Happily1986 5th Gear December 2, 2009 Share December 2, 2009 Thinking of doing a mod to my netbook but no dremel Would like to cut out a precise shape from the plastic bezel. I got the exact dimensions courtesy of a plastic block (not really a stencil) Does anyone know of a good shop that does customised laser cutting service, mine is just a minor laser cutting only plastic only. Hopefully the cost is not too expensive. thanks for your replies ↡ Advertisement Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear December 2, 2009 Share December 2, 2009 i know there are a few shops which do engraving, not sure if you are referring to this? you can try Causeway Point.~ Link to post Share on other sites More sharing options...
Happily1986 5th Gear December 2, 2009 Author Share December 2, 2009 (edited) Would like to cut out the shape of the apple on my LCD upper lid Then after which, use epoxy or putty to affix this plastic fella in there. Final product will look like this Edited December 2, 2009 by Happily1986 Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear December 2, 2009 Share December 2, 2009 if i were you, i will buy a tiny saw, rough and smooth sand paper and DIY..~ =p those stuffs you can buy at those $2 shops..~ Link to post Share on other sites More sharing options...
Happily1986 5th Gear December 2, 2009 Author Share December 2, 2009 if i were you, i will buy a tiny saw, rough and smooth sand paper and DIY..~ =p those stuffs you can buy at those $2 shops..~ lol... i think normal sawing is okay for me but this project will require me to saw from nowhere on the plastic lid and the precision require to fit the plastic apple thing, i am not so confident to get that precision leh... So was thinking just go to those workshops that do laser cutting Because if i screw up then habis already Link to post Share on other sites More sharing options...
Unltd 5th Gear December 2, 2009 Share December 2, 2009 lol... i think normal sawing is okay for me but this project will require me to saw from nowhere on the plastic lid and the precision require to fit the plastic apple thing, i am not so confident to get that precision leh... So was thinking just go to those workshops that do laser cutting Because if i screw up then habis already Me thinks just buy an Apple otherwise just live with the netbook, you may end up with more issues then you can imagine. Warranty, spoiled LCD, light shining through the LCD from the back etc.... Worse thing, when you bring it out and people see you using it like that outside they will think you badge whore. Like some people who stick a BMW to a nissan car, or a Merc logo on a Korean car. Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 3, 2009 Share December 3, 2009 U might want to check with the local CNC machining enthusiast community. http://www.daddyhobby.com/forum/forumdisplay.php?f=23 Link to post Share on other sites More sharing options...
Watwheels Supersonic December 3, 2009 Share December 3, 2009 56 defu lane 1 tel: 6280 2141 I just look to them to laser cut a piece of 10mm thick acrylic sheet. But I doubt they can do an "island" cut like the one in your pic. That's most likely done by injection moulding. Alternatively you can get a wooden mould maker to make a mould for you and you buy some epoxy resin and pour into the mould. Link to post Share on other sites More sharing options...
Kxbc Turbocharged December 3, 2009 Share December 3, 2009 How about Bras Brasah Complex? There are a couple of acrylic cutting shops on the 2nd floor. Maybe they can do laser cut for you. Never tried their services before though. Link to post Share on other sites More sharing options...
Happily1986 5th Gear December 3, 2009 Author Share December 3, 2009 Thanks for many bros input and help :) Link to post Share on other sites More sharing options...
Freestylers09 5th Gear December 3, 2009 Share December 3, 2009 Good Strong Gum at Ubi might have their acraylic box v cheap.think can customize ur design too if u have it 50% bigger than A4 cost me 20+, outside need 50-100+ Link to post Share on other sites More sharing options...
Mazdaowner Moderator December 3, 2009 Share December 3, 2009 56 defu lane 1 tel: 6280 2141 I just look to them to laser cut a piece of 10mm thick acrylic sheet. But I doubt they can do an "island" cut like the one in your pic. That's most likely done by injection moulding. Alternatively you can get a wooden mould maker to make a mould for you and you buy some epoxy resin and pour into the mould. Sorry I chek your reply. [laugh] Use Moulding Rubber, 2 part, mould out the item you want, then use fibreglass resin 2 part with hardener, to pour into the rubber mould for the final product, GP resin would do fine, GP as in General Purpose resin. 2 part moulding rubber easily found. Got problems, PM me. Link to post Share on other sites More sharing options...
Mazdaowner Moderator December 3, 2009 Share December 3, 2009 Good Strong Gum at Ubi might have their acraylic box v cheap.think can customize ur design too if u have it 50% bigger than A4 cost me 20+, outside need 50-100+ Err...I chek your reply also. Please don't use epoxy AB on your finish product, makes a mess of things. Go buy 3M spray glue, mess up the area you don't want to have glue applied, then spray and stick on. Very professional finish. Link to post Share on other sites More sharing options...
Mazdaowner Moderator December 3, 2009 Share December 3, 2009 Thanks for many bros input and help :) See above replies. Link to post Share on other sites More sharing options...
Happily1986 5th Gear December 3, 2009 Author Share December 3, 2009 See above replies. gam sia... ah di jin gam dong [nosebleed] Link to post Share on other sites More sharing options...
Freestylers09 5th Gear December 3, 2009 Share December 3, 2009 i get what u mean..yupz, the glue part is ok, hmm..at least might not like cloudy type..machiam some stuff..kekeke the peel off of the sticker is at least peel by me..fresh one Link to post Share on other sites More sharing options...
David Clutched December 3, 2009 Share December 3, 2009 Do you know of anyone working in Fuyu Plastic? Link to post Share on other sites More sharing options...
Mazdaowner Moderator December 3, 2009 Share December 3, 2009 How about Bras Brasah Complex? There are a couple of acrylic cutting shops on the 2nd floor. Maybe they can do laser cut for you. Never tried their services before though. They can't do it Kiat, they will end up using a band saw to do the work. [laugh] ↡ Advertisement Link to post Share on other sites More sharing options...
Singpost courier dishonesty with incredibly lousy service
National Service in Singapore
How to feedback on hospital service?
The ownself service car hobbyist! Pls come in Share your lobangs/parts hoot
Bad service from Top93, ubi
House painting
House painting
