What temperature do you set for air con?
Johnson28
Setting the air con lower temperature doesn't mean it gets cooler faster. Just saying.
I usually set to 25.5 & leave it there. Save fuel ( & hence money) lah. If not I will set to 20 deg. Just nice for me.
Temperature setting should depend on the outdoor temperature and humidity.
The idea is to feel comfortable. (ideal temperatrure for human is 24 degree celsius and 40 to 60 % humidity).
Too much temperature/humidity different between in door and out door is bad for the body
Singapore outside temperature/ humidity average is 30 degree/ 90% humidity during the day.
Reducing the humidity indoor play a big part in Singapore context for body comfort.
My setting:
Day time: 25 to 26 degree
night time: 23 to 24 degree (becasue nite time ourside temperature is lower, if set temp equal outside temp, compressor will stop running and humidity will go up in the room)
Just my 2 cents worth.
Edited by GoodCar
28 degree celcius for my car altis be it day or night.I feel very cold already.
You must love our local weather than. :D
I can't stand warm weather, even after living here for most of my life.
My setting:
Some cars are equipped with intelligent climate system, so I wonder if it is able to dispel humidity and regulate cabin temperature when set to auto mode?
Regards,
Come sit my car.Or you go test drive Altis,28 and 25 to me like no different! <_<
Moderator
From From what I understand, set the temp below 23, cos at 25, the heater kicks in and it shortens the life? I heard this way back when i had my bmw
my temp is set to 18
18
be it 25deg or 18 deg, e compressor work juz as hard as it cut itself off at a preset deg from e factory. Wif tis understanding, i don c e pt of setting it any higher than 18deg.
setting it at 25deg, e system simply mix hot air wif cold air to give u tat 25deg.
