Ysc3 Twincharged November 12, 2011 Share November 12, 2011 what sensors oh?? but the mechanic tell me that if you dont know how to change the battery, all the setting will run and you need to pay again for setting. no settings wan lah, the mech just want to scare you into paying for labour ... i unplug and take out and then put in and plug-on ... all under 10 mins. so all the memory will still be intact. done that, confirmed. but i do hear that beemers will need to be hooked up with external power when changing battery. ↡ Advertisement Link to post Share on other sites More sharing options...
Vinyhong Neutral Newbie November 12, 2011 Share November 12, 2011 no settings wan lah, the mech just want to scare you into paying for labour ... i unplug and take out and then put in and plug-on ... all under 10 mins. so all the memory will still be intact. done that, confirmed. but i do hear that beemers will need to be hooked up with external power when changing battery. I saw mechanic change the battery by hooked up with another battery, he said to minimize setting problem cause nowadays car are more electronic and got a lot of setting for engine, etc. .. Link to post Share on other sites More sharing options...
Ysc3 Twincharged November 12, 2011 Share November 12, 2011 I saw mechanic change the battery by hooked up with another battery, he said to minimize setting problem cause nowadays car are more electronic and got a lot of setting for engine, etc. .. anyway, like i said ... done that, been there. Link to post Share on other sites More sharing options...
Kwanheng 1st Gear November 12, 2011 Share November 12, 2011 anyway, like i said ... done that, been there. How's fc how? I'm getting 9km/l on 17 inch, esso 95 Link to post Share on other sites More sharing options...
Ysc3 Twincharged November 12, 2011 Share November 12, 2011 How's fc how? I'm getting 9km/l on 17 inch, esso 95 our optras are all very heavy ... which is good becoz its very dense. but downside is, F/C will be bad. i am also doing about 9km/L on 195/55/15, SPC 92. Link to post Share on other sites More sharing options...
2BDriver Hypersonic November 12, 2011 Share November 12, 2011 our optras are all very heavy ... which is good becoz its very dense. but downside is, F/C will be bad. i am also doing about 9km/L on 195/55/15, SPC 92. I clocked min.10km/L, with luxury time permitted for my driving, then max.out....11km/L. Absoutely Stock conditions maintained with 185/65/R14, Yokohama A Drive Tyres. (extra: without power amp, woofer and addicted to Denso Irridium Cold Engine Spark Plugs) A Happy Owner since taking over the Optra Estate. Link to post Share on other sites More sharing options...
Vinyhong Neutral Newbie November 12, 2011 Share November 12, 2011 our optras are all very heavy ... which is good becoz its very dense. but downside is, F/C will be bad. i am also doing about 9km/L on 195/55/15, SPC 92. now FC is quite ok after change engine oil to Full synthetic, change tires, FC is now more than 10~12km/L Link to post Share on other sites More sharing options...
Kwanheng 1st Gear November 13, 2011 Share November 13, 2011 our optras are all very heavy ... which is good becoz its very dense. but downside is, F/C will be bad. i am also doing about 9km/L on 195/55/15, SPC 92. Ron 92?? Link to post Share on other sites More sharing options...
Kwanheng 1st Gear November 13, 2011 Share November 13, 2011 now FC is quite ok after change engine oil to Full synthetic, change tires, FC is now more than 10~12km/L That's gd fc! what's ur tyres spec? Link to post Share on other sites More sharing options...
Ysc3 Twincharged November 13, 2011 Share November 13, 2011 Ron 92?? yup. cheapest grade .... as long as can move can already. Link to post Share on other sites More sharing options...
Kwanheng 1st Gear November 13, 2011 Share November 13, 2011 I'm on 17 inch rim now, I plan to upgrade my rotors to a bigger size. Will it affect my fc? Link to post Share on other sites More sharing options...
Vinyhong Neutral Newbie November 13, 2011 Share November 13, 2011 That's gd fc! what's ur tyres spec? bridgestone Turanza ER30, 195/55R15 Turanza ER30 maybe i go back malaysia with petro97, it give more mileage. Link to post Share on other sites More sharing options...
Icedbs Turbocharged December 10, 2011 Share December 10, 2011 The Optra is a very reliable car. I wish all car manufacturers could build a car as robust and hardy as the Optra. I have many experience with this car. And in the last 15 years, I have driven many other cars. The Optra may not be as fuel efficient, but it is one loyal servant that will never give you up in the middle of the road simply because some parts fail. I have even known of one Optra that was driven for months with an empty radiator reservoir. The owner didn't know as the car did not overheat or fail. It just went on and on. Then there is another owner who manage to drive 350km back from KL with a fail auto gearbox before the car finally succumb to failure after passing Woodlands custom. It is like giving up its last breathe only after knowing the owner is safely back in SGP. It's incredible. Great handling as well.....but the extreme robustness is impressive. I wish all cars are like that. Link to post Share on other sites More sharing options...
Weesern Clutched January 28, 2012 Share January 28, 2012 I am looking at a few optra auto in sgcarmart. reg in 2009. what should i look out for? would prefer estate but none available for reg 2009. Link to post Share on other sites More sharing options...
Friendstar Supercharged January 28, 2012 Share January 28, 2012 The Optra is a very reliable car. I wish all car manufacturers could build a car as robust and hardy as the Optra. I have many experience with this car. And in the last 15 years, I have driven many other cars. The Optra may not be as fuel efficient, but it is one loyal servant that will never give you up in the middle of the road simply because some parts fail. I have even known of one Optra that was driven for months with an empty radiator reservoir. The owner didn't know as the car did not overheat or fail. It just went on and on. Then there is another owner who manage to drive 350km back from KL with a fail auto gearbox before the car finally succumb to failure after passing Woodlands custom. It is like giving up its last breathe only after knowing the owner is safely back in SGP. It's incredible. Great handling as well.....but the extreme robustness is impressive. I wish all cars are like that. most cars don't break down that easily wat. i'm sure hyundai accent, kia rios etc are also like tat. basically the less hi-tech the car, the more robust. Link to post Share on other sites More sharing options...
Raytham Neutral Newbie January 28, 2012 Share January 28, 2012 most cars don't break down that easily wat. i'm sure hyundai accent, kia rios etc are also like tat. basically the less hi-tech the car, the more robust. Yes you are right man. The Accent,Verna and Rios are quite reliable. Quite worthy of the tag. Link to post Share on other sites More sharing options...
Friendstar Supercharged January 28, 2012 Share January 28, 2012 Yes you are right man. The Accent,Verna and Rios are quite reliable. Quite worthy of the tag. i remember my friend's accent manual 1.3m, super can trash around. very hardy. he even went drag racing with his friends (those anyhow type), do wheel spin just for nonsense fun. lasted a good 8 years before he changed to avante. never once broken down. basically... there's nothing to break down. its manual.... no airbag. no abs. everything is just very simple. ↡ Advertisement Link to post Share on other sites More sharing options...
Updates in notification
Whatsapp updates
Whatsapp updates
Common Problems with Optra 5
Any comments for Chevrolet Optra
Chevrolet Optra updated and still going strong as a Buick
Dodge Challenger, variants and updates
1.6A optra fuel comsumption
Chevrolet Optra Engine maintenance
