BengGaBoy 2nd Gear January 16, 2012 Share January 16, 2012 Hmmm....DR350 is $90 cheaper compared to local price....tempting sia. warranty is 1 year but not incl shipping i guess. Based on the link I see, S$159 inclusive of shipment as well ↡ Advertisement Link to post Share on other sites More sharing options...
Obscurest 1st Gear January 16, 2012 Share January 16, 2012 I think the heat is due to the cam is running. That's why I intend to set it less sensitive so that the cam won't be constantly activated. Imagine if park under hot sun, think the temp of the cam can fry an egg. I personally feel that the led is not the main contribution to the heat. As for the resolution of the cam that can affect the temp? Is really sad if is really true cos purpose of choosing this cam cos of its good resolution. Btw anyone really use car cam to report dangerous drivIng or speeding commercial veh or commercial veh on lane 1? Link to post Share on other sites More sharing options...
Dankoo 4th Gear January 16, 2012 Share January 16, 2012 what what I understand...the camera is always running. The trigger is only for it to record the video..so no trigger, the camera still running. Link to post Share on other sites More sharing options...
Rogersk8ter 1st Gear January 16, 2012 Share January 16, 2012 im just worry with the cam running so hot, its life span cannot be that very long. anyone use this cam for more than one yr? Link to post Share on other sites More sharing options...
Obscurest 1st Gear January 16, 2012 Share January 16, 2012 what what I understand...the camera is always running. The trigger is only for it to record the video..so no trigger, the camera still running. Oh no wonder the cam is hot even in the morning when I'm off to work. Link to post Share on other sites More sharing options...
Obscurest 1st Gear January 16, 2012 Share January 16, 2012 im just worry with the cam running so hot, its life span cannot be that very long. anyone use this cam for more than one yr? Yup I'm int to know if anyone uses this cam for more than a year that means on it 24/7 Link to post Share on other sites More sharing options...
Salmon 1st Gear January 16, 2012 Share January 16, 2012 SO Is just 1 "bar" away from the insensitive setting right ? Think will try that. Thks for sharing. Seems like that cam is hot. I mean real hot. I guess the cam won't b fried rite? No, less than 1 bar, I mean literally beside the insensitive button. Link to post Share on other sites More sharing options...
BengGaBoy 2nd Gear January 16, 2012 Share January 16, 2012 I think the question I have on Blackvue DR400 motion detection in parking mode is, after a motion is detected, the recording (or saving into memory card) will start. Now, upon what condition(s) will be camera goes back to monitoring mode (not writing to memory card) ? For example, upon no motion is detected for say 10 mins, the camera will stop saving into the mmeory card. Based on my observation of the past footage, the moment motion was detected, it will continue to record forever until you start moving the car and it enter into normal mode. Anybody know ? Link to post Share on other sites More sharing options...
VAG Neutral Newbie January 16, 2012 Share January 16, 2012 I stick a layer of alumium foil inside the plastic casing. It helps to reduce the heat on it when parked under the sun. But mine is the eariler version without GPS, so this method might not be suitable for in-build GPS antennna version. Link to post Share on other sites More sharing options...
Ditiang Neutral Newbie January 16, 2012 Share January 16, 2012 (edited) I run my Blackvue 400 24/7 for the past 2 months and it turn out to be like this! OMG what is happening to my blackvue?????..... It wasn't like this, it used to be very clear and nice. I do agreed that when I remove my sd card, the card is kind of hot :( Clean the lens, update, re-format, still the same.... Anyone encounter the same like me? Ignore the date in the image, as I did not set the date and time after reformat. Brightness is set to normal Edited January 16, 2012 by Ditiang Link to post Share on other sites More sharing options...
Obscurest 1st Gear January 16, 2012 Share January 16, 2012 Sorry I realised that there are 3 settings. 1 for sensitivity for norm recording. Guess I will leave it to default right 1 for sensitivity for parking mode. So I will shift the 3 bars to the far left plus 1 "click" right? 1 for motion detection move the bar all the way to the left n plus 1 "click" right? Is this correct or recommended? Link to post Share on other sites More sharing options...
Salmon 1st Gear January 16, 2012 Share January 16, 2012 Seems like there's something wrong with the lens, could be due to overheating? Today while I went thru the footage of my cam, there's one part whereby the screen turned purple then to totally white. You can still see the clock still running at the bottom of the screen. My car is parked under the sun. Later on when drive off, it's back to normal. As for the motion sensor, think not accurate cause with my setting (next to insensitive) it still trigger movement from more than 8 meters! Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 16, 2012 Share January 16, 2012 I run my Blackvue 400 24/7 for the past 2 months and it turn out to be like this! OMG what is happening to my blackvue?????..... It wasn't like this, it used to be very clear and nice. I do agreed that when I remove my sd card, the card is kind of hot :( Clean the lens, update, re-format, still the same.... Anyone encounter the same like me? Ignore the date in the image, as I did not set the date and time after reformat. Brightness is set to normal bro, not only that, ur date seemed to have been reset. havent encounter anythin lidat other than GPS malfunctioning, dat y no chance to let it tong til 2 months (got mine late Nov 2011; exchanged another on Dec 2011 due to faulty GPS). Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 16, 2012 Share January 16, 2012 I stick a layer of alumium foil inside the plastic casing. It helps to reduce the heat on it when parked under the sun. But mine is the eariler version without GPS, so this method might not be suitable for in-build GPS antennna version. u able to dismantle it??? Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 16, 2012 Share January 16, 2012 I think the question I have on Blackvue DR400 motion detection in parking mode is, after a motion is detected, the recording (or saving into memory card) will start. Now, upon what condition(s) will be camera goes back to monitoring mode (not writing to memory card) ? For example, upon no motion is detected for say 10 mins, the camera will stop saving into the mmeory card. Based on my observation of the past footage, the moment motion was detected, it will continue to record forever until you start moving the car and it enter into normal mode. Anybody know ? doesn't work dat way for both my 350 n 400. maybe motion sensor sensitive; even rain fallin on windscreen considered movement... dat wat happened to mine, but dat case should be good rite... Link to post Share on other sites More sharing options...
BengGaBoy 2nd Gear January 16, 2012 Share January 16, 2012 doesn't work dat way for both my 350 n 400. maybe motion sensor sensitive; even rain fallin on windscreen considered movement... dat wat happened to mine, but dat case should be good rite... Then seriously I'm wondering what so proprietary about Pittasoft motion detection algorithm as claim on their webby :) Basically they just detect any differences between last video frame and current video frame to determine motion. Link to post Share on other sites More sharing options...
Kiario 5th Gear January 17, 2012 Share January 17, 2012 his positive feedbacks looks ok leh. be wary of these positive feedbacks. i got a 720p camera from ebay, uplorry within a few months and I sent back to seller for replacement(shipping fees paid by me). when replacement set arrived, uplorry symptons within a few days, emailed seller and they refused to communicate anymore. tried to change my feedback score but cannot, so lan lan even with the 1 year warranty. Link to post Share on other sites More sharing options...
Obscurest 1st Gear January 17, 2012 Share January 17, 2012 Then seriously I'm wondering what so proprietary about Pittasoft motion detection algorithm as claim on their webby :) Basically they just detect any differences between last video frame and current video frame to determine motion. So if tats the case the sensitivity toggling won't work at all right ? Anyway I have adjusted the sensitivity hopefully it won't capture anything tat is far away. Else is literally recording 24/7 ↡ Advertisement Link to post Share on other sites More sharing options...
Any Top Notch Buffet Catering to recommend? PLEASE!!
W212 owners, please check-in
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
