Bluemice 2nd Gear April 28, 2011 Share April 28, 2011 Hi, Anyone using a timer for the storage water heater ? Do reco brand. I have seen one sold in Homefix. now searching for alternatives. thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Jtb 6th Gear March 30, 2013 Share March 30, 2013 Hi, Anyone using a timer for the storage water heater ? Do reco brand. I have seen one sold in Homefix. now searching for alternatives. thanks may i know whether you have fix the timer? Link to post Share on other sites More sharing options...
LoverofCar 6th Gear March 30, 2013 Share March 30, 2013 What is the timer for? For storage type of heater...when the water heated up...it will cut off the heating by itself and kept the water hot inside...isn't it build in feature? Link to post Share on other sites More sharing options...
Blackyv Turbocharged March 30, 2013 Share March 30, 2013 Yalor.. never heard before to fix a timer for storage heater.. it has build in sensor to cut off heater when temp reached set level... Link to post Share on other sites More sharing options...
Kb27 Supersonic March 30, 2013 Share March 30, 2013 (edited) delete Edited March 30, 2013 by Kb27 Link to post Share on other sites More sharing options...
Lala81 Hypersonic March 30, 2013 Share March 30, 2013 Or is the TS thinking of the other way. Using timer to start up the heater at pre-arranged time. So that can get hot water straight once u get home Link to post Share on other sites More sharing options...
Blackyv Turbocharged March 30, 2013 Share March 30, 2013 Or is the TS thinking of the other way. Using timer to start up the heater at pre-arranged time. So that can get hot water straight once u get home Storage heater's water is always hot... if left for long hour, maybe temp drop slightly but still hot enough and when bathe time, just switch on.. it gets hot very fast... really don't see the need to have a timer... Link to post Share on other sites More sharing options...
Bluemice 2nd Gear March 30, 2013 Author Share March 30, 2013 thanks for all replies. found my solution - a 20min off timer. which allows you to ON your storage heater for 20min, and cuts OFF at the end, this solves the prob. of forgetting to off a storage heater. mice Link to post Share on other sites More sharing options...
Bluemice 2nd Gear March 30, 2013 Author Share March 30, 2013 may i know whether you have fix the timer? got it. the Brand is "SL" avail at most Homefix store, it comes with a 20min Off-delay timer( much like an egg timer) Link to post Share on other sites More sharing options...
Lala81 Hypersonic March 30, 2013 Share March 30, 2013 Storage heater's water is always hot... if left for long hour, maybe temp drop slightly but still hot enough and when bathe time, just switch on.. it gets hot very fast... really don't see the need to have a timer... daytime ok. but nighttime the heat is lost very rapidly. I don't see the need to switch off though. thermostat always switch off for you what... Ideally storage heater have timer to come on, can set via iphone/android app bestest. Then ten mins before reaching home can switch on! :wub: Link to post Share on other sites More sharing options...
Jtb 6th Gear March 30, 2013 Share March 30, 2013 thanks for all replies. found my solution - a 20min off timer. which allows you to ON your storage heater for 20min, and cuts OFF at the end, this solves the prob. of forgetting to off a storage heater. mice may i know where to purchase one with a link? Link to post Share on other sites More sharing options...
marwing 1st Gear March 30, 2013 Share March 30, 2013 may i know where to purchase one with a link? Hi TS, can share store name and product name ? I like to implement your method. Sometime we forgot to turn it off and the heater re-heat unneccsarily in the middle of night. Waste utility bill. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 30, 2013 Share March 30, 2013 Just go to Homefix and buy. I am using it too. Link to post Share on other sites More sharing options...
Dark 5th Gear March 30, 2013 Share March 30, 2013 got it. the Brand is "SL" avail at most Homefix store, it comes with a 20min Off-delay timer( much like an egg timer) Is it fixed at 20-min or variable? How much for it? I'm thinking of using it for my iron. Link to post Share on other sites More sharing options...
Bluemice 2nd Gear March 30, 2013 Author Share March 30, 2013 But this is what the thermostat inside the storage heater does for you anyway. hi, do you have a storage heater at home ? usually it comes with a ON-OFF switch... this timer switch replaces just that. its meant for forgetful pple (me) note that a storage heater works differently from an instant heater.storage heater - whole tank is heated and maintained to a pre-defined temp, as long its switch ON. regardless if you use it or not.instant heater - water is heated o a pre-defined temp, as long its switch ON and water is used. mice @others: let me take a pic later to show. tried to find www link, but failed. Link to post Share on other sites More sharing options...
Bluemice 2nd Gear March 30, 2013 Author Share March 30, 2013 here it goes ... the one in the middle Link to post Share on other sites More sharing options...
LoverofCar 6th Gear March 30, 2013 Share March 30, 2013 (edited) I still don't quite get it .....the timer is set to on at specific time of the day...said 7pm and by 7.20pm...the timer will shut off the heater,.....this will make your life much easier....and there are timer that have that function.........or is it you have to turn the timer on each time you want to shower? ...so the timer will count down for 20 min and shut off the heater... is it the set up you using? ....but if you want to shower immediately....you have to wait for sometime for the heater to heat up the water inside...so what is the point? ...the purpose is just to avoid that you did not off the heater after shower?...just use those that can on at a specific time...so you just i walk into shower and water is heated up.. Edited March 30, 2013 by LoverofCar Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 30, 2013 Share March 30, 2013 here it goes ... the one in the middle Same one I am using. Locally made, must sakport! ↡ Advertisement Link to post Share on other sites More sharing options...
Dirt cheap storage space.. recommendations?
Need Advice on Self Storage
Looking for storage space ...
