Vroomtattat 2nd Gear January 24, 2011 Share January 24, 2011 I am installing a 150cm long punching bag. It weights about 48kg. Punching bag?? *gulp!* Sorry sorry ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic May 2, 2017 Share May 2, 2017 I aslo want to buy a drill Must be ac power one No battery one Must be able to drill into concrete wall with ease Any recommendations? This one can? https://www.horme.com.sg/product.aspx?id=1090 Link to post Share on other sites More sharing options...
Kangadrool Supersonic May 2, 2017 Share May 2, 2017 Marakita should be good as per name suggests. I aslo want to buy a drillMust be ac power oneNo battery oneMust be able to drill into concrete wall with easeAny recommendations?This one can?https://www.horme.com.sg/product.aspx?id=1090 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic May 2, 2017 Share May 2, 2017 Marakita should be good as per name suggests. Use already consperm marikita 1 Link to post Share on other sites More sharing options...
Dafansu Turbocharged May 2, 2017 Share May 2, 2017 Marakita should be good as per name suggests. I'm using this also, very good price, strong and hard drilling, confirmed can go in. 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic May 2, 2017 Share May 2, 2017 I aslo want to buy a drill Must be ac power one No battery one Must be able to drill into concrete wall with ease Any recommendations? This one can? https://www.horme.com.sg/product.aspx?id=1090 Yes, I have a similar makita HR2470. Important thing is that it's a rotary hammer, not a normal hammer drill. This one will make holes in concrete easily, even the ceiling. Check that it uses SDS drill bits. Which means you need to buy the correct bit It's not that expensive, just a couple of bucks and can be used for a long time. 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 2, 2017 Share May 2, 2017 I aslo want to buy a drill Must be ac power one No battery one Must be able to drill into concrete wall with ease Any recommendations? This one can? https://www.horme.com.sg/product.aspx?id=1090 yes you need rotary hammer drill that takes SDS drill bits. can easily punch thru any concrete. makes the world of difference in getting the job done. Key words are Rotary and SDS. 2 Link to post Share on other sites More sharing options...
Kusje Supersonic May 2, 2017 Share May 2, 2017 Wah.... now I know why my 80 bucks bosch hammer drill is so lousy... Need to upgrade. 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic May 2, 2017 Share May 2, 2017 Yes, I have a similar makita HR2470. Important thing is that it's a rotary hammer, not a normal hammer drill. This one will make holes in concrete easily, even the ceiling. Check that it uses SDS drill bits. Which means you need to buy the correct bit It's not that expensive, just a couple of bucks and can be used for a long time. Whoa!!! Thanks so much guys!!!I go read up on sds Like more powerful drill bits https://www.its.co.uk/blog/buying-guides/what-is-an-sds-drill/ yes you need rotary hammer drill that takes SDS drill bits. can easily punch thru any concrete. makes the world of difference in getting the job done. Key words are Rotary and SDS. Donno can use the skill development fund money to go for those diy man course or notLike teach how to drill and etc Wah.... now I know why my 80 bucks bosch hammer drill is so lousy... Need to upgrade. Maybe one of these days when nothing to doI go Hormes there to go shopping Having a full size drill and one of those battery drill makes me feel like a man You know One hand hold Donno got hao siao or not 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic May 2, 2017 Share May 2, 2017 One hand hold Donno got hao siao or not It's long and heavy. It'll twist your wrist, unless you balance it carefully with the other hand. Link to post Share on other sites More sharing options...
Jtb 6th Gear May 2, 2017 Share May 2, 2017 It's long and heavy. It'll twist your wrist, unless you balance it carefully with the other hand. this is long and maybe clumsy for long drilling time as both hands are needed. As also bought this for most of the concrete drilling. https://www.youtube.com/watch?v=PjF-kkk8_C0 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
3 surprising upcoming changes that may affect property prices and en-bloc in 2023.
MOM help FTs look for jobs ?
Renovation budget that blows your mind
Residents can post mail from all HDB, condo letterboxes by Sep 30; no plans to remove postboxes: SingPost
Solar panels on HDB roof.
