Stanchiam 1st Gear June 12, 2011 Share June 12, 2011 (edited) The main reason for going open is to save up the space for my HHO DIY project. Was told going open pod will make lower end suffer and only benefit higher end. To my surprise, my lower end did not suffer and wow, feel car more power. Not sure why it is like that. Have not try higher speed yet. To be updated on progress when i test it tomorrow on highway. http://bit.ly/lvoBug Edited June 12, 2011 by Stanchiam ↡ Advertisement Link to post Share on other sites More sharing options...
SimonTan 2nd Gear June 12, 2011 Share June 12, 2011 I am not sure exposing the filter to the water spray from the front is a good idea or not. Dry days, it's a damm good position for fresh cold air. But heavy rainy days.....any issues? I would put a plate to block the rain from Direct impact on the filter when it rains! Link to post Share on other sites More sharing options...
Stanchiam 1st Gear June 12, 2011 Author Share June 12, 2011 I am not sure exposing the filter to the water spray from the front is a good idea or not. Dry days, it's a damm good position for fresh cold air. But heavy rainy days.....any issues? I would put a plate to block the rain from Direct impact on the filter when it rains! never thought of that....hmmm have to think about it Link to post Share on other sites More sharing options...
Beehive3783 Twincharged June 12, 2011 Share June 12, 2011 Nice setup. My only gripe is that the filter seems to be too close to the engine. But then it's nearest to the grille where all the air comes in, so should be alright. Link to post Share on other sites More sharing options...
Mona-vie 1st Gear June 12, 2011 Share June 12, 2011 Thats not a good setup. Its sucking hot air directly from the radiator. For a good setup, you should house the open pod in a heat shielded box, then create a duct out of the engine bay to suck in cold air. Link to post Share on other sites More sharing options...
Mona-vie 1st Gear June 12, 2011 Share June 12, 2011 I am not sure exposing the filter to the water spray from the front is a good idea or not. Dry days, it's a damm good position for fresh cold air. But heavy rainy days.....any issues? I would put a plate to block the rain from Direct impact on the filter when it rains! Rain is not really a problem. the only issue is only when filter is submerged in water (eg flood), then its a problem. The that bit of wtaer won't matter at all. Link to post Share on other sites More sharing options...
Aaron_soh80 1st Gear June 12, 2011 Share June 12, 2011 Where is ur CAI ? Link to post Share on other sites More sharing options...
Mona-vie 1st Gear June 12, 2011 Share June 12, 2011 Where is ur CAI ? Thats what I was pointing out to him as well. Its a HAI (Hot Air Intake), not CAI. Btw, to answer TS's question why he doesn't lose his low end. The main reason is because the length of the intake is pretty much the same (I think slightly longer). Longer and more narrow intake pipes are suitable for low end while shorter and larger intakes are good for high end (at the expense of low end). The reason is due to air velocity in the intake pipe. If you measure the air velocity in a smaller and longer pipe vs a large and short pipe, you will realise the air velocity in the long pipe is higher when engine is at low RPM. However, at high RPM, the longer pipe becomes a restriction instead. Link to post Share on other sites More sharing options...
Stanchiam 1st Gear June 12, 2011 Author Share June 12, 2011 Thats what I was pointing out to him as well. Its a HAI (Hot Air Intake), not CAI. Btw, to answer TS's question why he doesn't lose his low end. The main reason is because the length of the intake is pretty much the same (I think slightly longer). Longer and more narrow intake pipes are suitable for low end while shorter and larger intakes are good for high end (at the expense of low end). The reason is due to air velocity in the intake pipe. If you measure the air velocity in a smaller and longer pipe vs a large and short pipe, you will realise the air velocity in the long pipe is higher when engine is at low RPM. However, at high RPM, the longer pipe becomes a restriction instead. oh...hahaha as long don't lose low end is good enough for me. the main reason i am doing open pod is to make space for my HHO generator installation. About the hot air, the place where i put is the area in front where all the cold air from outside come in Anyway, I will be wrapping up the exhaust with the below item and about the radiator, it is below the air filter pod with foam on top, will see how it goes, agree can be better but limited space in the engine, that is the best option i have now. Link to post Share on other sites More sharing options...
Mona-vie 1st Gear June 12, 2011 Share June 12, 2011 oh...hahaha as long don't lose low end is good enough for me. the main reason i am doing open pod is to make space for my HHO generator installation. About the hot air, the place where i put is the area in front where all the cold air from outside come in Anyway, I will be wrapping up the exhaust with the below item and about the radiator, it is below the air filter pod with foam on top, will see how it goes, agree can be better but limited space in the engine, that is the best option i have now. http://imageshack.us/photo/my-images/20/snc00765.jpg/ OIC, I thought its behind the radiator. As long as its not behind the radiator its ok. Btw, how much did you pay for the thermo wrap? Cause, from what I know its very expensive.... Can get much cheaper outside (suppliers of cermaic fiber materials). One 30m roll only around $60. If want reinforced with steel wires, around $80-90. Link to post Share on other sites More sharing options...
Mona-vie 1st Gear June 12, 2011 Share June 12, 2011 Btw, do not be alarm if you get smoke coming out from your engine bay after you use the therm wrap. Its normal. The smoke will go off after a while. Link to post Share on other sites More sharing options...
Mona-vie 1st Gear June 12, 2011 Share June 12, 2011 Btw, you going to DIY your HHO? Link to post Share on other sites More sharing options...
Stanchiam 1st Gear June 12, 2011 Author Share June 12, 2011 (edited) Btw, do not be alarm if you get smoke coming out from your engine bay after you use the therm wrap. Its normal. The smoke will go off after a while. ya, looking forward to seeing smoke coming off, should be a sight to enjoy...lol OIC, I thought its behind the radiator. As long as its not behind the radiator its ok. Btw, how much did you pay for the thermo wrap? Cause, from what I know its very expensive.... Can get much cheaper outside (suppliers of cermaic fiber materials). One 30m roll only around $60. If want reinforced with steel wires, around $80-90. not behind, on top and all the cold air from outside come in from there, think even if rain, at most a little wet, will not suck in water as it is facing downward as for the price for the wrap, i have got a very good price. Edited June 12, 2011 by Stanchiam Link to post Share on other sites More sharing options...
Stanchiam 1st Gear June 12, 2011 Author Share June 12, 2011 (edited) Btw, you going to DIY your HHO? yes and using the latest HHO technology, very efficient design, and as said, i am making space for the HHO by going open pod, now alot of space for me to play around with. Edited June 12, 2011 by Stanchiam Link to post Share on other sites More sharing options...
Kzy Neutral Newbie June 12, 2011 Share June 12, 2011 wow..nice DIY stuff... fun to play with.. wanna try it too.. .lols... btw whats HHO? =x Link to post Share on other sites More sharing options...
Stanchiam 1st Gear June 13, 2011 Author Share June 13, 2011 (edited) wow..nice DIY stuff... fun to play with.. wanna try it too.. .lols... btw whats HHO? =x HHO is hydrogen hydrogen oxygen splitting water into atoms today just fetch wife to work and wow, pick up better and acceleration faster. Like my open pod very much, no loss in lower end and in fact, increase in lower end. For high end, i didnt try and i dont drive beyond 90km, but now can accelerate faster, last time my car like no strength. By the way, I don't feel any increase in noise, maybe due to my car engine is loud already, so not able to hear the diff. Now i am very happy. One word, shiok Edited June 13, 2011 by Stanchiam Link to post Share on other sites More sharing options...
Moredhel 2nd Gear June 13, 2011 Share June 13, 2011 HHO is hydrogen hydrogen oxygen splitting water into atoms today just fetch wife to work and wow, pick up better and acceleration faster. Like my open pod very much, no loss in lower end and in fact, increase in lower end. For high end, i didnt try and i dont drive beyond 90km, but now can accelerate faster, last time my car like no strength. By the way, I don't feel any increase in noise, maybe due to my car engine is loud already, so not able to hear the diff. Now i am very happy. One word, shiok Nice stuff. You might want to consider building an aluminium enclosure with heat shield lining the inner area. Your header heat shield looks like right below your intake. I suppose when car is moving it's not really an issue. Only at traffic lights. ^^ Did you change your exhaust before? Link to post Share on other sites More sharing options...
Stanchiam 1st Gear June 13, 2011 Author Share June 13, 2011 (edited) Nice stuff. You might want to consider building an aluminium enclosure with heat shield lining the inner area. Your header heat shield looks like right below your intake. I suppose when car is moving it's not really an issue. Only at traffic lights. ^^ Did you change your exhaust before? right, when moving cold air is blowing into it so its great. will wrap up the exhaust first and see how is the effect before deciding if want to do shielding When i reach home i park my car and turn off the engine, i touch the aluminum intake pipe and it dont feel hot, but after i go down half hour later to take some item, i check again and it is hot, i suppose the heat start to spread to the pipe exhaust is stock, dont think i want to change it, not into high speed, just want faster pickup(which i surprisingly get for this mod) and make room for my HHO project. Edited June 13, 2011 by Stanchiam ↡ Advertisement Link to post Share on other sites More sharing options...
Honestbee Megastore - from boom to doom
polyamorous relationships
Open Cat COE - strategies of AD/PI
Any workshop open during CNY?
Office space, cubicles or open concept?
Decathlon Singapore
Decathlon Singapore
First all-female S’pore car wash to open in Yishun on August
Changes in employment landscape. Open legs
