Yaloryalor 5th Gear March 21, 2010 Share March 21, 2010 I have 1 Sharp LCD TV in my bed room. Only recently whenever I watch Channel U for about 15~20 minutes; the signal will be interfered and become blue screen (only Channel U has this problem). However, I verify with another TV, there is good signal on Channel U. If I switch off and on again in 20 min time, the signal is back again. Is it my TV got problem with Channel U frequency? Cos I program another channel to Channel U freq also got this problem. Cannot be signal reception problem rite as other channles no prob at all. Any bro/ expert can advice? ↡ Advertisement Link to post Share on other sites More sharing options...
Clemenzo 1st Gear March 21, 2010 Share March 21, 2010 Sounds very similar to my situation.. my 5 years Sharp LCD in my bedroom would give blue screen for channel 8 at times. I tried switching channels when the problem comes and other channels are okay. Usually I adjust the tv signal cable and it gets better sometimes. Almost gave up and thought of getting a new tv. However, the issue seems improved after I get a new SCV cable. Also made sure the cable is not cramped. Not sure why only one channel is affected. So far so good, keep my fingers crossed. You can try testing the tv with another SCV point and also another SCV cable. Change a thing at a time to troubleshoot slowly. Let me know if you find something. Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear March 21, 2010 Author Share March 21, 2010 My problem is my TV is wall mounted (boxed out) and had a feature wall. The cables are hidden. Hence now wanna change LCD TV also got size limitation.. My Sharp LCD TV also bought 5 years plus liao. 19" cost $2.2K last time. Link to post Share on other sites More sharing options...
Donut Supercharged March 21, 2010 Share March 21, 2010 tats the problem of having feature wall and hidden cables.... nice to look at only Link to post Share on other sites More sharing options...
Clemenzo 1st Gear March 21, 2010 Share March 21, 2010 My problem is my TV is wall mounted (boxed out) and had a feature wall. The cables are hidden. Hence now wanna change LCD TV also got size limitation.. My Sharp LCD TV also bought 5 years plus liao. 19" cost $2.2K last time. Very troublesome then.. I am already quite lazy even though mine is just mounted on the wall with a mounting bracket. Link to post Share on other sites More sharing options...
Aurora 1st Gear March 21, 2010 Share March 21, 2010 U might need a signal booster... Can get one from SLT.... Link to post Share on other sites More sharing options...
Ultramega 1st Gear March 21, 2010 Share March 21, 2010 Is your cable point installed by SH or 3rd party contractors? If it's by 3rd party then that could be the problem. They might have used lousy cables and splitters resulting in high losses. Just a guess. Link to post Share on other sites More sharing options...
Clemenzo 1st Gear March 22, 2010 Share March 22, 2010 I suppose the problem did not exist and only comes recently? It happened to me. My tv was working fine for years, then got the tuner replaced because we can no longer receive tv signal. Then the occasional no signal problem for a particular channel comes. Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear March 22, 2010 Author Share March 22, 2010 Thanks Guys! Like Clemenzo mentioned; mine was also working fine for many years but only recently got issue on 1 channel (channel U) only. If need signal booster or my contractor use lousy cable then the problem should surface out few years ago.. Really confuse.. Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear March 24, 2010 Author Share March 24, 2010 Sounds very similar to my situation.. my 5 years Sharp LCD in my bedroom would give blue screen for channel 8 at times. I tried switching channels when the problem comes and other channels are okay. Usually I adjust the tv signal cable and it gets better sometimes. Almost gave up and thought of getting a new tv. However, the issue seems improved after I get a new SCV cable. Also made sure the cable is not cramped. Not sure why only one channel is affected. So far so good, keep my fingers crossed. You can try testing the tv with another SCV point and also another SCV cable. Change a thing at a time to troubleshoot slowly. Let me know if you find something. Bro, jus to update.. Mine confirmed case is the TV issue. I have use another TV for the same cable, no prob. At the same time, I moved the LCD TV to another room using another cable, the Channel still cannot watch. I have bought a new TV. Case closed. haha.. Link to post Share on other sites More sharing options...
Clemenzo 1st Gear March 24, 2010 Share March 24, 2010 Good for you! Maybe the tuner has a problem with that channel. Mine is still ok, no excuse to change.. Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear March 24, 2010 Author Share March 24, 2010 Good for you! Maybe the tuner has a problem with that channel. Mine is still ok, no excuse to change.. Yalor. Now the price so attractive, so tempted to change my living room TV also. haha.. Link to post Share on other sites More sharing options...
Anakin Clutched April 21, 2010 Share April 21, 2010 my 3yr old lcd recently got this flickering problem. anybody got this before? the screen got a bit darker n the flickering comes on. i tot my old time CRT tv got this problem, now lcd also got this type of problem ... haiz ... need to spend $$$ again ... Link to post Share on other sites More sharing options...
Booboon 1st Gear April 21, 2010 Share April 21, 2010 my 3yr old lcd recently got this flickering problem. anybody got this before? the screen got a bit darker n the flickering comes on. i tot my old time CRT tv got this problem, now lcd also got this type of problem ... haiz ... need to spend $$$ again ... My lcd 3 yrs old also same problem. speaker got problem too. last time adjust vol 15 enuff, now need to adjust until 25 still soft. Link to post Share on other sites More sharing options...
Mdfaz 2nd Gear June 22, 2010 Share June 22, 2010 Sorry to hijack this thread. Wondering if anyone here knows what's wrong with my lcd tv. It's a philips cineos model. Intermittently the screen goes off... Not often but when it happens, i need to switch off and on a couple of times before it's ok again. It's coming to 4 years already and warranty is over. Actually this problem happen even during warranty period but the technician came and fix the problem... Now it's back again.. Anyone knows what's wrong? Link to post Share on other sites More sharing options...
Clemenzo 1st Gear June 22, 2010 Share June 22, 2010 (edited) Any idea if any part was replaced then? Edited June 22, 2010 by Clemenzo Link to post Share on other sites More sharing options...
Mdfaz 2nd Gear June 22, 2010 Share June 22, 2010 i dun think there was any parts replaced then... i remebered the technician did some soldering and he said dunno what part was loose, that's why on/off intermittent... after the tv was serviced it was ok... until recently when warranty over, the same old problem came back. just unlucky.. Link to post Share on other sites More sharing options...
Kxbc Turbocharged June 22, 2010 Share June 22, 2010 My lcd 3 yrs old also same problem. speaker got problem too. last time adjust vol 15 enuff, now need to adjust until 25 still soft. My CRT same case as you. Maybe the speaker really did get softer over the years or our hearing becoming worse or both. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
Discussion on Gout problem
HDB season parking renewal problem
Singapore Problem Gambling
