Spiderman302 2nd Gear January 24, 2011 Share January 24, 2011 I am trying to drill a hole in the ceiling with a normal power drill and concrete drill bit. No matter how hard i tried, the drill bit cant penetrate beyond the "skin" later (which is about 5 mm). The concrete is very super hard. Anybody have the knowledge on this ? ↡ Advertisement Link to post Share on other sites More sharing options...
Xrbeast Neutral Newbie January 24, 2011 Share January 24, 2011 did u use a hammer drill ? Link to post Share on other sites More sharing options...
Freestylers09 5th Gear January 24, 2011 Share January 24, 2011 The first skin is always v hard to poke one once thru easy liaoz... 1 Link to post Share on other sites More sharing options...
Xers007 Supercharged January 24, 2011 Share January 24, 2011 I am trying to drill a hole in the ceiling with a normal power drill and concrete drill bit. No matter how hard i tried, the drill bit cant penetrate beyond the "skin" later (which is about 5 mm). The concrete is very super hard. Anybody have the knowledge on this ? Did you set the drill to hammer mode?? Link to post Share on other sites More sharing options...
Moredhel 2nd Gear January 24, 2011 Share January 24, 2011 (edited) The first skin is always v hard to poke one once thru easy liaoz... Must hammer the area hard and ensure got some moisture to lubricate the drill bit. Once thru the first skin, the resulting hole would guide you through. Edited January 24, 2011 by Moredhel 1 Link to post Share on other sites More sharing options...
GLZT 6th Gear January 24, 2011 Share January 24, 2011 Why you all keep using skin here skin there. Very misleading leh. Can just use layers or not? Link to post Share on other sites More sharing options...
Lanceraz Clutched January 24, 2011 Share January 24, 2011 (edited) Bro , try a heavy duty drill sure get in commonly used by the contractor. im using HILTI or u may get hitachi or others but must be heavyduty wired or batterypack. Edited January 24, 2011 by Lanceraz Link to post Share on other sites More sharing options...
SimonTan 2nd Gear January 24, 2011 Share January 24, 2011 Last time my contractor was drilling near the windows to install my heavy curtains. The contractor drill untill his drill bit koyak! Seems like my window horizontal column part is actually a metal I-beam. The contractor call in his super heavy duty metal drill to finally drill the multiple holes! I suspect you could have hit the iron rebars on your ceilings. Perhaps you can try to re-drill another hole some centimeters away from the original hole. If still difficult....then it means your drill is not heavy duty enough and might not have the 'hammer' function! Link to post Share on other sites More sharing options...
Freestylers09 5th Gear January 24, 2011 Share January 24, 2011 Must hammer the area hard and ensure got some moisture to lubricate the drill bit. Once thru the first skin, the resulting hole would guide you through. Wah lao u explain so swee but i like lol Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear January 24, 2011 Author Share January 24, 2011 Did you set the drill to hammer mode?? my drill says got a switch which shows a hammer sign. I supposed its means hammer drill. But still cant drill through beyond the outer later. I ever drill my walls before to hang hamock. No problem. But today I am drilling ceiling. Its very very hard inside. I called a hardware shop near my house, they said I must use a special heavy duty drill which cost a couple of hundred bucks. They said the wall is different from ceiling. I guess they are right. Ceiling must be super tough otherwise how can it stand the heavy weight. Link to post Share on other sites More sharing options...
Achtung7 Neutral Newbie January 24, 2011 Share January 24, 2011 Ceiling slab is reinforced concrete.. walls are brick.. try to use a smaller bit to drill a pilot hole before using the correct drill bit... I've drilled 6 holes in the ceiling before using a 600W hammer drill, so unless your equipment and drill bits aren't up to it.. you should be able to do it as well.. Link to post Share on other sites More sharing options...
Jman888 Moderator January 24, 2011 Share January 24, 2011 Must hammer the area hard and ensure got some moisture to lubricate the drill bit. Once thru the first skin, the resulting hole would guide you through. Very experience, taking up skirt photo? [laugh] Link to post Share on other sites More sharing options...
Jman888 Moderator January 24, 2011 Share January 24, 2011 my drill says got a switch which shows a hammer sign. I supposed its means hammer drill. But still cant drill through beyond the outer later. I ever drill my walls before to hang hamock. No problem. But today I am drilling ceiling. Its very very hard inside. I called a hardware shop near my house, they said I must use a special heavy duty drill which cost a couple of hundred bucks. They said the wall is different from ceiling. I guess they are right. Ceiling must be super tough otherwise how can it stand the heavy weight. It has to be very tough, I have a hook on the ceiling which can take a person weight Link to post Share on other sites More sharing options...
Nicholas1986 January 24, 2011 Share January 24, 2011 u need a rotary hammer drill not the normal hammer drill pm me if you need help Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear January 24, 2011 Share January 24, 2011 I am trying to drill a hole in the ceiling with a normal power drill and concrete drill bit. No matter how hard i tried, the drill bit cant penetrate beyond the "skin" later (which is about 5 mm). The concrete is very super hard. Anybody have the knowledge on this ? It's not the toilet or master bedroom ceiling hor? You sending a probe thru hole is it? Are you installing ceiling fan? Link to post Share on other sites More sharing options...
Mazdaowner Moderator January 24, 2011 Share January 24, 2011 A simple issue would be, that our drill bit may be dulled. Try a new concrete drill bit. also, do not push all the way, add pressure and release, then again, The bit needs some cooling before hitting the surface again. Constant pressure will burn the bit dull. If your drill has a "hammer" logo, that will suffice, no need go buying some other so called expensive drill the hardware store is recommending you. my drill says got a switch which shows a hammer sign. I supposed its means hammer drill. But still cant drill through beyond the outer later. I ever drill my walls before to hang hamock. No problem. But today I am drilling ceiling. Its very very hard inside. I called a hardware shop near my house, they said I must use a special heavy duty drill which cost a couple of hundred bucks. They said the wall is different from ceiling. I guess they are right. Ceiling must be super tough otherwise how can it stand the heavy weight. 1 Link to post Share on other sites More sharing options...
Mazdaowner Moderator January 24, 2011 Share January 24, 2011 It has to be very tough, I have a hook on the ceiling which can take a person weight That would be a anchor hook, not the regular run of the mill brass hook. Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear January 24, 2011 Author Share January 24, 2011 It's not the toilet or master bedroom ceiling hor? You sending a probe thru hole is it? Are you installing ceiling fan? I am installing a 150cm long punching bag. It weights about 48kg. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Barrier arms raised at carpark gantries in 500 HDB estates following ‘technical difficulties’
Does HDB profit from selling flats?
JEM/Westgate ceiling collapse!
Toilet ceiling leaking
