Ehonda Neutral Newbie June 10, 2009 Share June 10, 2009 any it expert here? my current desktop going to up the lorry .. need to get a new desktop .. thinking of getting those branded one, like those from Court or Best Denki etc .. anything i should look out for? by the way .. my budget only $1,000 .... ↡ Advertisement Link to post Share on other sites More sharing options...
Maersk1 1st Gear June 10, 2009 Share June 10, 2009 bro...you may consider getting one from Dell, the lowest avg desktop roughly cost abt S$800 plus... for me I just bought one two months ago, this is my 2nd Dell desktop, the first one i used nearly abt 5 yrs....including monitor (21' wide screen), 500GB HD with 3GB ram mem, speaker + subwoofer etc...is abt S$1400 plus..., of course over your budget ! But seriously you can consider Dell. Happy searching.... Link to post Share on other sites More sharing options...
Kxbc Turbocharged June 10, 2009 Share June 10, 2009 Go SLS/Funan ask them to build one for you. CPU + licensed OS alone should be less than $1k depending on what you put inside. Usually 1 yr warranty. You can always reuse your old monitor. My second built CPU from them already. All still functioning after 3 years with no breakdown. But this type of thing heng sway one. Or buy a cheap netbook and hook it up to your monitor? Less than $700. Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 10, 2009 Share June 10, 2009 if possible consider a laptop. my laptop is 15.4" if you need bigger they also have 17" although size isn't everything! Link to post Share on other sites More sharing options...
Skylander Neutral Newbie June 10, 2009 Share June 10, 2009 i believe you still have your monitor not going to change that. My system also went kaput recently and i managed to trade in my old system and got a new one for about $550. Specs are decent (dual core, 320GB, 6.1 sound on-board, nvidia 9400GT, 2GB ram, 450W Power, card reader, XP or Vista OEM etc) and should be able to handle most games and software. I think most shops in SLS lets you trade-in your old PC. PM me for more details if you want to know. Link to post Share on other sites More sharing options...
Rickster 5th Gear June 10, 2009 Share June 10, 2009 If u into gaming or doing 3d works/graphics etc, I'd advice u to get a desktop with a dedicated graphic card nothing less than a Gefore9800. Go for a system with at least 2GB of ram - nothing less if u want to enjoy smooth computing. Harddisk go for one that is at least 7200rpm with 32MB cache if you don't want to wait donkey years for an application to load. 1K budget will be more than enough for you to get a system with the above specs (if you recycle ur monitor). Link to post Share on other sites More sharing options...
Dwoon 1st Gear June 10, 2009 Share June 10, 2009 Repair your current one if it still serves your purpose..... save the $$$ Was considering another PC or notebook.... then decided against it since current one was serving its purpose well. Just that it was dying. So did abit of reading up (hardwarezone) and did some monitoring of the system thru' the advises that were posted in the forum. Narrowed down to PSU or motherboard. I just replaced my PSU as the old one (~ 5 years) was dying and not supplying sufficient 3.3V voltage to the system. Symptoms was the PC would just shutdown on its own or hang halfway. Fix cost $39. Link to post Share on other sites More sharing options...
Ahgongwolve Clutched June 10, 2009 Share June 10, 2009 any it expert here? my current desktop going to up the lorry .. need to get a new desktop .. thinking of getting those branded one, like those from Court or Best Denki etc .. anything i should look out for? by the way .. my budget only $1,000 .... Build urself la! Link to post Share on other sites More sharing options...
Jamstart 1st Gear June 10, 2009 Share June 10, 2009 PC is coming, hearsay cheapest offer with 18.5" monitor is around 499. Check it out. Link to post Share on other sites More sharing options...
Sniperben Neutral Newbie June 10, 2009 Share June 10, 2009 any it expert here? my current desktop going to up the lorry .. need to get a new desktop .. thinking of getting those branded one, like those from Court or Best Denki etc .. anything i should look out for? by the way .. my budget only $1,000 .... DIY will be best. go for cheaper alternative like AMD processer. choose on DDR2 instead of the new DDR3 to cut cost. if you not into gaming, just get 1 board with integrated graphic. a stable power supply unit is essential, please get something reasonable good. lastly, recommend ram to be 3GB at least. Link to post Share on other sites More sharing options...
Geboz Clutched June 10, 2009 Share June 10, 2009 any it expert here? my current desktop going to up the lorry .. need to get a new desktop .. thinking of getting those branded one, like those from Court or Best Denki etc .. anything i should look out for? by the way .. my budget only $1,000 .... is you PC for gaming, watcing video or fporgeneral usage (surfing + doc processing) ? $1000 is more than enough for a general usage machine, but not enough for hardcore gamers. Link to post Share on other sites More sharing options...
Mazdaowner Moderator June 10, 2009 Share June 10, 2009 any it expert here? my current desktop going to up the lorry .. need to get a new desktop .. thinking of getting those branded one, like those from Court or Best Denki etc .. anything i should look out for? by the way .. my budget only $1,000 .... Compaq with 20+" screen $999. Go check it out at Challenger. Link to post Share on other sites More sharing options...
Ev960d Neutral Newbie June 10, 2009 Share June 10, 2009 Can consider Shuttle PC. Made in US, and looks cute. W/o Monitor less than $500 Link to post Share on other sites More sharing options...
Josho 1st Gear June 10, 2009 Share June 10, 2009 Basically, whats ur need? Game or normal office work? Then everyone can guide u along. Link to post Share on other sites More sharing options...
Contax 1st Gear June 10, 2009 Share June 10, 2009 I'm also in your shoes a few months back , with the help of the bro's here I finally bought a 16'' Lap Top instead of the desk top . Here's the discussion : http://www.mycarforum.com/index.php?showtopic=2634349 Link to post Share on other sites More sharing options...
Mazdaowner Moderator June 10, 2009 Share June 10, 2009 I'm also in your shoes a few months back , with the help of the bro's here I finally bought a 16'' Lap Top instead of the desk top . Here's the discussion : http://www.mycarforum.com/index.php?showtopic=2634349 Hey bro. good choice. I gave my Compaq notebook to my son, going U few months from now. Next round, you MIGHT want to consider, i poison you first. kekekek..... Lighter and smaller. Ram put up to 2GB. Serves my purpose well enough. Half the size of my old notebook. Cheep cheep. $600+. Got lohbang. I got a Compaq Mini Notebook. Link to post Share on other sites More sharing options...
Contax 1st Gear June 10, 2009 Share June 10, 2009 knn.....but I have to agree ,IT stuffs changes much faster than we change underwear. For now , I'm contended .Period . Link to post Share on other sites More sharing options...
Cavver 4th Gear June 10, 2009 Share June 10, 2009 Viewsonic unveiled their all-in-one PC at the CES 2009. The VPC 100 has an 18.5-inch 16:9 LCD screen and is only 35mm thick. The system features a 160GB hard drive, 1GB RAM and runs on an Intel Atom 1.6GHz CPU. It also has a 1.3mp webcam, a DVD +/- RW drive, built-in stereo speakers and a 3-in-1 card reader. Installed with Windows XP home. I think is priced under $900 for this PC show. ↡ Advertisement Link to post Share on other sites More sharing options...
Getting a foreign wife
COVID-19: Retrenchments
Woman lashes out at tutor who asks for payment.
Tutors getting private bankers pay
Getting City Gas Into Landed Property
How many interviews to go b4 getting the job
Shell to downsize ops in sgp
