Alutec. some other stream owners also have this problem. inferior pdt? likely... Link to post Share on other sites More sharing options...
Apollo 1st Gear September 5, 2008 Share September 5, 2008 bearing gone. Link to post Share on other sites More sharing options...
Watwheels Supersonic September 5, 2008 Share September 5, 2008 When there is flexing, the bolts where the bar are secured are bound to come loose. Unless the bolt is secured by a lock nut on the other end of the bolt or some pin to prevent the bolt from unscrewing itself(due to flexing), your problem will never be solved. Link to post Share on other sites More sharing options...
Apollo 1st Gear September 5, 2008 Share September 5, 2008 can use spring washer lah... tat one used for washing spring chicken. Link to post Share on other sites More sharing options...
Circuit Clutched September 9, 2008 Share September 9, 2008 aiyo.. in case of lossening due to vibration. buy loctite for screws to tie it down. if need to remove.. jus heat up and can be loosen. :) Link to post Share on other sites More sharing options...
Modykoh 1st Gear September 9, 2008 Share September 9, 2008 correct...or use a spring washers... Link to post Share on other sites More sharing options...
Ck77 Neutral Newbie September 11, 2008 Share September 11, 2008 I think should be looses and that make vibration. Checking can finding what is wrong is important The last time I hear fuuny sound in my car was that the person left a tools near my engine. Link to post Share on other sites More sharing options...
Ep80_dekit Neutral Newbie September 14, 2008 Share September 14, 2008 anyway, could be exhaust hitting the bar. even got enough clearance, the exhaust has some flex, so it could be hitting it. ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
Sound Proofing the car
Whole car sound proof
COVID-19: Retrenchments
NUS Grad becomes rubbish collector after retrenchment
