Kieran1975 1st Gear April 2, 2011 Share April 2, 2011 My front wind screen solar flim " up the lorry" liao.... got very "BIG bubbles" and need to remove and replace. Given FOC by SE when i bought my car ..... so must be those cheap cheap one.... Any lobang? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
5936 1st Gear April 2, 2011 Share April 2, 2011 Go back to AD WS if still under warranty. If not, solar film shops will remove for you, and would be nice if you get a replacement film from them. DIY- peel them out, starting from the sides and corners. Link to post Share on other sites More sharing options...
Kieran1975 1st Gear April 2, 2011 Author Share April 2, 2011 Go back to AD WS if still under warranty. If not, solar film shops will remove for you, and would be nice if you get a replacement film from them. DIY- peel them out, starting from the sides and corners. Hi bro, Do you know how much will it cost to remove the film? Don't really want to spend much $$$ as car is already 6 yrs old and also got a few small chips on screen... Thanks. Link to post Share on other sites More sharing options...
Kieran1975 1st Gear April 3, 2011 Author Share April 3, 2011 Just checked my insurance policy, need to pay $100 to replace the front wind screen..... So will it cost less than $100 just to replace the front solar film? Any recommendation? Link to post Share on other sites More sharing options...
Hulk 1st Gear April 3, 2011 Share April 3, 2011 Hi bro, Do you know how much will it cost to remove the film? Don't really want to spend much $$$ as car is already 6 yrs old and also got a few small chips on screen... Thanks. You only just want to remove film? But if u want to replace of cos they will remove for u swee swee and paste new film. DIY remove still will leave stain on the window. Link to post Share on other sites More sharing options...
Prostcode Clutched April 3, 2011 Share April 3, 2011 Just checked my insurance policy, need to pay $100 to replace the front wind screen..... So will it cost less than $100 just to replace the front solar film? Any recommendation? $50 to remove the front solar film. Link to post Share on other sites More sharing options...
Kieran1975 1st Gear April 3, 2011 Author Share April 3, 2011 $50 to remove the front solar film. Hi Bro, can PM me the contact... Thks. Link to post Share on other sites More sharing options...
Dafansu Turbocharged April 3, 2011 Share April 3, 2011 Just checked my insurance policy, need to pay $100 to replace the front wind screen..... So will it cost less than $100 just to replace the front solar film? Any recommendation? Front windscreen tinted film cost about 80 to 100 for replacement Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged April 3, 2011 Share April 3, 2011 Just a tip,,,, install new solar film under hot day... It will have lesser bubbles compared when you do it in a rainy day. Link to post Share on other sites More sharing options...
Kieran1975 1st Gear April 12, 2011 Author Share April 12, 2011 Hi all, Thanks for your input, due to the 2 minor cracks on my front wind screen the installer advise me to change a new wind screen as removing the film may cause more damages to the cracks. End up paying $107 to my insurance workshop to replace the wind screen..... Link to post Share on other sites More sharing options...
Jefkking Clutched April 16, 2011 Share April 16, 2011 (edited) "Bubbles" due to poor workmanship. (The SE give you freebie of solar firm deducted from his commission of sales of car to you & your finance loan interest commission) Professional solar film installer will do it in dust free and air-con room (NOT open air nor direct sun) and usually around S$ 150 for front winscreen with warranty period of between 5 to 7 yrs should the defect due to mfgr or workmanship defective ) and MUST psss LTA requirments with the gauage testing of light transmission of 50% or more required. If it failed to meet 50% light transmission, then during your Vehicle Inspection on 3rd yr of aged of your car or when you pass thru the check points heading to JB, you may get block by LTA staffs and they'll issue you a letter for Inspection & fine was S$ 100 + forking of inspection fees at your own costs. So make sure it's in compliance with LTA requirements. Edited April 16, 2011 by Jefkking Link to post Share on other sites More sharing options...
C-K 2nd Gear April 16, 2011 Share April 16, 2011 "Bubbles" due to poor workmanship. (The SE give you freebie of solar firm deducted from his commission of sales of car to you & your finance loan interest commission) Professional solar film installer will do it in dust free and air-con room (NOT open air nor direct sun) and usually around S$ 150 for front winscreen with warranty period of between 5 to 7 yrs should the defect due to mfgr or workmanship defective ) and MUST psss LTA requirments with the gauage testing of light transmission of 50% or more required. If it failed to meet 50% light transmission, then during your Vehicle Inspection on 3rd yr of aged of your car or when you pass thru the check points heading to JB, you may get block by LTA staffs and they'll issue you a letter for Inspection & fine was S$ 100 + forking of inspection fees at your own costs. So make sure it's in compliance with LTA requirements. Correction: - The visible light transmittance for the front windscreen and two front side windows must be at least 70%. - The visible light transmittance for the rear windscreen and the rear passenger windows must be at least 25%. ↡ Advertisement Link to post Share on other sites More sharing options...
Citroen C4 1.2 Sensor & Display
Wheel Spacer, where to buy?
Need Advice on Self Storage
Where you cut your hair?
Going to Batam. Where to park overnight ?
