Shochong Clutched October 24, 2011 Share October 24, 2011 Xavier, this dual lens cam has got no motion detector, right? (I remember u ever told me b4...) Yea bro~ so i using 32gb now which can last me around 9 hours ↡ Advertisement Link to post Share on other sites More sharing options...
Desmondteo Neutral Newbie October 24, 2011 Share October 24, 2011 Hi bros, axela525 recorder records very clear. Even the next lane car plate can see clearly at night. I am looking for recorder that require this purpose: - records 24/7 during parking - auto re-write old record - jeer or power cut off wun affect the recording with backup battery. - must be clear during night raining able to see far or next lane vechicle number plate. Link to post Share on other sites More sharing options...
Shochong Clutched October 24, 2011 Share October 24, 2011 Brand : INavi (Made in Korea) Price: Sms me at 97572495 to check latest promotional price! [There is no GPS Function] Summary of product features - 1280*720 of HD high-definition resolusion - Image sensor of 2.0 megapixel - Viewing angle of 146 degree at maximum, recording function of maximum 30 frame per second - Vivid normal-recording - Event recording function that saves accident video safely, and facilitates checking - Convenient hand-operated recording that enables you to choose the scene and record directly - Parking recording that observes moving and impact while parking - Voice recordking function - Built-in battery - Uses Micro SD that is easy to extense and move High-definition HD resolusion of 1280*720 Supports High-definition HD resolusion of 1280*720 HD, provides most powerful Real HD screen among the blackbox. Image sensor of 2.0 megapixelUsing image sensor of 2.0 megapixel and highly efficient lense, realizes best primium picture. * Always records primium-class picture night and day. You can see day and night picture clearly with i-navi Black Clear. Records 146 degree of viewing angle, and 30 frame/s at most. Using 146 degree of viewing angle(fixed 15 frame standard), shoots wide image for the accurate record of accident. Provides 30 frame/s recording for good image streaming. Lively normal-time recording While driving, makes all image consecutively into 1 minute video file, and saves in normal-time recording folder. Saved as AVI file, you can check the record video and share it without any file translation. When the storage space is full, auto-deleting system starts. (from old video file to recent one) Event(impact) recording that saves accident video and enables checking of the video If exterior knock occurs by an accident, detects it with 3 spindle acceleration sensor, and saves the video by the time in event(impact) recording folder. Then it saves 10 seconds before and after by the impact(20seconds) automatically. Convenient manual recording When you want to record something specialy, just click the manual recording button on the back of the product. Then it saves 10 seconds before and after by the time you click it(20seconds) in manual recording folder. Parking recording guards moves and impacts while parking Records the video of car damage. Detects the impacts and moves of forward, saving as video file while parking. * Should buy the normal-time power device seperately and connect it to the product. Voice recording function With a microphone built in the product, records the voice that helps analyzing of accident. Records the sound at the area that is not seen in video screen. Use of built-in battery In case of sudden power shut-off by accident, saves the video of that time safely. Use of Micro SD memory easy to extense and move Using exterior Micro SD memory, you can check the video easily with just seperating the memory only. Check the record video. Record video saved as AVI file format, you can check the video without any file translation. Stable and stylish design With smooth bodyline and substantial structure, has stable appearance. Easy install and use Turn the car ignition off and install the switched-off blackbox. 1. Clean the part that blackbox will be attached. 2. Take off the product's double-sided tape. 3. Adhere it at the back of room mirror or at the right side of driver's seat and adjust the direction of blackbox head to be horizontal. 4. Connect the DC 12V Cigar Jack and arrange the cable. 5. Start the car and turn on the blackbox's power switch. * Once you turn on the power button, blackbox will work automatically. Specifications and components - Size : 91(W) * 63(H) * 44(D) mm - Weight : 98g - Contents : Main, Power cable(4m), Double-sided tape(2 pieces), Cable arragement tool(3 pieces), Micro SD memory(8GB), Micro SD adapter, Manual in Korean Link to post Share on other sites More sharing options...
Jweaver Neutral Newbie October 24, 2011 Share October 24, 2011 If you didn't exceed the parameters = it's not enough to trigger as an event? Think about it this way, my event files will not be overwrited. So if i were to 'record' so many events, i find myself taking out the SD card every now and then just to delete the event files? This will somehow defeat the purpose of an ease free DVR? If you want to record a certain event down, then i guess the only way is to buy a bigger card, once go back home export it out or switch off the cam, bring home export it out to your computer? or buy another SD card, when you have an event, swap it ? You can set the sensitivity on the DR400, but you dont' want it so sensitive that it starts recording after every bump in the road, so its needs to be set quite "insensitive". I understand what you are saying and I can see why this will work for you.. But for me, I would find the inconvenience of taking hte card out each time I see an event and 'extracting' it from the live normal video, than taking it out to backup the events. The thing I have a problem with, with manufacturers is the lack of flexibility they build in.. Its sofware.. It can do almost anything.. Why not make all the features available and let the customer choose. Personally for my application, I would rather forgo the parking mode and use the button to store an 'event' instead.. Pittasoft have confirmed that this was the original functionality but they remove it... So it looks like I will have to adopt the practice of hitting the camera to trigger an event to make it work how I want.. I am sure this will work, but its hardly scientific! I just don't get why they would allow this feature IF someone (like me) wanted it... It makes no sense. Jon Link to post Share on other sites More sharing options...
Axela525 4th Gear October 24, 2011 Share October 24, 2011 (edited) Hi bros, axela525 recorder records very clear. Even the next lane car plate can see clearly at night. I am looking for recorder that require this purpose: - records 24/7 during parking - auto re-write old record - jeer or power cut off wun affect the recording with backup battery. - must be clear during night raining able to see far or next lane vechicle number plate. Iam using DOD GSE580 car cam.... Edited October 24, 2011 by Axela525 Link to post Share on other sites More sharing options...
Beng2 5th Gear October 24, 2011 Share October 24, 2011 A few months back there was a topic on this. Got one bro was stopped at Woodlands Checkpoint by an officer (who spotted his cam) and they questioned him for a few hours, then released. Last month I went in JB, I on the cam cos I observed they don't check out-going cars. But when I drove back in, I totally removed it, so as not to stir any trouble cos I know they will detail check all in-coming cars. As a Singaporean, I'm more concerned at the Malaysia side, and not the Singapore side. So at Malaysia side, I go for the Green Lane, so won't get checked at all. What? Questioned for a few hours? Looks like I had better disconnect the DC cable to the cam when crossing chk points. Only worry is I will forget to do so. Hi bro, u mentioned "I set my recorder to overwrite files first in first out" , correct me if i m wrong, i thought this is default? where to set the option for this? It's default feature, but IIRC we can choose one more mode... not so sure now after being "questioned" by you . SD card inside car now, so cannot test out. Link to post Share on other sites More sharing options...
TVT Supercharged October 24, 2011 Share October 24, 2011 What? Questioned for a few hours? Looks like I had better disconnect the DC cable to the cam when crossing chk points. Only worry is I will forget to do so. If u disconnect the cable, u might as well remove the whole cam. If your cam is small and can be hidden well, maybe u can take a chance. But mine is not fully hidden behind the rear mirror, so if the officer carefully looked, still can spot it. It really depends on your own comfort level lor (when u cross the checkpoints). Me don't want to create any trouble, as I also travel with my family... Link to post Share on other sites More sharing options...
Mindbox33 1st Gear October 24, 2011 Share October 24, 2011 Hi DR350 user.. wats the most recommended level for brightness? 50% or 75% (to the right)? do u guys set 30fps & highest quality? Link to post Share on other sites More sharing options...
Elstonng Neutral Newbie October 24, 2011 Share October 24, 2011 Can the car cam be left in car under the sun? Will it overheat the cam? Link to post Share on other sites More sharing options...
Adrianli Hypersonic October 24, 2011 Share October 24, 2011 Can the car cam be left in car under the sun? Will it overheat the cam? Can, why not??? Been using car cam for at least since 5yrs ago and none has stopped working due to overheat. Link to post Share on other sites More sharing options...
Adrianli Hypersonic October 25, 2011 Share October 25, 2011 Hi DR350 user.. wats the most recommended level for brightness? 50% or 75% (to the right)? do u guys set 30fps & highest quality? Not a Blackvue user, but why not follow the manual's recommended setting first and adjust from there to ur liking. I would recommend to set to 30fps so that the video will be smooth n not jerky due to lack of frame rates. Link to post Share on other sites More sharing options...
Mindbox33 1st Gear October 25, 2011 Share October 25, 2011 (edited) anyone keen on DR350 blackvue? less than one week old.. installed last fri nia.. to sell w power magic n 16gb card. pls pm me. tks.. Edited October 25, 2011 by Mindbox33 Link to post Share on other sites More sharing options...
Elstonng Neutral Newbie October 25, 2011 Share October 25, 2011 Thanks bro... ;) Eh how abt gps ah...? I have been removing and plugging in my gps everyday until I damn sianzzzz..... Cos the heat is really too hot to even touch..... Wonder will it die away if I just leave it to overheat....hahah Link to post Share on other sites More sharing options...
Jeunes Neutral Newbie October 25, 2011 Share October 25, 2011 Thanks bro... ;) Eh how abt gps ah...? I have been removing and plugging in my gps everyday until I damn sianzzzz..... Cos the heat is really too hot to even touch..... Wonder will it die away if I just leave it to overheat....hahah how come? I leave my Garmin in my car everyday. Never got so hot that i cant touch. But the location i put is top right, the visor area there. if you do leave it at your windscreen, I suggest not to leave it there to invite thiefs. At the end of the day, to replace windscreen or windows will cost more than the GPS itself. Link to post Share on other sites More sharing options...
Elstonng Neutral Newbie October 25, 2011 Share October 25, 2011 My gps is located right next to the cash card machine so it's directly under sunlight everyday if I dun plug Out as there is nothing to shade it.....;( Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged October 26, 2011 Share October 26, 2011 Thanks bro... ;) Eh how abt gps ah...? I have been removing and plugging in my gps everyday until I damn sianzzzz..... Cos the heat is really too hot to even touch..... Wonder will it die away if I just leave it to overheat....hahah Why dun u install a good solar film at least for your windscreen? Link to post Share on other sites More sharing options...
Ysc3 Twincharged October 26, 2011 Share October 26, 2011 Why dun u install a good solar film at least for your windscreen? solar film only helps when you are driving with the a/c on. one you park under the sun, no film can help ... my $1k 3M film also sucks big time when parked under the sun. once i even resorted to cutting corrugated cardboard to the size of my windows and placing the cardboard there to block the sun when parking !! that will work. Link to post Share on other sites More sharing options...
Jeunes Neutral Newbie October 26, 2011 Share October 26, 2011 solar film only helps when you are driving with the a/c on. one you park under the sun, no film can help ... my $1k 3M film also sucks big time when parked under the sun. once i even resorted to cutting corrugated cardboard to the size of my windows and placing the cardboard there to block the sun when parking !! that will work. maybe it's time for me to do that! but what about days that are windy or rainy? ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Jun 2026
What could have causes this car to skid so badly?
Car financing issues
