When to change shock absorbers?
Siyexcalibur
I have squeaky sounds frm my D2 coils... any idea how to fix them? :(
You should go bakc to A T Performance for a health check on your coils.
ya, a bit squeaky sound for D2 coils is normal. If BTH, better go AT performance and let them check and service your coils. Your squeaky sound is front of rear? Previously, i got squeaky sound on the front. End up they put grease and spray some WD-40 on the shaft then problem solve !
well, just to share a thing or two that I have learned from my dad and uncles. They say that the good way to test your shocks is to push the car down and release it, if it bounce back and steadied just after going up, then your shocks are still ok. But when it bounce back like a ball you are dribbling, it is the perfect time to change your car shock absorber. Hope this simple trick can help. :)
My poor car cross about 50 speed humps a day, excluding speed regulating strips. This type of usage, how long can the shock absorbers last? Can last 10 years? I tried bouncing the car, but the suspension is too firm, I can hardly move it. My wife ill treat the car by crossing the humps at up to 60 km/h.
Some literature recommended to check/replace every 40,000km. However, it also depends on other factors like the weight od the vehicle during usage (longer service life with lighter vehicle weight), travelling speed during usage (especially over humps, potholes, cornering, braking)
My one year plus car already have symptoms of previous 8-year old car with worn shock-absorbers, when road surface is rough/uneven
If car rock alot, have a Mechanic check for worn shock-absorbers. Worn shock-absorbers typically caused one vehicle collision/somersaulting when braked hard
My Sonata NF shock-absorber also due for change. Can feel the car bouncing like a rubber ball over humps. [laugh]
Got lots of ticking sound making U-turn as well.
Milage almost 110k liao.
I just changed my shock absorbers for my nissan sunny now at 135,000km and paid S$130-00 for 2 pcs front Tokiko brand and S$30 for labour to change at a JB workshop, and another S$20-00 for 2 pcs dust cover + dampener. Total cost = S$180-00.
Most places i went quoted almost 50% more at least for the same and I still cant believe how much cheaper i got it done.
And my ride is now perfect, smooth and stable. Feels like a new car.
If your shocks are faulty, get it changed immediately. I had a near miss on the AYE recently. Faulty shocks will compromise your braking performance. With faulty shocks you will take a longer time to brake and a few seconds can be vital to whether you or your family live or die or get hurt.
yes only the 2 front shock absorbers - the back ones are still ok and just did computerised wheel allingment at JB for $45 ringgit and the ride is really great and feels stable wit good grip...i'm happy.
I think the Tokiko shock absorbers are good and for $65-00 really value for money.
Hi Mika, u only changed the front 2 shocks? isnt it better to change all 4?
The gauge is to change shock absorber in pairs that is left and right together not all 4. Anyway.. its mostly sold in pairs so you don't seem to get a choice. However if the test is done at AD, then they will tell you that they had run a check on the other side of the damper hence changing the faulty one is sufficient. Different talks for different pockets.
Not just ADs. Some workshops would also advise the same.
Change already, the car feel new again.
I did once long ago with my old civic...I mean I change all four after leaving the car in the open during winter and not drive for three months.
The car was bouncing like a ball and I have to change all four
Edited by GoodCar
I changed my suspension too some weeks back.
Feels good. [thumbsup]
