Furrynadz 5th Gear August 6, 2009 Share August 6, 2009 i just checked..pad still has about 7mm left..dunno should i change onot? going up north this weekend... dun change u have insufficient time/mileage to bed in the pads and transfer the friction material ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 6, 2009 Share August 6, 2009 i just did my last servicing 2 mths ago..and driven less than 2000km..i only worry about the brakes.. ============= 7mm left on the pads is still quite a lot lah. I use till maybe 1mm then consider to change. Hahaha. Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 6, 2009 Share August 6, 2009 some time ago i bought a pair of Ferodo brake pad from a guy called Robert.....but has lost e contact. Any bros can help enlighten?? Link to post Share on other sites More sharing options...
Solar Turbocharged August 6, 2009 Share August 6, 2009 Stock brake pads usually lasts longer as they are using hard compound material, but at the expense of less bite. For my previous 2 new auto cars, the stock pads lasted about 75,000 - 80,000km before I changed them. Some aftermarket brake pads give better bite, but last shorter mileage due to softer compound used for the pads. These typically lasts only around 30,000-40,000km. yes, that's true.. i'm using ebc yellow stuff, lasted me about 30k km.. changed them out with about 4mm left Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 9, 2009 Share August 9, 2009 some time ago i bought a pair of Ferodo brake pad from a guy called Robert.....but has lost e contact. Any bros can help enlighten?? Ferrodo brake pad here kenna condemn by Australia forums ppl like mad. It's pretty cheap though but no one want to buy it, i did some research first before decided on RDA for my SUV. The premium pads here are mainly EBC, RDA and Bendix. Link to post Share on other sites More sharing options...
Yuan 6th Gear August 9, 2009 Share August 9, 2009 Change it and have a peaceful drive... Better still, do light servicing n do point checks... Msian roadside mechs talk a lot of c--k and sell a load of bull if u have a problem there... Nothing beats a pleasant, worry-free drive... cheers! Agree with this. Link to post Share on other sites More sharing options...
LauSaiKia Neutral Newbie August 19, 2009 Share August 19, 2009 Jus for your info Organic brake pad - cheap, less sound and dust but braking no good. Metallic brake pad - slighly expensive, some sound and dust but good bite for braking so rotor will wear out faster(wat do u expect when u have metal against metal) Nothing is perfect... Link to post Share on other sites More sharing options...
Tanshida1201 Neutral Newbie September 3, 2009 Share September 3, 2009 Any good and decent brand for brake pad to recommend? I am not the kind who drive very fast. So is stock brake pad sufficient? Link to post Share on other sites More sharing options...
Andrefoo Neutral Newbie September 3, 2009 Share September 3, 2009 mintex if you're driving a conti, stock if you're on a jap or korean sedan. Reason being most conti cars have stock brakepads which give out hell a lot of brake dust. Link to post Share on other sites More sharing options...
Tanshida1201 Neutral Newbie September 3, 2009 Share September 3, 2009 Thanks Andrefoo. Mine is a japanese car.. Btw, what is the problem with the brake dust? It will affect our health issit? Link to post Share on other sites More sharing options...
Andrefoo Neutral Newbie September 3, 2009 Share September 3, 2009 Thanks Andrefoo. Mine is a japanese car.. Btw, what is the problem with the brake dust? It will affect our health issit? no problem la.... just that if you drive a car like mine, you can wash the rim on monday till its shiny n it will be black with brake dust by thursday... sigh... its a problem with most contis Link to post Share on other sites More sharing options...
Tanshida1201 Neutral Newbie September 3, 2009 Share September 3, 2009 OIC.. So the brake dust will stick to rim.. No wonder my back rim always more dirty than the front rim. Thanks.. Link to post Share on other sites More sharing options...
Yuan 6th Gear September 3, 2009 Share September 3, 2009 Any good and decent brand for brake pad to recommend? I am not the kind who drive very fast. So is stock brake pad sufficient? If you are not the kind who drive very fast, stock would be sufficient. Link to post Share on other sites More sharing options...
Lordau Neutral Newbie September 3, 2009 Share September 3, 2009 usualli getting aftermarket type of brake pad better or stock pad better? Abit confuse which to get Link to post Share on other sites More sharing options...
Yuan 6th Gear September 3, 2009 Share September 3, 2009 usualli getting aftermarket type of brake pad better or stock pad better? Abit confuse which to get Aftermarket brake pads give slightly better braking power than stock ones. But if you don't drive aggressively, stock pads would be sufficient. Link to post Share on other sites More sharing options...
Robin 4th Gear September 4, 2009 Share September 4, 2009 check thickness.. check if got eeee eeeee sound when braking Link to post Share on other sites More sharing options...
Scaglietti Neutral Newbie September 4, 2009 Share September 4, 2009 (edited) OIC.. So the brake dust will stick to rim.. No wonder my back rim always more dirty than the front rim. Thanks.. Should be the other way round. The front brakes will contribute more to the braking then the rear. There should be much more brake dust generated in the front brakes then the rear. Edited September 4, 2009 by Scaglietti Link to post Share on other sites More sharing options...
Scaglietti Neutral Newbie September 4, 2009 Share September 4, 2009 mintex if you're driving a conti, stock if you're on a jap or korean sedan. Reason being most conti cars have stock brakepads which give out hell a lot of brake dust. One thing I hate about Mintex pads... screechy. Mintex pads can be very noisy... don't like them at all. ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
Change Disc Rotors
Change Disc Rotors
Tool to change Spark Plug
X for twitter change request
