Siemens60 Clutched April 4, 2011 Share April 4, 2011 Hi, need some advice from gurus here... driving a 2006 Chevrolet Optra 1.6A... noticed that my check engine oil indicator lighted up, so stopped car immediately and check engine oil. It was within the min & max level... then con't driving home and reliased that indicator only lights up when i release accelerator and will goes off when i step on gas... it is also on when idling... Anybody encounter this before or any idea what's wrong? due sensor faulty, contaminated oil? Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Stanchiam 1st Gear April 4, 2011 Share April 4, 2011 Hi, need some advice from gurus here... driving a 2006 Chevrolet Optra 1.6A... noticed that my check engine oil indicator lighted up, so stopped car immediately and check engine oil. It was within the min & max level... then con't driving home and reliased that indicator only lights up when i release accelerator and will goes off when i step on gas... it is also on when idling... Anybody encounter this before or any idea what's wrong? due sensor faulty, contaminated oil? Thanks in advance. when is the last time u change oil? what type of oil u use and for how many km? change fuel filter and oil filter before? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear April 4, 2011 Share April 4, 2011 Hi, need some advice from gurus here... driving a 2006 Chevrolet Optra 1.6A... noticed that my check engine oil indicator lighted up, so stopped car immediately and check engine oil. It was within the min & max level... then con't driving home and reliased that indicator only lights up when i release accelerator and will goes off when i step on gas... it is also on when idling... Anybody encounter this before or any idea what's wrong? due sensor faulty, contaminated oil? Thanks in advance. Possible causes:- Oil filter partially blocked/choked (replace with new oil filter) Engine oil not suitable for usage (check with AD's office the recommended specification engine oil) Check for faulty indicator light (unlikely) Engine oil pump a little too worn to maintain the oil pressure (go see Vehicle Mechanic) Can be any two of them, or all three of them. Link to post Share on other sites More sharing options...
5936 1st Gear April 4, 2011 Share April 4, 2011 Likely oil pressure low. Link to post Share on other sites More sharing options...
Siemens60 Clutched April 5, 2011 Author Share April 5, 2011 when is the last time u change oil? what type of oil u use and for how many km? change fuel filter and oil filter before? Last change oil and oil filter in Jan using Mobil 1 0w-40. currently 7000+km. fuel filter not changed. would fuel filter affect? Link to post Share on other sites More sharing options...
Stanchiam 1st Gear April 5, 2011 Share April 5, 2011 Last change oil and oil filter in Jan using Mobil 1 0w-40. currently 7000+km. fuel filter not changed. would fuel filter affect? 4 yrs never change before? u drive how many km already? fuel filter recommend to change every 30k km if it is dirty or clog, sure can lead to other problem Link to post Share on other sites More sharing options...
Tianmo Hypersonic April 5, 2011 Share April 5, 2011 Hi, need some advice from gurus here... driving a 2006 Chevrolet Optra 1.6A... noticed that my check engine oil indicator lighted up, so stopped car immediately and check engine oil. It was within the min & max level... then con't driving home and reliased that indicator only lights up when i release accelerator and will goes off when i step on gas... it is also on when idling... Anybody encounter this before or any idea what's wrong? due sensor faulty, contaminated oil? Thanks in advance. did you change anything lately? it could be the ecu sensor, our optra has a very smart ecu which will self learn, ( I was told of this). few days back I changed my battery and the engine light came on for a while, but went away after that, was told by workshop is the ecu trying to adjust. Link to post Share on other sites More sharing options...
Eng40765 1st Gear April 5, 2011 Share April 5, 2011 did you change anything lately? it could be the ecu sensor, our optra has a very smart ecu which will self learn, ( I was told of this). few days back I changed my battery and the engine light came on for a while, but went away after that, was told by workshop is the ecu trying to adjust. In this case, Very Smart or very Stupid ECU ??? Link to post Share on other sites More sharing options...
Tianmo Hypersonic April 5, 2011 Share April 5, 2011 In this case, Very Smart or very Stupid ECU ??? I also don't know leh................ [laugh] yah, maybe stupid suits it better...... Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 5, 2011 Share April 5, 2011 engine oil level sensor. Should have nothing to do with all kinds of filter....... Link to post Share on other sites More sharing options...
Stanchiam 1st Gear April 5, 2011 Share April 5, 2011 engine oil level sensor. Should have nothing to do with all kinds of filter....... yes u r right its best he look for ws to check it out, could be leaks too Link to post Share on other sites More sharing options...
Siemens60 Clutched April 5, 2011 Author Share April 5, 2011 did you change anything lately? it could be the ecu sensor, our optra has a very smart ecu which will self learn, ( I was told of this). few days back I changed my battery and the engine light came on for a while, but went away after that, was told by workshop is the ecu trying to adjust. Thanks. Btw, how's your fc like? Link to post Share on other sites More sharing options...
Kianbeng Clutched April 5, 2011 Share April 5, 2011 Sometimes I can really can fall off from my chair when I see some of the replies, especially related to technical advise. Don't know why but its clear that we have a brain drain in MCF which has happened many many years ago. Now we focus on day-day issues, politics, .... and when it comes to car issues..... How many who has done real maintenance on their own car? Anyway, to the TS .... to briefly answer your question, you might be having a faulty oil level sensor (float). Near the oil sump, there is a sensor with a elect cable. Check for leakage or if the wires have oil leaking through them. Anyway if you go to any workshop, they will suggest you to change that. That oil level sensor or float, is an alert if the oil level falls to very low levels. But if your dip stick shows the level is ok, it means this sensor is faulty. To replace it, the best way is to wait till your next servicing, drain all the oil, open the oil sump and replace this sensor. If it's really just the engine oil indicator light as what you described, and if dip stick shows ok, then I think it's ok. If you have a CEL - Check Engine Light on, then it's different. In that case, you need a OBD reader to pull fault codes out from your car. Most (if not all) workshops in sg should have these handy. Maybe you might get a P0520 code. Link to post Share on other sites More sharing options...
Darkblue 1st Gear April 12, 2011 Share April 12, 2011 If you never go Malaysia, fuel filter in Singapore can last a long time. It is not likely a fuel issue. More likely engine oil, filter issue. Link to post Share on other sites More sharing options...
Tianmo Hypersonic April 13, 2011 Share April 13, 2011 Thanks. Btw, how's your fc like? sorry for the late reply...............my Fc is ard 9.2km/l Link to post Share on other sites More sharing options...
Icedbs Turbocharged April 19, 2011 Share April 19, 2011 Hi, need some advice from gurus here... driving a 2006 Chevrolet Optra 1.6A... noticed that my check engine oil indicator lighted up, so stopped car immediately and check engine oil. It was within the min & max level... then con't driving home and reliased that indicator only lights up when i release accelerator and will goes off when i step on gas... it is also on when idling... Anybody encounter this before or any idea what's wrong? due sensor faulty, contaminated oil? Thanks in advance. Hi TS, has your issue been solved? Any reasons for it? One of my friend's Optra is also having the same issue...when press gas, lights go off, when release gas pedal lights go on. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 19, 2011 Share April 19, 2011 LOL....what ppl should do is when you reach home wait for the oil to settle down, next morning dan check your oil level, dan you will get an accurate reading. You just stopped your engine and immediately take out the dip stick, oil is all over in the engine block, how to read? If you can get within max & min that means your oil level is very very low. Link to post Share on other sites More sharing options...
Icedbs Turbocharged April 19, 2011 Share April 19, 2011 LOL....what ppl should do is when you reach home wait for the oil to settle down, next morning dan check your oil level, dan you will get an accurate reading. You just stopped your engine and immediately take out the dip stick, oil is all over in the engine block, how to read? If you can get within max & min that means your oil level is very very low. Ok then should be what when the car is fully cooled down? At the max level? ↡ Advertisement Link to post Share on other sites More sharing options...
KIA K3 Owners check-in!
No More Cheques In Singapore come 2027 Jan and EDP (electronic deferred payment)
How To Check A New Car ?
