Timmz Neutral Newbie September 15, 2008 Share September 15, 2008 I just did a try to loosen the wheel nuts with the small car supplied tool kit wrench. ooowwww, it was soooooo tight, tried all round. cannot even move even 1 of them. ok the wrench is rather small and has poor leverage...... but.... if really need to change the spare... I dont think I can make it :( Due to the air wrench super torque tightening? Any 'kang tao' for getting a better 1? or look for a strong pipe to better leverage on the supplied wrench?? Please advise. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Xiaogary Neutral Newbie September 15, 2008 Share September 15, 2008 put the bar in, then whole body stand onto the bar. Then jump or shake on the bar. I tried to remove one nut from Grandis before. Jump up and down 10-20 times with whole body weight then the nut loosen. Link to post Share on other sites More sharing options...
Ahliew Neutral Newbie September 15, 2008 Share September 15, 2008 i find bending your knees slightly, putting the wrench 90 degs, pulling upwards helps me abit. or step/jump on it i find it harder to push it downwards Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 15, 2008 Share September 15, 2008 er... did you unloosen the nuts BEFORE you jack up the car? you can use a hollow pipe that can go over ur wrench and use it as a bar extender to get greater torque. Link to post Share on other sites More sharing options...
Apollo 1st Gear September 15, 2008 Share September 15, 2008 goto chew hup thai or kam automart but the taiwan made extendable bar. this uses simple fulcrum principle of longer length x force to overcome the locked nut. not expensive and hv 2 nut adapter for use on 4 different nuts. the crossbar can keep at home. this one good for fighting also.. Link to post Share on other sites More sharing options...
Kb27 Supersonic September 15, 2008 Share September 15, 2008 The problem is the tyre workshop always overtightened. They like to do at least 100 ft-lb and more. That's what I found out with a torque wrench. According to my car manual, the tightening torque is only between 60 to 80 ft-lb. Even after you untightened it, if you go back to them, they will overtighten again and again. Link to post Share on other sites More sharing options...
Hitsuji123 Neutral Newbie September 15, 2008 Share September 15, 2008 Ur wheel nut is a virgin la...! tat's y sooo tight... try putting some lubricant.. then sure can lossen... Link to post Share on other sites More sharing options...
Fitvip Supersonic September 15, 2008 Share September 15, 2008 (edited) Get a metal pipe as an extension! Edited September 15, 2008 by Fitvip Link to post Share on other sites More sharing options...
Genie47 1st Gear September 15, 2008 Share September 15, 2008 Use your body weight. Stand on the wrench. Hop on it a few times if needed. Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie September 15, 2008 Share September 15, 2008 did you unloosen the nuts BEFORE you jack up the car? tat is one bloody mistake i have and learnt when i experience the need to change tyre on my very first car... Link to post Share on other sites More sharing options...
Timmz Neutral Newbie September 15, 2008 Author Share September 15, 2008 not expensive is approximately how much? some people also say torque wrench is also not expensive..... Link to post Share on other sites More sharing options...
Nazaki Clutched September 15, 2008 Share September 15, 2008 Subscribe to AAS. Free 24hr assist. :) Link to post Share on other sites More sharing options...
Apollo 1st Gear September 15, 2008 Share September 15, 2008 ard $20-30 only Link to post Share on other sites More sharing options...
Caravan 5th Gear September 15, 2008 Share September 15, 2008 KICK it. Or rather stamp on it. I have changed tyres 3 times, and kicking always works. Don't underestimate the power of a kick. Link to post Share on other sites More sharing options...
Brock 1st Gear September 16, 2008 Share September 16, 2008 If you jump on it, better be careful. Not properly aimed or timed, you're gonna have a bad gash on your leg if the metal connects with your flesh. Link to post Share on other sites More sharing options...
Robin 4th Gear September 16, 2008 Share September 16, 2008 initially i also cant loosen my "virgin" nuts.... but after the first time... no problem liao Link to post Share on other sites More sharing options...
Eyke Supercharged September 16, 2008 Share September 16, 2008 Due to the air wrench super torque tightening? just make sure whoever next tightens your nuts don't go over your car manufacturer's recommended torque. or get yourself a torque wrench, and DIY; that's what i do coz besides hard to loosen, over tight can strip threads and warp rotors. Link to post Share on other sites More sharing options...
King 1st Gear September 16, 2008 Share September 16, 2008 i fainted.... ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Wheel Hubs
Wheel Hubs
Eye surgery - cannot drive
Sales pitch for animals
Paddle shifters - fixed to wheel or column?
