Yeshe Turbocharged February 2, 2011 Share February 2, 2011 What is the reason ? i often saw those cars with rusty brake disk ... from what i know is not cause by rain , else my car would have those rusty brakes too ... someone enlighten me pls ? Happy chinese new year ! definitely will have one lah, i just went to wash my car, after washing the brake disc all rusty. then drive around, the rust all gone after u apply brake which will clear the rust. ↡ Advertisement Link to post Share on other sites More sharing options...
Yeshe Turbocharged February 2, 2011 Share February 2, 2011 So where does the Iron that is part of the Iron Oxide i.e. rust coming from? Not from the brake disc's surface then from air?? Like that i build a large condenser unit to collect iron oxide from air and then reduce the rust to produce iron liao lor. makes tonnes of $$$$. bugger probably fail chemistry one [laugh] Link to post Share on other sites More sharing options...
Hondavvvtec 1st Gear February 2, 2011 Share February 2, 2011 i do encounter certain rotors that dont rust easily. Previously i change my rotor to slotted type from Jap, it doesnt rust so easily, will probly show signs of rust after 2-3 days of rain if not , will only rust if i didnt drive for 1 week Link to post Share on other sites More sharing options...
Antony Neutral Newbie February 2, 2011 Share February 2, 2011 after washing car, u'll notice the rust for sure, its a normal thing Link to post Share on other sites More sharing options...
Darthrevan Supercharged February 2, 2011 Share February 2, 2011 iron & water react to give iron oxide? just drive and brake normally the brake dust will be gone Link to post Share on other sites More sharing options...
Weiming 1st Gear February 2, 2011 Share February 2, 2011 It's just surface rust for cast iron rotors else it may also be the brake pad material that is bedded onto the rotor surface which is abrasive and probably has metallic content. Link to post Share on other sites More sharing options...
Purezazn Neutral Newbie February 3, 2011 Author Share February 3, 2011 ohh , so u mean if u drive and apply the brakes , u can remove the rust ? It isnt a sign of aging of the brakes ? Link to post Share on other sites More sharing options...
Subzro Neutral Newbie February 3, 2011 Share February 3, 2011 You don't tell it's age by surface oxidation. Link to post Share on other sites More sharing options...
Legendary Clutched February 3, 2011 Share February 3, 2011 ohh , so u mean if u drive and apply the brakes , u can remove the rust ? It isnt a sign of aging of the brakes ? Are you sure your car bo rust? Everybody else rust, yours dont? It's just surface rust, apply brakes, the friction will remove it la. What aging of brakes? Use the brakes of course age la... Link to post Share on other sites More sharing options...
Watwheels Supersonic February 3, 2011 Share February 3, 2011 ohh , so u mean if u drive and apply the brakes , u can remove the rust ? It isnt a sign of aging of the brakes ? Why you confuse yourself between oxidation & aging of a metal? Any steel base metal (other dan stainless steel) without any surface finishing or coating when exposed to the elements will oxidise or rust. In engineering terms nobody use the word "aging", instead the word metal fatigue is used. If your car is used frequently there's no worry of your brake rotors rusting beyond usage, if frequently used heat will evaporate the moisture and prevent any oxidation or rusting. It's normal to see rust on the rotors after a car wash or rainy day or the car left un-used for a couple of days. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear February 3, 2011 Share February 3, 2011 I think my jazz rotors don't rust. Even after rain or wash car, the rotors are still rust free. My rotors always very smooth. Honda good design! I guess it depends on the material of manufacturing. Link to post Share on other sites More sharing options...
EventH 1st Gear February 4, 2011 Share February 4, 2011 Maybe the TS is driving a car with CCB. Good article on CCB Link to post Share on other sites More sharing options...
EventH 1st Gear February 4, 2011 Share February 4, 2011 Depends on the driver I think. My neighbour was just complaining that he went through 3 sets of front rotors on a Stream in less than 5 years. I think my jazz rotors don't rust. Even after rain or wash car, the rotors are still rust free. My rotors (stock pads) always very smooth. Honda good design! I guess it depends on the material of manufacturing. Link to post Share on other sites More sharing options...
Yuan 6th Gear February 4, 2011 Share February 4, 2011 Why you confuse yourself between oxidation & aging of a metal? Any steel base metal (other dan stainless steel) without any surface finishing or coating when exposed to the elements will oxidise or rust. In engineering terms nobody use the word "aging", instead the word metal fatigue is used. If your car is used frequently there's no worry of your brake rotors rusting beyond usage, if frequently used heat will evaporate the moisture and prevent any oxidation or rusting. It's normal to see rust on the rotors after a car wash or rainy day or the car left un-used for a couple of days. And I think it is quite a normal sign or occurrence. ↡ Advertisement Link to post Share on other sites More sharing options...
FORCE Big Brake Kit promotional Price
Time to buy some US dollar?
Brakes specialist?
Brakes specialist?
Question on brakes for Toyota
Disc brakes vs Drum brakes
How to deter car thieves from aiming ur car
Some pics from Houston
Put Euro Style Licence Plate Some More Lah
