Picanto 3rd Gear July 23, 2012 Share July 23, 2012 wow, iridum really that lasting? i bought mine at 40k.. ride is only 78k now.. meaning i will probably need to change at 140k.. its supposed to last...does not mean it will DEFINITELY last 100k ↡ Advertisement Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 23, 2012 Share July 23, 2012 wow, iridum really that lasting? i bought mine at 40k.. ride is only 78k now.. meaning i will probably need to change at 140k.. not all iridium plugs can last 100k, it depends on which type of iridium plugs : example : IK20 - around 20k ~30k+ because it has a 0.4mm diameter iridium tip & a normal alloy ground or negative electrode (similar to copper plugs) SK20 - around 80k ~ 100k+ because it has a 0.7mm diameter iridium tip & a platinum coated on normal alloy ground or negative electrode. above are similar plugs in terms of external specs. Link to post Share on other sites More sharing options...
Yixiang1 3rd Gear July 23, 2012 Share July 23, 2012 how u know plugs need changing??? Loss of power?? but that could be due to ignition coil also right?? Link to post Share on other sites More sharing options...
Mickkiee 1st Gear July 23, 2012 Share July 23, 2012 iridium is good metal.. and it'll be usefull for many purpose so its best to use it Link to post Share on other sites More sharing options...
Terratoss 1st Gear July 23, 2012 Share July 23, 2012 not all iridium plugs can last 100k, it depends on which type of iridium plugs : example : IK20 - around 20k ~30k+ because it has a 0.4mm diameter iridium tip & a normal alloy ground or negative electrode (similar to copper plugs) SK20 - around 80k ~ 100k+ because it has a 0.7mm diameter iridium tip & a platinum coated on normal alloy ground or negative electrode. above are similar plugs in terms of external specs. Usually how much does it cost for IK20 and SK20? Link to post Share on other sites More sharing options...
Trex101 3rd Gear July 23, 2012 Share July 23, 2012 Usually how much does it cost for IK20 and SK20? IK20 around $60/set while SK20 around $100+ per set but for a long life 100k km plugs, you could try the new Bosch OE iridium, Iriidium + platinum like SK20 but cost around $60/set only. Link to post Share on other sites More sharing options...
Skyiet27 Clutched July 24, 2012 Share July 24, 2012 bro you were saying u got freelance mech to change for us plugs if mine is used car my mech say oil seal are worn oreadi your mech got these seals or should i bring down the seals together with the plugs change tks Link to post Share on other sites More sharing options...
Trex101 3rd Gear July 24, 2012 Share July 24, 2012 (edited) bro you were saying u got freelance mech to change for us plugs if mine is used car my mech say oil seal are worn oreadi your mech got these seals or should i bring down the seals together with the plugs change tks They wouldn't have the seal, you have to bring the correct stem seal down and they can change it for you but plugs we have, no problem. You would also need to bring a new valve cover gasket as that need to be open up for stem seal change. Edited July 24, 2012 by Trex101 Link to post Share on other sites More sharing options...
Terratoss 1st Gear July 24, 2012 Share July 24, 2012 IK20 around $60/set while SK20 around $100+ per set but for a long life 100k km plugs, you could try the new Bosch OE iridium, Iriidium + platinum like SK20 but cost around $60/set only. hm.. ok.. so the new bosch oe iridium is also considered long life category? Link to post Share on other sites More sharing options...
Trex101 3rd Gear July 24, 2012 Share July 24, 2012 hm.. ok.. so the new bosch oe iridium is also considered long life category? Yes, same category as Denso iridium tough. Link to post Share on other sites More sharing options...
Terratoss 1st Gear July 24, 2012 Share July 24, 2012 Yes, same category as Denso iridium tough. hm.. ok.. shall research on it and see see look look.. thks for the input! Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 24, 2012 Share July 24, 2012 Usually how much does it cost for IK20 and SK20? IK20 can around $60 for a pack of 4 plugs, same goes for SK20, if you know where to buy Link to post Share on other sites More sharing options...
Terratoss 1st Gear July 24, 2012 Share July 24, 2012 IK20 can around $60 for a pack of 4 plugs, same goes for SK20, if you know where to buy May I know where? Link to post Share on other sites More sharing options...
Ooosh 1st Gear July 24, 2012 Share July 24, 2012 Iridium is the worst conductor of electricity. But it gives good mileage Stock copper spark plugs are the best value for money as they are the next best conductor after silver spark plugs and probably is economically viable to change every 10k (under $20 for 4 cylinders). Link to post Share on other sites More sharing options...
Keromond 1st Gear July 24, 2012 Share July 24, 2012 (edited) May I know where? mxtrad ings can get this price? Edited July 24, 2012 by Keromond Link to post Share on other sites More sharing options...
Terratoss 1st Gear July 24, 2012 Share July 24, 2012 Iridium is the worst conductor of electricity. But it gives good mileage Stock copper spark plugs are the best value for money as they are the next best conductor after silver spark plugs and probably is economically viable to change every 10k (under $20 for 4 cylinders). hm.. in this case can I say that copper plugs provide more "spark power"? Link to post Share on other sites More sharing options...
Trex101 3rd Gear July 24, 2012 Share July 24, 2012 (edited) hm.. in this case can I say that copper plugs provide more "spark power"? All or most plugs are copper core, iridium or platinum are just the tip at the centre electrode. The plugs that produced the most concentrated sparks is the one with the smallest centre electrode. copper plugs usually have 2.5mm copper tip. iridium from 0.4mm to 0.8mm platinum from 0.6mm to 1.1mm Edited July 24, 2012 by Trex101 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 24, 2012 Share July 24, 2012 hm.. in this case can I say that copper plugs provide more "spark power"? Actually about the same when new,it is only Irdium will last longer...some cars esp those modern V6 engine[for my car,you need to remove the throttle body] very difficult to change spark plugs,so long lasting spark plugs is needed. ↡ Advertisement Link to post Share on other sites More sharing options...
Denso Iridium Spark Plug (IK20)
Iridium Laser spark plugs
Which NGK iridium plugs for Integra GSR?
What's Different Between Denso Iridium SP in SK20 & IK20
NGK V.S DENSO - IRIDIUM SPARK PLUG
Bosch FGR8MQI or Denso 1KH16 Iridium Spark plug
Recycle Reuse iridium Spark Plugs
